Is it normal that HDR looks "washed out" (as if the brightness is set too high) when viewing OBS Preview on a monitor with Windows HDR enabled?
I use PC to PC recording, two monitors of the exact same HDR-enabled model. I have Game-PC playing on one monitor with DP output from GPU and a HDMI out from Game-PC GPU plugged into the Input I/O of the Capture Card on my Record-PC. I use OBS Source Projector to project what I am playing on "Identity 1" display to the "Identity 2" display, which is actually the Capture Card detected as another Display in Windows Display Settings. Everything works fine but with my setup I can See OBS' Preview(Capture Card aka Identity 2) to my Side, capturing what I am seeing in front of me on the Identity 1 Display. So I can easily compare and notice that OBS shows a "Washed out" preview compared to what I am seeing on the monitor I have in Front of me.
Is it Normal that the OBS Preview looks washed out? Source is HDR since I am playing with HDR enabled and that gets recorded by OBS on the Record-PC.
I have to assume its normal, but it looks "washed out" because I am directly comparing HDR to SDR, right ? someone viewing my recording wont notice the "Washed out" colors because they dont have the HDR source to compare to. Am I correct in my thinking of this scenario or is this a REAL "Washed out" colors Issue.
I have been using a Color Correction Filter to get OBS to look identical to what I see on Display 1, but I get the feeling this is an Incorrect use of color correcting. am I shooting myself in the foot here by fiddling with colors of my recording and just making it worse for people viewing the Final SDR output, because it does look a bit "off" when I replay the mkv/mp4 via Media Player Classic. But I just chalked that up to the fact that OBS doesnt record HDR.
