PTZ Controls
PTZ Controls v0.19.0
Aside from the plugin not loading, I don't see any error messages. Most failures I've seen so far give an error message. In your log I only see a message that the plugin wasn't loaded. Can you send a screenshot of the plugin manager? (Tools->Plugin Manager)
What version of PTZ Controls did you install?
Using latest version 0.1.8
obs-ptz-0.18.0-windows-x64-Installer.exe
Testing in OBS 31.1.1 with a Sony SRG-X120 and CH Products Desktop controller. The plugin picked up both the camera and controller with no problems and controls the camera's presets great! I did run into a couple of issues that I'm hoping is just a configuration error on my part. Thanks in advance for any help provided.
  • PTZ Controls is not seeing the Z-axis (Zoom) (Axis 2) movement of the joystick. Only the X & Y axis. Zoom does work if I set a couple of the preset buttons on the joystick to Zoom In & Zoom Out.
  • If a setting is selected on the preset buttons the plugin will not allow you to go back to None.
I have this same problem. Using a CH joystick as well and I can't get any of my PTZ camera's whether its IP or USB to recognize the z axis for zoom. Also have the same issues for the buttons not going to NONE option as well.
Specifically, I'm using an Aver CAM540 which is USB but also one of my Illustra IP cameras has the same issue.
I have the same issue. Windows can see all buttons and X, Y, Z axis. PTZ contols does not respond to the Z axis. Tried this on CH joystick and also Axis joystick.
Also same issue with button mapping - can not set it back to None after it gets programmed.
Also if I map Zoom In and Zoom Out to buttons, holding them down will Zoom a little bit, then will stop. It does not stay continuous when the button is continuosly held down.
Hi,
thank you for this plugin and the recent updats (that finally fixed the VISCA serial bug). Now all our cameras can be operated from OBS!
But there's always room for improvement. :D
We already use the PTZ Action object to recall a preset for a specific scene. Would it be possible to add new functions to this object?
Specifically, I'd like to be able to power on and power off our Sony network camera (VISCA UDP) with specific scenes. There is a lua script based plugin that in theory supports that feature but I wasn't able to get it to work with our camera and I don't want to manage two different plugins.
@glikely, thx for your support and all effort with this amazing plugin!!! I need some help here, please.
I'm testing the upgrade to OBS 31.1.2 and obs-ptz to 0.18.2 but got a problem with the update files still showing v0.17.0.
As you can see, I confirmed the sha256 of the zip from github and it's equal. I use OBS on portable mode, but also tried using the installer and copying the files from the 'C:\ProgramData\obs-studio' path to the OBS folder I use but still no success.
Please, let me know if you need me to do anything different or collect other evidences
Thanks in advance!
Is there a possible trick to run multiple instances of PTZ controls in a single OBS instance?
I have 3 Fomako cameras, I'd like to a dedicated control for each camera docked so users dont need to select the camera they want to move and instead just click on one of the 3 control instances to move the camera.
(or is there another way?) basically I'd like this picture, where the control could be docked under the specific camera it could manage.
I am using an OBSBot Tiny 2 Lite camera. This plugin is working well using a USB Camera (UVC) connection.
I am only seeing one tiny issue. The PAN and TILT don't seem to be entirely accurate.
For example, if I pan as far to the right or left as the plugin will allow me, I can then go into the OBSBOT Control Center, and pan 10-15 degrees more, either direction.
And tilt works similarly, but let's say I want to TILT down all the way. It will go to a certain point, and then start tilting back up. And vice versa for the other way. But I can still tilt as far as the plugin will allow me, and then go into the OBSBOT Control center again, and get 20 or so more degrees.
I also tried using the OBSBot software to position where I wanted the camera, and then saving the preset in the plugin. It will take the position back to its limits. Not the cameras limits.
hi all. I've noticed that during the various updates at some point all the icons on the PTZ controls got smaller. Don't know if it's a matter of OBS itself or the plugin. Got OBS 32 with default "appearance" settings. Don't matter how I arrange the docks, they are always, with little variations, much smaller than the container button. On the previous versions they were much bigger. Any solution? Thank you.
Issues with PTZ Controls in OBS "Portable Mode"...
Developers (or Power Users) -- anyone know how to get PTZ Controls to work properly when portable mode is enabled on OBS? I have everything setup in PTZ Controls as I want it on "normal" OBS mode, but no matter what I do to consolidate everything in OBS "portable mode" for easy backup of my entire instance of OBS - program, scenes, profiles, plugins, media, etc. - PTZ Controls just disappears. I've tried copying the plugin binaries into various plugin folders in the OBS "portable mode" file structure that is created to no avail. Anyone have any inputs? Or is the PTZ Controls plugin just not set up to be "portable mode" compatible?
Thanks in advance,
Teeter
i had same experience. Moved OBS to another setup. All went flawless, only PTZ controls settings were all lost. May be the settings of PTZ controls are not stored in the right place for portability ?
Let me be clear, for me it was a little thing. Besides this i am very glad to have PTZ controls. Together with the use of gstreamer and a lot of 'cheap' Hikvision PTZ cams we built a very cost effective setup for streaming from our church wit cams in very decent 1080p quality.....
Is there any resource that can tell me what camera control configuration to use? I've never got this to work as the terms in the plugin don't match anything I can find in my camera configuration. I'm using Hikvision PTZ camera, and it's using TCP over Ethernet. I can see the proper preview in the PTZ Controls dock, but nothing ever moves.
How do I determine the correct "TCP Port"? I've got HTTP port, RTSP, HTTPS, Server port, and Enhanced SDK Service Port.
Do I need to restart PTZ Controls or OBS for a new port to connect properly? The camera has a username/password, how do I log in with this plugin, or do I need to?
Thanks
[edited screenshot]
Hi, since updating to OBS 32.0.4 I keep getting OBS PTZ cntrols plugin failed to load - update or delete to continue. I have updated numerous times but I continue to get the error message. Has anybody else had this issue? Is there a fix please? Thanks in advance
Can you please tell me if there is a way to fine tune the movements?
I am using an OSBBOT tiny4k in our church. the issue I am having is that the camera is not centered on various places. having a way to fine tune the movements would sure be helpful - to allow the user to set the camera on a fixed point - no matter where it is in the operational field.
so i HAD that problem as well, BUT here is what I did to solve it
I was trying to use OBS on a network drive, this plugin HAS to be installed on the C drive (windows) - more specifically
c:\ProgramData\obs-studio\plugins\obs-ptz
all i did was extract the files from the installer and physically put them in the above directory.
then relaunched OBS opened the DOCKS dropdowm - and there it was (PTZ controls)
what clued me in
look in the TOOLS dropdown menu
find the tool called Plugin Manager
this tool is VERY helpful in troubleshooting stubborn plugins as it will show you IF OBS is trying to load a plugin and if it was successful. if it is greyed out, it failed BUT OBS tried.
