Twitch Switcher
TheKreamCs
Src is the source code, unless you are a developer, dont care about it.
If you are running OBS x64, unrar strait into OBS folder, and same for x86, but in the OBS x86 folder.
into the plugin folder or where? Because if i put this files in the plugins folder, then i don't see it under settings.
TheKreamCs
thanks! But i have a problem with the x64. Always if i want to change my scene with twitch switcher, then obs crashed all time
Drow Arrow
so i have a problem everytime i hit the apply button after making a change or even without making a change it throws up an exception then obs crashes... any ideas?
can find the message that happens before the crash here
Scacht
32bit or 64bit? Also are you able to post the text file that's produced from the crash? Also a copy of your twitchsw.ini without your OAuthKey. First thing that comes to mind is to make sure you don't have a rogue empty entry in your table (on the bottom, like in the picture). I haven't been able to reproduce that error with any combo I've tried, so the above information will help greatly.
Yzangard
I have the exact same issue, now it is even crashing as soon as OBS starts, surely due to automation. Where are the config files stored so I can reset them ?
Here is the log :
OBS has encountered an unhandled exception and has terminated. If you are able to
reproduce this crash, please submit this crash report on the forums at
https://obsproject.com/ - include the contents of this crash log and the
minidump .dmp file (if available) as well as your regular OBS log files and
a description of what you were doing at the time of the crash.
This crash appears to have occured in the 'c:\program files\obs\plugins\twitchsw.dll' module.
**** UNHANDLED EXCEPTION: c0000094
Fault address: 00007FFDC9AD3B46 (c:\program files\obs\plugins\twitchsw.dll)
OBS version: Open Broadcaster Software v0.655b
Windows version: 6.2 (Build 9200)
CPU: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Crashing thread stack trace:
Stack EIP Arg0 Arg1 Arg2 Arg3 Address
000000D16C23FE30 00007FFDC9AD3B46 0000000000000000 00007FFDC9AD1A80 000000D169BA6B20 0000000000000000 twitchsw.dll!0x7ffdc9ad3b46
000000D16C23FF50 00007FFDE3062D92 00007FFDE3062D70 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ffde3062d92
000000D16C23FF80 00007FFDE3659F64 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ffde3659f64
A minidump was saved to C:\Users\Yzangard\AppData\Roaming\OBS\crashDumps\OBSCrashDump2015-09-21_3.dmp.
Please include this file when posting a crash report.
List of loaded modules:
Base Address Module
Yzangard
I managed to remove the file that was causing problem but it created another file that created problems, as well. Something wrong with the plugin, maybe is it due to different language used ? My computer is in french (despite I wanted it in english).
Yzangard
Ok, I removed blank lines at the beginning of the ini files and it seems to work properly now.
Testing further.
Drow Arrow
it would appear i cannot get it to happen again.. it seems to have cured itself. however it doesn't seem to be changing the title of the stream or the game i'm playing on twitch when any of the listed scenes are selected in obs. 64bit fyi
Oni
Hey! Same problem here.
Going to "Twitch Switcher" settings window and leaving it, without any modification, prompts asking to apply changes, every time.
Further more, using "start at launch" options make the OBS crashing and the only solution is to remove the plugin or disable autorun by editing the settings file.
Windows 10 Pro 64 bit
OBS 64 bit, running it as admin
Crash log
Fault address: 00007FF9044E3B46 (c:\program files\obs\plugins\twitchsw.dll)
CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
00000051F352FC40 00007FF9044E3B46 0000000000000000 00007FF9044E1A80 00000051F2594090 0000000000000000 twitchsw.dll!0x7ff9044e3b46
00000051F352FD60 00007FF91ABC2D92 00007FF91ABC2D70 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ff91abc2d92
00000051F352FD90 00007FF91B729F64 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ff91b729f64
A minidump was saved to C:\Users\ricca\AppData\Roaming\OBS\crashDumps\OBSCrashDump2015-09-22_6.dmp.
Base Address Module
Crash dump attached
  • OBSCrashDump2015-09-22_6.rar
Scacht
Once again (for EVERYONE), without copies of your current twitchsw.ini there isn't a whole bunch I can do to troubleshoot. I CANNOT reproduce crashes without config files, crash dumps, and dump logs.
Your DMP file was perfect and should be enough. I think I found your problem and I'll be updating the download in a couple minutes.
Scacht
Glad to see such a fast update! Crash issue solved here, thank you!
The "prompt to apply even if not changes" bug is still there unfortunately.
Yeah, that's a stupid problem I'll have to search through and find eventually, glad that fixed the crash at least.
Scacht
Found a case that Twitch won't update the stream title if the game is already launched when you start OBS/TwitchSwitcher. I'll fix it eventually, currently you just need to manually switch scenes once on initial startup for that case.
TLDR: Launch OBS/TwitchSwitcher before your Sources/Scenes.
Drow Arrow
nevermind it just happened again. I'd just got another OAuth key and when i hit Apply it threw up my original error.
Other information:
There are no rogue entries in the list.
