Bug Report Suddenly No audio when recording
onyx1988
Attached some screenshots to help. Yeah I could record just the other day with audio and now suddenly it stopped working. I did nothing in the settings to cause it, just happened out of the blue. Other friends are having the same issue.
Did your system get a recent Windows update? Sometimes audio goes to crap (happens to me).
Go update your audio drivers from your motherboard manufacturer to see if it fixes problem.
Also, go to Windows Sound Panel and make sure:
1) The mic is enabled and is set to be the default recording device
2) The speakers are enabled and set to be the default playback device
3) Advanced settings are correct
Right click properties and check to see if the default format is set correctly in the Advanced tab for each device (channel, bitness, sampling rate)
Sometimes an update or even just a reboot can:
1) reset your system default audio device; if this happens and your old default was something else, or OBS was set to use "default" instead of a specific device, this can lead to no audio in OBS;
2) reset your audio devices to nonsense settings, such as 8hz mono, which will sound terrible.
Hi thanks for the replies
I tried these methods from narcogen and sukiyucky to no avail. Windows hadn't updated. I don't really know what to do and need other solutions please.
