OBS Preview Keeps Freezing
You can just disable VRR in your windows display settings
Tried your advice - didn't help
100% reproducible for me if MPO's enabled and
1. Start OBS
2. Start RIDE 5
Аfter few seconds, you starting to see popping RIDE 5 frames over preview window even if your game/windows capture is disabled
After some time preview window freezing (in less than 15 minutes I think)
No issues with disabled MPO trick, that I using since first public release of 24H2 ¯\_(ツ)_/¯
I've been having the same problem, but I'm on a laptop with a Gefore RTX 3070 Laptop GPU and I just can't find G-Sync anywhere because my Nvidia control panel is almost empty. Anyone got some help for that?
Have you tried disabling variable refresh rate in your windows display settings and then restarting your computer?
I'm trying to do this but it won't let me scroll to find Vertical Sync, and everything is grayed out. Is there a setting to fix this? I tried resetting my Drs Nvidia Corporation folder but that didn't work. Thanks!
Just helped a friend through this. Change global setting off of auto-select and to High Performance NVIDIA processor. Then it won't be greyed out.
