OBS daily reset - disconnect from Twitch
nahtagain
Hello -
I've had this problem for several months now, my stream disconnects from Twitch daily around 11:15am and I have tried MANY solutions like:
- Uninstalling OBS and removing all files, re-installing OBS (this worked for exactly One (1) day)
- Switching to a stream key to connect
- Changed servers and then changed back again
- Deleted the obs_profile_cookies folder
- Disconnected OBS from Twitch's end and re-connected it
I even switched to Streamlabs for a day and it DID NOT disconnect then but I really hate streamlabs.
The only solution when it ends stream and gives me the same error pop up (see attached image), is to disconnect OBS from my Twitch account and re-log back in and then start stream again.
I'm attaching some logs here; the analyzer says everything is fine but I'd love to know if there's some other issue deep down.
When I first started streaming today: https://obsproject.com/tools/analyzer?log_url=https://obsproject.com/logs/mByBjjPyXtlMtIOa#logURL
After it broke and I re-signed back in: https://obsproject.com/tools/analyzer?log_url=https://obsproject.com/logs/2Ql4ZIVhu7faSFif#logURL
After I had to close and reopen OBS (current log while posting this): https://obsproject.com/tools/analyzer?log_url=https://obsproject.com/logs/NQUtZ7aaukqOYXlq#logURL
Thanks for all your help, please please let me know if there's a solution because this is very frustrating.
Literally going through the same thing and I have no idea why. At first I thought cause I switch ISP but everything fine in their end as well as twitch so I have no clue what do. And no one has an answer. I’ve uninstall and every thing aswell it’s so weird.
