MIDIControl - Control OBS, Soundboard, Twitch chat with MIDI Devices
Free MIDIControl - Control OBS, Soundboard, Twitch chat with MIDI Devices 2.0.1.0
BelloTheKid
So I have tested the new Version and the Software is running very stable again thx for the fix! In the beginning I had a hard time understanding how to use the 'FilterLog.log' but now I understood and it works as well! The only thing I missed was that the 'filterminmax.csv' need to be placed inside "%AppData%\MIDIControl" as well. Before I edited the 'filterminmax.csv' which is automatically created in the Installdirectory and MIDIControl wouldn't recognize the changes.
Maybe this is due to the fact that I installed MIDIControl to a different Disk than "C:"
Anyhow, now your tool is honestly the most potent and useful tool there is for OBS and if you are ok with it I will make a Video Presentation or some How To Clips on how to utilize MIDIControl. (I don't think there are any yet?)
Best Wishes,
Bello
Etuldan
In previous version, it was install indeed in the InstallDirectory, but I switched to %AppData% since new version (as user may modify it, without UAC prompt)
Of course, you're welcome ! Feel free to drop the link here !
chriguch
That are the Monitor-Events from MIDI-OX
BramstokerD
I got some light on the original launchpad, if i press the learn view, page, etc circular buttons the right circular buttons will light, and on the sqare buttons looks like it´s going to work but if i put another action i will get this, i´m only able to use one button on the new update
Etuldan
Make sure to name the keybind differently from an other already existing one
MattRigg
Is it possible to implement a feature whereby buttons need to be pressed and held (for a couple of seconds) before they activate?
My fat fingers have, on more than one occasion, caused me to accidentally stop a stream because I caught the start/stop button.
Ronaldobc
Hi, MidiControl is really very powerful and the possibilities are almost endless. But I'm having trouble configuring the Lower Thirds through it. As I understand it, it would be for HotKeys, but it's not working. Would anyone know what is the correct way? Thanks.
Etuldan
You have to setup Animated Lower Thirds by enabling the "brower source", the "control panel" and the lua script.
I recommend you to read the README.md of Animated-Lower-Thirds
Ronaldobc
yes, everything is installed. I watched several tutorials on youtube demonstrating. In OBS, Lower Third works correctly, the issue is in the “communication” with MidiControl. Because the other functions such as changing the scene, playing the media, etc., MidiControl performs faithfully.
Paul G
Hello. I was just about to upgrade to latest version but I wanted to ask - should I uninstall the current version first? How can I save or retain the the note configs I have now?
Thanks for a GREAT Program!
Etuldan
Unless you upgrade from a very old version, just install over it, and it should work.
Config files are in %AppData%\MIDIControl
Paul G
I can't get a handle on the separate Profile Feature. I checked the Profile .ini(s) in both folders and there is only one Note Off triggered scene listed.
Do we have to Delete and Start Over with each Profile?
Please advise.
Paul G
OK - moving forward slowly - Save Icon does nothing. ENTER Key Return starts New EMPTY Profile
Love this program!
