Window Capture device (Blinks)
DOM.org
Windows 11 Home
Version 21H2
Build 22000.469
Video Capture device Blinks or Flickers.
(Recordings and Livestream)
Followed trouble shooting page
The OBS Gpu is set to high.
I turned Game mode off.
Messed with setting a thousand times, but then put them back on default.
Nothing worked.
I looked at the log but nothing stoodout.
The log will show that I Changed The VCD resolution to 1280×720 but I just restored it to default because that didn't work either.
This did not help my problem! I am still searching for a fix. This issue is not multiple devices on a USB port. I went into the system and looked up the USB ports and they are all functional. The drivers are up to date. This computer has all its updates. Still haven't found a fix for the camera blinking in and out.
Often internal cams are conected to the USB root hub ! like other devices like keyboard or touchpad on notebooks
send a screenshot of the tree viewer !
the device manager is a Stupid thing .
Trying to use a single video capture device in multiple scenes, you should NOT be using multiple different-named video capture device sources.
I fixed this and put everything into one scene and one camra and the camera still blinks
Here's my updated log which shows I have one, scene and one camera. But I am still having the same problem. If you could help please.
