Resource icon
win-capture-audio v2.2.3-beta
I have only tested this with beta 1, but I can say this:
It works with 28 as distributed for 27.x.y.
Hell, of all the plugins I use with 27.2.4, this is the only plugin that ACTUALLY WORKED. I fully expected it to NOT WORK AT ALL.
In fact, win-capture-audio in its current state is much more advanced than what's bundled with OBS Studio 28. I would actually install over what OBS has because it allows you to capture stuff that the bundled plugin, whose win-capture-audio level of functionality is about the same as 2.0.0-beta3, won't. That's because win-capture-audio 2.0.0-beta3 and OBS Studio's bundled plugin both rely on looking for processes with windows on-screen. Win-capture-audio does not require the program have a window; it just requires it to emit sound.
Since it won't directly overwrite the file that OBS bundles, it WILL, however, supersede its functionality. You can't use OBS's distributed plugin with the most recent win-capture-audio installed.
I will be trying it with the release version of OBS Studio 28 so I can report on how well it works.
--Katt. =^.^=
How to add Xbox game bar party chat ? Win+g
Is not recognized into the plugin sources , no sound, only by the main desktop source in obs.
I tried everything , but couldnt get It to work.
I use It to stream while talking with my friend from xbox
Win 10
First, which version of the plugin and OBS Studio are you using? Also, which release of Windows 10, including bittedness (i.e. 32- vs. 64-bit) and release (NOT as whether it's "Home", "Pro", "Education" or "Enterprise" or whatever)?
You need at least Windows 10 release 2004, a.k.a. 20H1 at the barest minimum with 20H2 being strongly recommended. Check by using "winver". If it's 1909 or earlier, you MUST update to a newer release. If you are using an LTSC release of Windows 10 Enterprise, it must be 2021 or later.
If you are using a 32-bit release of either OBS Studio or Windows 10, you are out of luck. Both MUST be 64-bit.
If you are using OBS Studio 27.x.y, you need to make sure Application Audio Output Capture is an option. If it is not, you may not have installed the plugin correctly or at all.
If you are using OBS Studio 28.0.0, you need to install the plugin correctly. If you don't, only the default, less-capable OBS Studio plugin will be available as "Application Audio Capture (BETA)" will be visible. Win-capture-audio's source is called "Application Audio Output Capture" and can live alongside OBS Studio's default plugin and will be after the OBS default application audio capture plugin.
Hope this helps.
--Katt. =^.^=
--Katt. =^.^=
UPDATE: As it turns out, both plugins will coexist with each other.
That said, I'll still use the win-capture-audio plugin until such a time as when the OBS Studio default plugin is as advanced in development and stability that win-capture-audio is in its present state.
--Katt. =^.^=
Hope this helps.
--Katt. =^.^=
OBS 27.2.4 (64bit)
Windows 10 Pro 64bit 21H1
OS19043.1889 , Windows Feature Experience Pack 120.2212.4180.0
The plugin is working properly in any other sound sources ...Spotify , browsers , games ... it's amazing. But, I use Xbox game bar (win+g) to chat in parties with my friends on xbox , daily , it's our sacred routine in Twitch lives. But no sound is captured by the plugin when I try to capture it from gamebar. None
The only way to capture the audio from gamebar is the default "desktop audio" sound track from the OBS. But it is mixed with all the other sounds, and that's the reason I tried this plugin, to split it.
Any idea ? Anyway thanks for the help
Can anyone try to start a party chat on Xbox game bar ( Win+g ) and figure out How to make the plugin capture It on obs ?
First of all, as I had mentioned earlier, the application must be emitting sound before it'll appear on the list of programs that you can add. However, if you know the exe file that it uses, you can add it to the list, preferably of a second instance of the plugin so you can vary its volume separately from all other sources in the scene(s) it's included in.
Since I do not use this app, I do not know the app's exe name.
--Katt. =^.^=
Hey all. Is anyone else seeing this problem with this plugin?
