Preview Media source in Multi-view
DavidCoq
Hi,
I need to use Media Source via Multi-view mode, but for this type, there is no preview, making it difficult to select the correct media.
The only solution I found is to place the first frame of the video below the video layer, but it's not an optimal solution.
Do you have any better ideas?
Select not first but most memorable frame for background.
Only VLC Video Source (you need VLC player installed) has option to always play media (even when source is not shown).
I tried to do as you said, but with poor results.
I'm leaving a video to show you what I would like to do.
OK. Make meaningful thumbnail from your video and place it as image below media source in OBS. It is best solution here.
