"The virtual camera is not installed" ???? Why
Mark Eisenman
How do I solve this problem please.
Running OBS 30.0 on a Mac OS 14.1.1
"The virtual camera is not installed.
Please allow OBS to install system software in System Settings → Privacy & Security → Security.
You may need to restart OBS if this message still appears afterward."
No matter what I have tried I get the same error message.
Of course, now OBS is not available as a source for ZOOM.
Any suggestions would be appreciated?
Mark Eisenman
THIS is solved. I had to make sure I was in PRIVACY settings to allow OBS to fully install.
procubate
HI. Glad you're solved, but I'm not seeing a menu called security in the Privacy and Security System settings on my macbook (Sonoma 14.2).
Also, what do you mean you had to be 'in Privacy settings to install OBS?'
Would be great to also understand the path/steps you took to solved it, as I'm having the same issue too.
Thank you!!!
procubate
OK. I've solved it too...
And here's how.
On the Privacy & Security section of the system settings, if you scroll down, you see a section called Security.
Because OBS needed extra permissions to what it already had, a button appeared called 'Details' in that Security section. By clicking on that 'Details' button you can see any apps that are blocked, which included OBS. Enabling OBS there then allowed the virtual camera to work as a webcam in Zoom. All up and running, and ready to broadcast!
I restarted OBS but am not sure if I needed to.
Hope this helps others who couldn't find the settings for the same issue which gave the message:
ccoscot
VISUALLY...this is what you are looking for:
Hermes1972
And here's how.
This solved the issue. The fix is tiny and easy to miss. Wow. Thank you.
jazzthis
What if you are not getting the "System Software from "OBS" was blocked from loading." option? I can start the virtual camera in 30.0.2 - which I keep so I can reinstall it after updating and trying the virtual camera - but as soon as I download and install 30.2 Beta the virtual camera goes away.
BoatBodger
I have a slight variant f this problem:
If I start OBS 30.2.2 on MAC without command line flags, I can then click 'Start Virtual Camera' and it starts.
If I start OBS from command line with the flag --startvirtualcam I get a modal dialog saying "The Virtual camera is not installed:
I do not see the 'details' button anywhere on the Security part of the Privacy & Security screen [I note that my mac mini has 'Privacy & Security" whilst others refer to it as "Security & Privacy" - different versions of MacOS perhaps?]
AaronD
I have no idea if this is even related, but on Linux (at the very least, Debian and its derivatives like Ubuntu), the camera loopback must be enabled as root, every time the system starts up. So until I added this in a startup script that runs as root (copy/pasted from OBS's source code), I had to type my password when I clicked the VCam button in OBS:
Bash:
modprobe v4l2loopback exclusive_caps=1 card_label='OBS Virtual Camera' video_nr=99
The only thing I changed from that copy/paste was video_nr=99, to keep it from rearranging the low-numbered automatic ones that correspond to physical captures. Now both the button and the startup flag "just work".
Again, I have no idea if it's even the same problem, but since Mac and Linux are somewhat similar under the hood, I thought I'd at least offer it as a remote possibility. The V4L2 part will certainly be different (Video for Linux, version 2), but maybe the concept is similar?
BoatBodger
Bash:
I suspect that's not related, but useful to know - thank you for posting.
My workaround (which may become permanent) is that my nodejs program now uses node-obs-websocket to issue a StartVirtualCam instruction. The only problem is that if the virtualcam is already running, this generates an (apparently) un-trappable error and blows my my node script. The reverse is also true. If the camera is stopped, and you issue a 'StopVirtualCam' command you get a similar error.
AaronD
...if the virtualcam is already running, this generates an (apparently) un-trappable error and blows my my node script. The reverse is also true. If the camera is stopped, and you issue a 'StopVirtualCam' command you get a similar error.
I wonder if the Advanced Scene Switcher plugin has the same problem. I don't think it does.
And likewise to stop it.
It's getting a bit Rube-Goldberg at this point, but if it works, it works! And maybe you can move a bunch more automation from the script into Adv. SS. It does a LOT!
BoatBodger
In the end, I simply added code to get the virtual camera status to determine whether or not to send a 'stop' or a 'start' command - this was only another handful of lines of nodejs, and is more easily understood by whichever poor mug gets to take this system over at some stage in the future!.
That said, I do appreicate your suggestions, and ASSw may well be useful for other things in the future.
I'm also not seeing OBS blocked:
is there a step-by-step workaround?
I am having the same problem. OBS is fully installed. I have granted all permissions. Restarted. When I click Start Virtual Camera, it tells OBS needs permission to install, when navigate to the System Preferences there is nothing being blocked. I have unblocked many programs before so I know what I am looking for. I am running on macOS 15.0 (24A335). Has anyone found a way to resolve this? Am I missing something?
bowensanders
Adding my name to the pile.
No blocking message appears in security (like other things have today, like opening a pkg that was unsigned.)
Might be worth noting that the OS version is sequoia 15.0
