OpenVR-Capture
OpenVR-Capture v1.8.4
gdx65
I have copied the plugin files in the OBS directory (C:\Program Files\obs-studio) but it does not work. I have tried to copy them into the obs-plugin directory (C:\Program Files\obs-studio\obs-plugins) and now I can see the option to use OpenVR-Capture ,can choose it from the Sources menu, but it crashes... which is the correct directory?
ddfracer
Fantastic plugin, thanks for your work! I'm using it to record footage from RaceRoom and iRacing and it provides a significantly better view than their default mirrors. These crop the image far too much on my Pimax Crystal Light and make the pixelation quite obvious. However, there is a downside in that the plugin also captures any pinned windows I have inside the headset, such as my live stream chat and in-car telemetry via Open Kneeboard.
Is there any way of getting this plugin to record only the game layer and not any additional layers composited on top of it? Or is this plugin only able to take the VR image as a whole?
Many thanks in advance for anyone who might be able to solve this one.
pigney
Unfortunately OpenVR's API doesn't provide direct access to the game image before overlays are rendered so this isnt possible.
HeizOff
Hi, i have a question. Is it possible to add a setting to capture VR with both eye where one is dominant (like in SteamVR View)?
If it possible i will be very glad to see this function in next update. ANW thx for this plugin)
pigney
This can be achieved using two OpenVR sources and Advanced Masks to blend them together
HeizOff
Does this affect performance a lot?
Persvicx
Unfortunately creating 2 eyes crashes OBS. Sad cause I wanted to record full res both eyes combined...
  • Crash 2025-07-18 00-25-33.txt
OssianTT
Got a problem with V1.8.4, if i add both eyes as sources (one source for each eye), OBS crashes whenever i try to show both sources at once. In original version made by Keijo i'm able to do this just fine.
techfreak13
Hey man, just want to say thanks a lot for this plugin this is just amazing much better quality than just recording SteamVR View. Thank you for creating this plugin.
Do let us know if there is any way we can donate to you as this plugin is amazing.
pigney
This is a side-project i work on from time to time since nothing else had the functionality i needed, no need for donations :)
