Stream Timer Studio
Stream Timer Studio 1.0.0
MMLTech
MMLTech submitted a new resource:
Stream Timer Studio - A lightweight countup / countdown timer configurator for streaming (formerly known as obscountdown)
You can support this project
Stream Timer Studio is the successor to my old OBSCountdown configurator. Due to the huge accessibility of AI tools these days, the old configurator became somewhat irrelevant, but just for the sake of it, I decided to give it a complete facelift.
During the past 6 months, all donations made...
MMLTech updated Stream Timer Studio with a new update entry:
Improve timer configurator SEO, preview, fonts, and layout stability
- add countup-from-zero mode to the configurator and generated timer runtime
- expand the Google font catalog and update font loading/weight support
- replace the split font search/select with a single searchable custom font picker
- add configurable urgency color support
- fix last-10-seconds color shift and last-5-seconds shake behavior, including duration mode
- fix preview background rendering for transparent/dark/light/scene modes inside the iframe
- make timer digit blocks fixed-width...
Stream Timer Studio Client Changelog
  • Completely removed all AdMaven advertising and related pop-ups.
  • Redesigned the homepage with a cleaner, more modern appearance.
  • Added clearer messaging explaining what the timer tool does.
  • Improved navigation between the timer builder and setup guide.
  • Made the timer creation process easier to understand for new users.
  • Improved the experience on phones, tablets, and smaller screens.
  • Added clearer calls to action and feature explanations.
  • Made the OBS setup...
