DroidCam OBS Camera
DroidCam OBS Camera 2.4.0
Razorflak
Hi @dev47,
First of all, thank you for your app! I've been using it for a while, and it's awesome.
For an event, I need to use the audio feature with the cam for the first time.
However, when I enable the option, OBS crashes immediately after I press "Activate."
I tried with two different phones, but I got the same result.
Here are the OBS logs: the first activation is without audio, and the second one is with audio.
16:00:53.589: Using EGL/X11
16:00:53.589: CPU Name: AMD Ryzen 5 4600H with Radeon Graphics
16:00:53.589: CPU Speed: 1763.207MHz
16:00:53.589: Physical Cores: 6, Logical Cores: 12
16:00:53.589: Physical Memory: 15354MB Total, 7392MB Free
16:00:53.589: Kernel Version: Linux 6.8.0-50-generic
16:00:53.589: Distribution: "Ubuntu" "22.04"
16:00:53.589: Desktop Environment: ubuntu:GNOME (ubuntu)
16:00:53.589: Session Type: x11
16:00:53.589: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.21.1
16:00:53.604: Qt Version: 6.2.4 (runtime), 6.2.4 (compiled)
16:00:53.604: Portable mode: false
16:00:53.639: OBS 30.2.3 (linux)
16:00:53.639: ---------------------------------
16:00:53.731: ---------------------------------
16:00:53.731: audio settings reset:
16:00:53.731:     samples per sec: 48000
16:00:53.731:     speakers:        2
16:00:53.731:     max buffering:   960 milliseconds
16:00:53.731:     buffering type:  dynamically increasing
16:00:53.732: ---------------------------------
16:00:53.732: Initializing OpenGL...
16:00:53.777: Loading up OpenGL on adapter AMD RENOIR (renoir, LLVM 15.0.7, DRM 3.57, 6.8.0-50-generic)
16:00:53.777: OpenGL loaded successfully, version 4.6 (Core Profile) Mesa 23.2.1-1ubuntu3.1~22.04.3, shading language 4.60
16:00:53.811: ---------------------------------
16:00:53.811: video settings reset:
16:00:53.811:     base resolution:   1920x1080
16:00:53.811:     output resolution: 1920x1080
16:00:53.811:     downscale filter:  Bicubic
16:00:53.811:     fps:               30/1
16:00:53.811:     format:            NV12
16:00:53.811:     YUV mode:          Rec. 709/Partial
16:00:53.812: NV12 texture support enabled
16:00:53.812: P010 texture support not available
16:00:53.815: Audio monitoring device:
16:00:53.815:     name: Par défaut
16:00:53.815:     id: default
16:00:53.815: ---------------------------------
16:00:53.836: No AJA devices found, skipping loading AJA UI plugin
16:00:53.836: Failed to initialize module 'aja-output-ui.so'
16:00:53.851: No AJA devices found, skipping loading AJA plugin
16:00:53.851: Failed to initialize module 'aja.so'
16:00:53.862: Failed to load 'en-US' text for module: 'decklink-captions.so'
16:00:53.874: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
16:00:53.891: A DeckLink iterator could not be created.  The DeckLink drivers may not be installed
16:00:53.891: Failed to initialize module 'decklink.so'
16:00:54.185: [pipewire] Available capture sources:
16:00:54.185: [pipewire]     - Monitor source
16:00:54.185: [pipewire]     - Window source
16:00:54.251: [obs-browser]: Version 2.23.6
16:00:54.251: [obs-browser]: CEF Version 103.0.5060.134 (runtime), 103.0.0-5060-shared-textures.2594+g17f8588+chromium-103.0.5060.134 (compiled)
16:00:54.319: os_dlopen(libnvidia-encode.so.1->libnvidia-encode.so.1): libnvidia-encode.so.1: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce nom
16:00:54.319:
16:00:54.332: VAAPI: API version 1.14
16:00:54.336: FFmpeg VAAPI H264 encoding supported
16:00:54.336: FFmpeg VAAPI AV1 encoding not supported
16:00:54.353: FFmpeg VAAPI HEVC encoding supported
16:00:54.533: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.5.2 | RPC Version: 1)
16:00:54.533: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.2.4 | Qt version (run-time): 6.2.4
16:00:54.533: [obs-websocket] [obs_module_load] Linked ASIO Version: 101801
16:00:54.548: [obs-websocket] [obs_module_load] Module loaded.
