Muted Notification
Muted Notification 1.0.2
univrsal
universallp submitted a new resource:
Muted Notification - Get an audio notification when talking while muted
Adds an audio filter, which will play a wav file if the parent source receives audio while muted:
The filter works exactly like the noise gate, but instead of opening the gate it'll play the selected WAV file to the selected playback device. The cool down defines how much time has to pass before the sound is played again.
Installation
On Windows you can use either the installer or manually extract the binaries to your obs directory.
On Debian based...
Hi universallp,
I visited your git repository. I am thinking to package this plugin for Debian. What you think about to change all names 'U r muted' or 'urmuted to 'muted-notification' and 'Muted Notification' in source code? I think it is a bit confuse to keep two different names (a name here and other in source code). For me, urmuted is not intuitive too.
Thanks for your attention and work.
Hey, very handy plugin cheers. Just having an issue with the 'Device' selection, no matter what I selet, the audio is always coming through my headphones/desktop audio.
Hi universallp,
Sorry for the late reply, I randomly don't get notifications for threads for some reason. I can change the names.
Hey, very handy plugin cheers. Just having an issue with the 'Device' selection, no matter what I select in the dropdown menu, the audio is always coming through my headphones/desktop audio.
Can you post your obs studio log after changing the audio device?
The log is showing the change, although it doesn't apply the change:
22:12:51.152: [urmuted] Opened 'Headphones Rear (Realtek High Definition Audio)'
22:13:01.926: [urmuted] Opened 'Headphones Front (Realtek High Definition Audio)'
Here's a little more (Covering all the urmuted plugin specifics:
20:47:38.436: Failed to load 'en-GB' text for module: 'urmuted.dll'
20:47:38.436: [urmuted] plugin loaded successfully (version 1.0.0)
20:47:38.483: Loaded Modules:
20:47:38.483: urmuted.dll
20:47:38.854: [urmuted] Opened 'Headphones Front (Realtek High Definition Audio)'
20:47:39.048: [Loaded global audio device]: 'Mic/Aux'
20:47:39.048: - filter: 'U r muted' (muted_filter)
HERE IS WHERE I CHANGED THE OUTPUT DEVICE
21:54:19.259: [urmuted] Opened 'Headphones Rear (Realtek High Definition Audio)'
21:54:35.100: [urmuted] Opened 'Headphones Front (Realtek High Definition Audio)'
After this I 'did' add an en-GB text file (Copied the en-US), but obviously it's nothing to do with that.
I can test/log more if needed.
Pic of my devices attached, none of which make any difference. The muted sound just always comes through whatever my currently default output device is set to in WIN10.
Try this release:
Works really well!
Dunno if its possible but having it play a folder of different .wav files randomly would be kinda cool to have. Like if it was possible to put 5 .wav sound files in there and then it would randomly play whichever. Just thought it be fun for a livestream etc.
Eitherway it works super well and thanks for the plugin.
Used to be great a few months ago, now I can't get it to work at all.
Solved, my bad understanding, did not figure that closing the audio source eye within a scene won't trigger the plugin. Once I muted it in the audio mixer, it went fine. Very nice solution for someone like me, that forgets the mic is muted all the time. Than you, univrsal.
Cool little update with the visual indicator.
I thought there was an issue at first with the indicator showing on different monitors if the audio notification was also seleted. Then I realised the indicator image shows on whicever screen the mouse is. Good stuff.
Would be nice if we could adjust horizontal positioning. (Triple screen/NVIDIA Surround +4th screen user) but not really needed TBH. I'm running the indicator size at 250 haha.
Hey! Is there a way for it to work even if the source is not on mute? It would help me a lot to be notified if the lavalier microphone runs out of battery and stops transmitting sound.