Although I have multiple apps emitting audio, the "currently active sessions" drop down is empty, and the "Add executable" button is greyed out.
I'm running Windows 10 21H2, OBS 28.0.1 and version 2.2.3-beta of this plugin. I've tried running OBS as Administrator and just normally, but neither seem to work.
FWIW, the "built in" version of this plugin in OBS 28 seems to show the processes without problem ... but v2.2.3 is much more attractive because a single source can cater for multiple applications.
Thanks in advance for the help.
Hey I'm trying to setup my audio using this plugin. I've made it to where Discord, games, and headset can be separate audio sources through the applications, but when I try to record. It either chooses to record the game audio and not my headset or the other way around. It is getting both sources on the meter but the recording picks and chooses between game or headset for audio everything. Anyone have an idea what it could be? I already tried turning off device exclusivity for headset to see if that would work and same problem still.
My Win-audio-capture isn't responding on mixer.
11:49:16.589: ==== Startup complete ===============================================
11:49:16.947: All scene data cleared
11:49:16.947: ------------------------------------------------
11:49:16.997: [win-wasapi: 'Desktop Audio'] update settings:
11:49:16.997: device id: {0.0.0.00000000}.{e8c0302a-46db-4716-977d-639e002e3532}
11:49:16.997: use device timing: 1
11:49:16.997: [Loaded global audio device]: 'Desktop Audio'
11:49:16.999: [win-wasapi: 'Mic/Aux'] update settings:
11:49:16.999: device id: {0.0.1.00000000}.{431d4a0d-4b44-484c-8035-86c3bd6112e6}
11:49:16.999: use device timing: 0
11:49:16.999: [Loaded global audio device]: 'Mic/Aux'
11:49:17.002: [win-wasapi: 'Audio Output Capture'] update settings:
11:49:17.002: device id: {0.0.0.00000000}.{e8c0302a-46db-4716-977d-639e002e3532}
11:49:17.002: use device timing: 1
11:49:17.004: [duplicator-monitor-capture: 'Display Capture'] update settings:
11:49:17.004: display: 1 (1920x1080)
11:49:17.004: cursor: true
11:49:17.004: method: DXGI
11:49:17.028: WASAPI: Device 'Speakers (Realtek(R) Audio)' [48000 Hz] initialized
11:49:17.031: WASAPI: Device 'Speakers (Realtek(R) Audio)' [48000 Hz] initialized
11:49:17.079: WASAPI: Device 'Microphone (Realtek(R) Audio)' [44100 Hz] initialized
11:49:18.080: Switched to scene 'Scene'
11:49:18.081: ------------------------------------------------
11:49:18.081: Loaded scenes:
11:49:18.081: - scene 'Scene':
11:49:18.081: - source: 'Game Capture' (game_capture)
11:49:18.081: - source: 'Display Capture' (monitor_capture)
11:49:18.081: - source: 'Audio Output Capture' (wasapi_output_capture)
11:49:18.081: - source: 'Application Audio Output Capture' (audio_capture)
11:53:12.731: Settings changed (outputs)
11:53:12.731: ------------------------------------------------
11:55:03.138: User Removed source 'Application Audio Output Capture' (audio_capture) from scene 'Scene'
11:55:07.773: User added source 'Application Audio Output Capture' (audio_capture) to scene 'Scene'
11:55:28.918: [win-capture-audio] (ActivateCompleted) activate failed (0x80070002)
11:55:28.930: [win-capture-audio] (CaptureSafe) C:\Users\joeka\Desktop\win-capture-audio\src\audio-capture-helper.cpp(56)\win-capture-audio.dll!00007FFEDE4AD04C: (caller: 00007FFEDE4ACD77) Exception(1) tid(1964) 80070002 The system cannot find the file specified.
