Media Controls
Media Controls 0.4.1
Hi Exeldro, Un fortunately it still doesn't show up on my Mac. Perhaps you have made it for Catalina? I have High Sierra. Thank You for your on-going effort though. I've installed other of your resources and they are working great! Thank You!
joechihe
Amazin pluging, the missing piece we needed for OBS since a long time ago. Kudos to Exeldro!
I'm using it in OBS 25.0.8 in macOS Catalina and works like a charm
istorar
Hi, I'm having some trouble getting this to work on Linux. Extracted the files to .config>obsstudio>plugin_config, but it's not showing up as a dock option. Any help would be v appreciated!
OBSnewguy
Apparently, it is written for Unbuntu; it does not work for Debian 9. I tried it.
JVRaines
This control should be part of the standard distro! Absolutely necessary to have control over media playback.
One bug I am experiencing with 2.2 is that a hotkey assigned to play the media source doesn't work. The Media Control's PLAY button changes to PAUSE, but there is no playback and no movement of the cursor.
OBSnewguy
I don't see a /plugins/ folder, just /plugin_config/
And I've read those posts, was confused because I couldn't find that folder
Go to:
~/.config/obs-studio/
Create directory:
/plugins/
Copy the folder 'media-controls' into the /plugins/ directory.
End result:
~/.config/obs-studio/plugins/media-controls
Restart OBS-Studio
istorar
Go to:
Create directory:
/plugins/
End result:
Restart OBS-Studio
Ohhhh okay thanks friend it's working now :)
alexslx
Hi,
I would like to be able to set hotkeys to fast-forward (150%) or fast-backward (50%) some media sources. Do you think it would be possible to include in this plugin?
Exeldro
@alexslx the speed of a media source can not be controlled in the same manner as the functions this plugin. So it would need to be done with an other plugin or lua script.
alexslx
Hi, thanks for the response. That is unfortunately. I tried to do that using lua scripts but it doesn't seems to be able without restarting the media source every call to update settings.
I was trying to use that to control a media source so I can comment on it, go back or forward, slower some important parts... you got the idea.
VA Tech Support
Thank you for this amazing plug-in which solves a big gap in OBS Media Source controls.
I am experiencing the Mac crash bug which comes up when removing videos from a scene as described in this issue log: https://github.com/exeldro/obs-media-controls/issues/10
The other trouble is that it appears to wipe out all profile configurations when the crash occurs and OBS restarts.
Just wanted to check to see if this was on your radar to fix and any time estimates for resolution so we can plan accordingly?
Thank you again for your efforts in this awesome development.
Exeldro
The crash should be fixed with OBS version 26. Can you test if the release candidate of OBS fixes it?
VA Tech Support
It looks like the Media Controls are built right in to OBS version 26, which is awesome to see.
Deleting Media Source from Scenes doesn't crash OBS anymore, as long as the separate Media Controls plug-in isn't installed.
Thank you again for your contributions to this incredible project.
