Maidsuit: Draw
Maidsuit: Draw 1.2.1
hi maidsuit
just want to ask if theirs a zip file for your plug-in ? at the moment im currently using a portable version of obs
thanks
maidsuit updated Maidsuit: Draw with a new update entry:
Color Picker, Selection Tools, and Saving Layers
View the update trailer video here:
  • Color picker now added! Find it under the color selection area.
  • Shift press the color picker, or right click the color picker to select the "Pick Directly" color picker, accounts for screen preview and what youre actually visually seeing.
  • Box select, Lasso Select, and Circle select has now been added
  • Select multiple layers with Shift or Control select
  • Save selected layers as flattened PNG &...