11:55:28.930:
12:02:23.212: [audio monitoring: 'Application Audio Output Capture'] audio_monitor_init_wasapi: Failed to get device: 80070490
12:02:23.212: User changed audio monitoring for source 'Application Audio Output Capture' to: monitor and output
12:03:35.411: [win-wasapi: 'Mic/Aux'] update settings:
12:03:35.411: device id: {0.0.1.00000000}.{431d4a0d-4b44-484c-8035-86c3bd6112e6}
12:03:35.411: use device timing: 0
12:04:31.642: [win-wasapi: 'Mic/Aux'] update settings:
12:04:31.642: device id: {0.0.1.00000000}.{431d4a0d-4b44-484c-8035-86c3bd6112e6}
12:04:31.642: use device timing: 0
12:32:43.438: Settings changed (outputs)
12:32:43.438: ------------------------------------------------
12:32:54.609: Settings changed (outputs)
12:32:54.609: ------------------------------------------------
12:33:05.514: Settings changed (outputs)
12:33:05.514: ------------------------------------------------
12:33:36.702: User Removed source 'Application Audio Output Capture' (audio_capture) from scene 'Scene'
12:33:40.588: User added source 'Application Audio Output Capture' (audio_capture) to scene 'Scene'
12:34:09.786: [win-capture-audio] (ActivateCompleted) activate failed (0x80070002)
12:34:09.787: [win-capture-audio] (CaptureSafe) C:\Users\joeka\Desktop\win-capture-audio\src\audio-capture-helper.cpp(56)\win-capture-audio.dll!00007FFEDE4AD04C: (caller: 00007FFEDE4ACD77) Exception(2) tid(2c9c) 80070002 The system cannot find the file specified.
12:34:09.787:
12:34:21.499: [audio monitoring: 'Application Audio Output Capture'] audio_monitor_init_wasapi: Failed to get device: 80070490
12:34:21.499: User changed audio monitoring for source 'Application Audio Output Capture' to: monitor and output
12:54:32.869: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds (source: Mic/Aux)
12:54:32.869:
12:55:59.723: Device 'Speakers (Realtek(R) Audio)' invalidated. Retrying (source: Desktop Audio)
12:55:59.724: Device 'Speakers (Realtek(R) Audio)' invalidated. Retrying (source: Audio Output Capture)
12:55:59.827: [win-capture-audio] (ActivateCompleted) activate failed (0x80070002)
12:55:59.828: [win-capture-audio] (CaptureSafe) C:\Users\joeka\Desktop\win-capture-audio\src\audio-capture-helper.cpp(56)\win-capture-audio.dll!00007FFEDE4AD04C: (caller: 00007FFEDE4ACD77) Exception(3) tid(560) 80070002 The system cannot find the file specified.
12:55:59.828:
12:56:02.750: WASAPI: Device 'Speakers (Realtek(R) Audio)' [48000 Hz] initialized
12:56:02.752: WASAPI: Device 'Speakers (Realtek(R) Audio)' [48000 Hz] initialized
12:56:03.816: Device 'Speakers (Realtek(R) Audio)' invalidated. Retrying (source: Desktop Audio)
12:56:03.817: Device 'Speakers (Realtek(R) Audio)' invalidated. Retrying (source: Audio Output Capture)
12:56:03.855: [win-capture-audio] (ActivateCompleted) activate failed (0x80070002)
12:56:03.855: [win-capture-audio] (CaptureSafe) C:\Users\joeka\Desktop\win-capture-audio\src\audio-capture-helper.cpp(56)\win-capture-audio.dll!00007FFEDE4AD04C: (caller: 00007FFEDE4ACD77) Exception(4) tid(2d9c) 80070002 The system cannot find the file specified.
