Resource icon
obs-text-slideshow v2.0.0-alpha
briand123
The is a great plugin that I am using for changing text on a lower third on a long-duration live stream. I'm loading lines to display from a file. A very useful feature add would be an option to have the plugin check when a file containing the slides has changed and automatically reload it. Is this something you could add? Thank you for a great plugin.
Hi, I'm gradually fixing the text of previous localization plugins.
I've finished re-localizing the plugin, changing a lot of errors caused by machine translation.
I found a bug, if you continue to update this plugin, please fix it in the next version!
Slideshow.ReadFromMultipleFiles This line of localization definition may not be implemented in the code of the source project, I can't change it by localizing the text.
I have adapted the localization file to version 2.0.0.
  • zh-CN.rar
