OBS SceneTransition
pitchatan
nice job, if possible i would like you to enable access to the webserver as it is currently only accessible on http://localhost
Reason, i have modified obs remote to send a get request to the trigger url and i would like for it to be accessible by ther computers in the network/outside my network.
MrSpectacle
This was good at first, but I never got it "triggering" slide transitions, even though I was able to trigger it manually by going to the trigger location directly. Now, a day later I'm trying to test it out and the OBSSceneTransition won't open the UI at all. It goes into the task manager, it goes into the details (Windows 8) but the "UI" won't open.
I've attempted a clean install of OBS with only OBSSceneTransition installed as a plugin clean even to see if that's the case, but the UI is now "gone".
I've noticed this happens on occasion, killing the application through the task manager then reopening it should work. At least it does for me. Seems the be an issue with node-webkit loading the application - not running win.show();
MrSpectacle
I will look into adding this feature in a future update.
Kenko
OBS crashes on startup after installing the modified sceneswitcher, both on 32 and 64-bit.
I tried running as administrator, and I made sure scenetransition was open when I opened OBS.
I also tried reinstalling, but it didn't work.
EdgyRetard
I really need help, I think I installed and setup everything the way it's supposed to be but I can't get the transitions to work. I have no crashes, no error report or anything, scene switcher shows up in OBS and I set up the scenes it's supposed to work for and the settings in SceneTransition work fine, I just can't get the transitions to take effect at all and I have no idea why. I guess I can't get the trigger to work
Kenko
I got OBS to start, but the modified sceneswitcher doesn't work
(the unmodified sceneswitcher works fine)
Katheryn
For people who are having problems
  1. Make sure you replace scenesw.dll
  2. Open OBS SceneSwitcher
  3. Open OBS
  4. Click Plugins --> Click OBS Scene Switcher --> Click Configure --> Setup your windows here
  5. Make http://localhost:3000/transitions/ into global source and make dimensions match your screen
  6. Make http://localhost:3000/transitions/trigger into global source and make dimensions match your screen
  7. Add both of new global sources to your scenes.
  8. Turn SceneSwitcher on by clicking on it in the menu
  9. Now it should work.
Carousel
  3. Open OBS
4. Where's PLUGINS button in OBS?
Even following the instructions I have following problem.
OBS SceneTransition UI sometimes doesn't open. Running it with administrative rights helps. OBS itself crashes each time I use the plugin.
RADRaze2KX
Works beautifully so far... I stream a lot of phone games, so there's no way to scene transition when I'm broadcasting a video source from my phone directly into OBS using Source Plugin...
I've created a jankey solution in the form of a web-browser that changes it's title to trigger the scene switcher transition manually...
You'll need to set up two identical scenes and use this HTML file as the "Window Title to Check for"... It starts out on a neutral title... click the button on the page and detect that as window title 1 ... add the information you need to the Scene Switcher config... click the button on the page again and re-detect it as window title 2... add t he information you need to the Scene Switcher config again, then click "OK" ... test it...
  • Scene Switcher - Manual.zip