12:56:03.855:
12:56:06.840: WASAPI: Device 'Speakers (Realtek(R) Audio)' [48000 Hz] initialized
12:56:06.843: WASAPI: Device 'Speakers (Realtek(R) Audio)' [48000 Hz] initialized
12:56:12.579: Device 'Speakers (Realtek(R) Audio)' invalidated. Retrying (source: Desktop Audio)
12:56:12.581: Device 'Speakers (Realtek(R) Audio)' invalidated. Retrying (source: Audio Output Capture)
12:56:12.621: [win-capture-audio] (ActivateCompleted) activate failed (0x80070002)
12:56:12.622: [win-capture-audio] (CaptureSafe) C:\Users\joeka\Desktop\win-capture-audio\src\audio-capture-helper.cpp(56)\win-capture-audio.dll!00007FFEDE4AD04C: (caller: 00007FFEDE4ACD77) Exception(5) tid(9c0) 80070002 The system cannot find the file specified.
12:56:12.622:
12:56:15.611: WASAPI: Device 'Speakers (Realtek(R) Audio)' [48000 Hz] initialized
12:56:15.615: WASAPI: Device 'Speakers (Realtek(R) Audio)' [48000 Hz] initialized
13:03:49.908: Settings changed (general)
13:03:49.908: ------------------------------------------------
Anybody else having this issue? @bozbez ?
This is great, but for some reason the Application Audio Output Capture is significantly quieter than what Desktop Audio captures for me. For comparing they're both at 0.0db, and I don't have any filters or anything on either of them. Is there some "reason" for this, or is it kinda just how it is?
Hey,
I have tried using Win Capture Audio a couple Months ago to seperate my audio layers like game sound, discord, firefox for music etc. but the audio stuttered from time to time.
I couldnt get a fix for that so I installed voicemeeter and figured it all out and it worked.
Now I thought the new OBS 28 feature would let me seperate my tracks without any other programs and I tried it out, but it´s stuttering, too.
So my question is, does this come with the open apps it grabs the sound from?
Win Capture Audio does the same as I remember, you choose an open window to grad the sound from.
What could cause this? I really would like to get rid of voicemeeter
--Katt. =^.^=
The Plug-in recognizes the GameBar.exe application but does not capture the audio.
The plugin used to work for me but after doing a clean install of windows 10 and trying to set it up again it wont work, everything is up to date to the latest version.
The problem is it recognizes the executable, and it adds the bar to the list of tracks but no audio is being captured.
The only difference im finding is that for other people in the window (of the picture I attached) it would only say Spotify.exe while mine is in brackets followed by the music that spotify is playing. (same for other applications like chrome has the tab name instead of just "Chrome.exe", and discord will show the channel name instead of just "Discord.exe") No idea why its different.
OBS version: 28.0.3 (64 bit)
Windows: Windows 10 Pro, Version 20H2, OS build 19042.631
NVM im stupid I fixed it. Apparently just being version 20H2 isnt enough, and my OS build was too old. The OS build that this worked for me is 19042.1706 The plugin apparently uses an API that is in windows 11 and in the newest windows 10 build so you have to absolutely make sure your windows is the newest OS build and windows 10 might not offer the update until a few days after you last updated or something. It was like that for me where got the option to update to build 19042.1706 three days after updating to version 19042.631.
Hey,
nobody knows anything?
hi guys,
i have downloaded win captured audio.
I installed the plugin correctly, it makes me select "application audio output capture" but when I start spotify, for example, it doesn't capture the audio and in the mixer the luminous line remains off.
I am attaching the log file.
If anyone knows how to fix it please let me know.
I am desperate.
