I'll check how it works on Android, when will find it :)Thanks for your reply.
it seems to work on iPhone but not Android :(
thanks!!, hopefully you can figure it out for Android, then I can test it. :)I'll check how it works on Android, when will find it :)
So far I have fixed the display of the background and the bottom status bar.
HiHi Kopsap4ik
I found this Plugin and must say really nice Work.
And i want it to use it, but the Login Function dont work. I dont receive any mail.
Also i tested the Championship Logo function. But i dont see the Logo anywhere.
Also is it possible to edit the part time text. f.e. hockey 1st Period, 2nd Period, soccer 1st Half, 2nd Half?
What do you planning for the future. I'am very Interested into it.
Do you need some help for Programming? I dont be the best in programming, but i want to learn, and maybe i can help you.
I'll think about how this can be added to the scoreboard.Can there be an "F" or "Final" added to the scoreboard to change it to once the games end? Otherwise, it is great love it!!!
Describe in more detail about timeouts.Please Add timeouts for Football, basket, hoquei!
If possible baseball score
And everything worked great!
Hello. Recently made changes. Try registering again. Please report the problem in more detail if you are unable to register again.++++
Hello. Recently made changes. Try registering again. Please report the problem in more detail if you are unable to register again.I like the demo, unfortunately the registration does not work.
That’s a great suggestion! Updating team names functionality to allow batch uploads from a file and quick selection via dropdown could streamline the process and reduce spelling errors. I’ll pass this idea along to the development team for consideration!Would it be possible to update the way team names function.
I would love to be able to feed a bunch of teams in a file and be able to chose them from a dropdown for quick switches and minimizing the chance of a spelling error e ss