16:00:54.653: [vlc-video]: VLC 3.0.16 Vetinari found, VLC video source enabled
16:00:54.706: [obs-teleport] version: 0.7.2
16:00:54.706: ---------------------------------
16:00:54.706:   Loaded Modules:
16:00:54.707:     obs-teleport.so
16:00:54.707:     droidcam-obs.so
16:00:54.707:     vlc-video.so
16:00:54.707:     text-freetype2.so
16:00:54.707:     rtmp-services.so
16:00:54.707:     obs-x264.so
16:00:54.707:     obs-websocket.so
16:00:54.707:     obs-vst.so
16:00:54.707:     obs-transitions.so
16:00:54.707:     obs-qsv11.so
16:00:54.707:     obs-outputs.so
16:00:54.707:     obs-libfdk.so
16:00:54.707:     obs-filters.so
16:00:54.707:     obs-ffmpeg.so
16:00:54.707:     obs-browser.so
16:00:54.707:     linux-v4l2.so
16:00:54.707:     linux-pulseaudio.so
16:00:54.707:     linux-pipewire.so
16:00:54.707:     linux-jack.so
16:00:54.707:     linux-capture.so
16:00:54.707:     linux-alsa.so
16:00:54.707:     image-source.so
16:00:54.707:     frontend-tools.so
16:00:54.707:     decklink-output-ui.so
16:00:54.707:     decklink-captions.so
16:00:54.707: ---------------------------------
16:00:54.707: Available Encoders:
16:00:54.707:   Video Encoders:
16:00:54.707:     - ffmpeg_aom_av1 (AOM AV1)
16:00:54.707:     - ffmpeg_vaapi_tex (FFmpeg VAAPI H.264)
16:00:54.707:     - hevc_ffmpeg_vaapi_tex (FFmpeg VAAPI HEVC)
16:00:54.707:     - obs_x264 (x264)
16:00:54.707:   Audio Encoders:
16:00:54.707:     - ffmpeg_aac (FFmpeg AAC)
16:00:54.707:     - ffmpeg_opus (FFmpeg Opus)
16:00:54.707:     - ffmpeg_pcm_s16le (FFmpeg PCM (16-bit))
16:00:54.707:     - ffmpeg_pcm_s24le (FFmpeg PCM (24-bit))
16:00:54.707:     - ffmpeg_pcm_f32le (FFmpeg PCM (32-bit float))
16:00:54.707:     - ffmpeg_alac (FFmpeg ALAC (24-bit))
16:00:54.707:     - ffmpeg_flac (FFmpeg FLAC (16-bit))
16:00:54.707:     - libfdk_aac (libfdk AAC)
16:00:54.707: ==== Startup complete ===============================================
16:00:54.755: All scene data cleared
16:00:54.756: ------------------------------------------------
16:00:54.759: pulse-input: Server name: 'pulseaudio 15.99.1'
16:00:54.763: pulse-input: Audio format: s16le, 44100 Hz, 2 channels
16:00:54.764: pulse-input: Started recording from 'alsa_output.pci-0000_04_00.6.analog-stereo.monitor' (default)
16:00:54.764: [Loaded global audio device]: 'Audio du bureau'
16:00:54.823: pulse-input: Server name: 'pulseaudio 15.99.1'
16:00:54.823: pulse-input: Audio format: s16le, 44100 Hz, 2 channels
16:00:54.823: pulse-input: Started recording from 'alsa_input.pci-0000_04_00.6.analog-stereo' (default)
16:00:54.824: [Loaded global audio device]: 'Mic/Aux'
16:00:54.837: [DroidCamOBS] Source: "DroidCam OBS" - 233
16:00:54.837: [DroidCamOBS] checking adb
16:00:55.039: [DroidCamOBS] "adb version" exit value 2
16:00:55.040: [DroidCamOBS] checking /usr/local/bin/adb
16:00:55.040: [DroidCamOBS] checking /usr/bin/adb
16:00:55.040: [DroidCamOBS] checking /bin/adb
16:00:55.040: [DroidCamOBS] adb not found