18:52:37.371: CPU Name: AMD Ryzen 5 2600 Six-Core Processor
18:52:37.371: CPU Speed: 3400MHz
18:52:37.371: Physical Cores: 6, Logical Cores: 12
18:52:37.371: Physical Memory: 16335MB Total, 8489MB Free
18:52:37.371: Windows Version: 10.0 Build 18363 (release: 1909; revision: 1256; 64-bit)
18:52:37.371: Running as administrator: false
18:52:37.371: Aero is Enabled (Aero is always on for windows 8 and above)
18:52:37.371: Windows 10/11 Gaming Features:
18:52:37.371: Game DVR: On
18:52:37.374: Sec. Software Status:
18:52:37.375: Windows Defender Antivirus: enabled (AV)
18:52:37.376: Windows Firewall: enabled (FW)
18:52:37.476: Current Date/Time: 2022-11-20, 18:52:37
18:52:37.476: Browser Hardware Acceleration: true
18:52:37.476: Hide OBS windows from screen capture: false
18:52:37.476: Qt Version: 6.3.1 (runtime), 6.3.1 (compiled)
18:52:37.476: Portable mode: false
18:52:37.530: OBS 28.1.2 (64-bit, windows)
18:52:37.530: ---------------------------------
18:52:37.654: ---------------------------------
18:52:37.654: audio settings reset:
18:52:37.654: samples per sec: 48000
18:52:37.654: speakers: 2
18:52:37.654: max buffering: 960 milliseconds
18:52:37.654: buffering type: dynamically increasing
18:52:37.656: ---------------------------------
18:52:37.656: Initializing D3D11...
18:52:37.656: Available Video Adapters:
18:52:37.660: Adapter 0: NVIDIA GeForce GTX 1050 Ti
18:52:37.660: Dedicated VRAM: 4213178368
18:52:37.660: Shared VRAM: 4269381632
18:52:37.660: PCI ID: 10de:1c82
18:52:37.660: Driver Version: 30.0.15.1123
18:52:37.660: output 0:
18:52:37.660: name=SAMSUNG
18:52:37.660: pos={0, 0}
18:52:37.660: size={1600, 900}
18:52:37.660: attached=true
18:52:37.660: refresh=30
18:52:37.660: space=RGB_FULL_G22_NONE_P709
18:52:37.660: sdr_white_nits=80
18:52:37.660: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
18:52:37.661: output 1:
18:52:37.661: name=SyncMaster
18:52:37.661: pos={1600, 285}
18:52:37.661: size={1360, 768}
18:52:37.661: attached=true
18:52:37.661: refresh=60
18:52:37.661: space=RGB_FULL_G22_NONE_P709
18:52:37.661: sdr_white_nits=80
18:52:37.661: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
18:52:37.661: output 2:
18:52:37.661: name=LCDTV16
18:52:37.661: pos={-1360, 297}
18:52:37.663: Loading up D3D11 on adapter NVIDIA GeForce GTX 1050 Ti (0)
18:52:37.756: D3D11 loaded successfully, feature level used: b000
18:52:37.756: DXGI increase maximum frame latency success
18:52:37.756: D3D11 GPU priority setup failed (not admin?)
18:52:39.508: ---------------------------------
18:52:39.508: video settings reset:
18:52:39.508: base resolution: 1920x1080
18:52:39.508: output resolution: 1920x1080
18:52:39.508: downscale filter: Bicubic
18:52:39.508: fps: 60/1
18:52:39.508: format: NV12
18:52:39.508: YUV mode: Rec. 709/Partial
18:52:39.508: NV12 texture support enabled
18:52:39.508: P010 texture support not available
18:52:39.512: Audio monitoring device:
18:52:39.512: name: Predefinito
18:52:39.512: id: default
18:52:39.512: ---------------------------------
18:52:39.515: No AJA devices found, skipping loading AJA UI plugin
18:52:39.516: Failed to initialize module 'aja-output-ui.dll'
18:52:39.517: No AJA devices found, skipping loading AJA plugin
18:52:39.517: Failed to initialize module 'aja.dll'
18:52:39.518: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
18:52:39.521: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
18:52:39.523: Failed to load 'en-US' text for module: 'decklink-captions.dll'
18:52:39.525: Failed to load 'en-US' text for module: 'decklink-output-ui.dll'
18:52:39.527: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
18:52:39.527: Failed to initialize module 'decklink.dll'
18:52:39.576: [AMF] Unable to load 'amfrt64.dll', error code 126.
18:52:39.580: [AMF] AMF Test failed due to one or more errors.
18:52:39.580: Failed to initialize module 'enc-amf.dll'
18:52:39.596: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
18:52:39.596: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
18:52:39.596: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
18:52:39.639: [obs-browser]: Version 2.18.7
18:52:39.639: [obs-browser]: CEF Version 103.0.5060.134 (runtime), 103.0.0-5060-shared-textures.2591+g4204d54+chromium-103.0.5060.134 (compiled)
18:52:39.646: NVENC supported
18:52:39.646: [NVENC] AV1 is not supported
18:52:39.648: [noise suppress]: NVIDIA RTX denoiser disabled, redistributable not found
18:52:39.649: [NVIDIA RTX VIDEO FX]: FX disabled, redistributable not found.
18:52:40.168: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.0.1 | RPC Version: 1)
18:52:40.168: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.3.1 | Qt version (run-time): 6.3.1
18:52:40.168: [obs-websocket] [obs_module_load] Linked ASIO Version: 101201
18:52:40.179: [obs-websocket] [obs_module_load] Module loaded.
18:52:40.376: [vlc-video]: Couldn't find VLC installation, VLC video source disabled
18:52:40.426: [win-capture-audio] Version 2.2.3 (74323e6)
18:52:40.544: ---------------------------------
18:52:40.544: Loaded Modules:
18:52:40.544: win-wasapi.dll
18:52:40.544: win-mf.dll
18:52:40.544: win-dshow.dll
18:52:40.544: win-capture.dll
18:52:40.544: win-capture-audio.dll
18:52:40.544: vlc-video.dll
18:52:40.544: text-freetype2.dll
18:52:40.544: rtmp-services.dll
18:52:40.544: obs-x264.dll
18:52:40.544: obs-websocket.dll
18:52:40.544: obs-vst.dll
18:52:40.544: obs-transitions.dll
18:52:40.544: obs-text.dll
18:52:40.545: obs-qsv11.dll
18:52:40.545: obs-outputs.dll
18:52:40.545: obs-filters.dll
18:52:40.545: obs-ffmpeg.dll
18:52:40.545: obs-browser.dll
18:52:40.545: image-source.dll
18:52:40.545: frontend-tools.dll
18:52:40.545: decklink-output-ui.dll
18:52:40.545: decklink-captions.dll
18:52:40.545: coreaudio-encoder.dll
18:52:40.545: ---------------------------------
18:52:40.545: ==== Startup complete ===============================================
18:52:40.601: All scene data cleared
18:52:40.601: ------------------------------------------------
18:52:40.624: [win-wasapi: 'audio in uscita'] update settings:
18:52:40.624: device id: default
18:52:40.624: use device timing: 1
18:52:40.624: Switched to scene 'audio'
18:52:40.624: ------------------------------------------------
18:52:40.624: Loaded scenes:
18:52:40.624: - scene 'Scena':
18:52:40.624: - scene 'CoDiario':
18:52:40.625: - source: 'CoD m' (window_capture)
18:52:40.625: - source: 'audio in uscita' (wasapi_output_capture)
18:52:40.625: - scene 'audio':
18:52:40.625: - source: 'cod' (audio_capture)
18:52:40.625: - source: 'youtube' (audio_capture)
18:52:40.625: ------------------------------------------------
18:52:40.639: [win-capture-audio] (ActivateCompleted) activate failed (0x80070002)
18:52:40.639: [win-capture-audio] (CaptureSafe) C:\Users\joeka\Desktop\win-capture-audio\src\audio-capture-helper.cpp(56)\win-capture-audio.dll!00007FFD19B5D04C: (caller: 00007FFD19B5CD77) Exception(1) tid(43a0) 80070002 Impossibile trovare il file specificato.
18:52:40.639:
18:52:40.688: WASAPI: Device 'Altoparlanti (2- M-Audio AIR 192 6)' [48000 Hz] initialized