16:00:55.040: [DroidCamOBS] PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin
16:00:55.040: [DroidCamOBS] activated=0, deactivateWNS=0, is_showing=0, enable_audio=0
16:00:55.040: [DroidCamOBS] video_format=avc video_resolution=2560x1440
16:00:55.040: [DroidCamOBS] video_thread start
16:00:55.040: [DroidCamOBS] video_decode_thread start
16:00:55.040: [DroidCamOBS] audio_thread start
16:00:55.043: Switched to scene 'Test'
16:00:55.043: ------------------------------------------------
16:00:55.043: Loaded scenes:
16:00:55.043: - scene 'Scène':
16:00:55.043:     - source: 'Teleport' (teleport-source)
16:00:55.043: - scene 'Test':
16:00:55.043:     - source: 'Source vidéo VLC' (vlc_source)
16:00:55.043:     - source: 'DroidCam OBS' (droidcam_obs)
16:01:05.545: [DroidCamOBS] target IP is empty
16:01:10.146: [DroidCamOBS] Refresh Device List clicked
16:01:10.146: [DroidCamOBS] USBMux: found -1 devices
16:01:10.147: [DroidCamOBS] Could not get iOS device list, is usbmuxd running?
16:01:19.266: [DroidCamOBS] Refresh Device List clicked
16:01:19.266: [DroidCamOBS] USBMux: found -1 devices
16:01:19.266: [DroidCamOBS] Could not get iOS device list, is usbmuxd running?
16:01:19.664: [DroidCamOBS] added new device with serial 'Android-CPH2415._droidcamobs._tcp.local.'
16:01:19.667: [DroidCamOBS] warn: duplicate device
16:01:19.667: [DroidCamOBS] error adding device
16:01:26.019: [DroidCamOBS] activated: id=Android-CPH2415._droidcamobs._tcp.local. type=4 ip=192.168.1.87 port=4747
16:01:26.019: [DroidCamOBS] video_format=0/avc video_resolution=5/2560x1440
16:01:27.648: [DroidCamOBS] have config: 30
16:01:28.293: [DroidCamOBS] use hw: 1
16:01:32.302: [DroidCamOBS] deactivate
16:01:37.121: [DroidCamOBS] activated: id=Android-CPH2415._droidcamobs._tcp.local. type=4 ip=192.168.1.87 port=4747
16:01:37.121: [DroidCamOBS] video_format=0/avc video_resolution=5/2560x1440
16:01:38.400: [DroidCamOBS] have config: 30
16:01:38.641: [DroidCamOBS] use hw: 1
16:01:38.735: [DroidCamOBS] have config: 2
dev47
This is most likely due to you local ffmpeg version, which one is installed?
You would need to upgrade ffmpeg (if possible), or switch to the Flatpak version of OBS which should work without issue.
Razorflak
I made a test on another PC (a Windows) and it works great.
So I suppose it's related to the Linux version.
I just installed the latest version of ffmpeg I could find (7.0.2), but there’s no improvement.
Razorflak
I just tested with the Flatpak version, and it works like a charm.
Thank you, I wasn't familiar with this way of installing OBS at all.
pndspirit
Hey! I've got the paid app. It worked perfectly until today. On my Windows 11 machine, in OBS, when I press Activate, it idles for a bit, then only on my iphone i get the camera view for a split second. This repeats every few seconds. The obs log outputs:
22:28:09.769: [DroidCamOBS] read header recv returned -1
22:28:16.838: [DroidCamOBS] read header recv returned -1
22:28:24.002: [DroidCamOBS] read header recv returned -1
22:28:31.065: [DroidCamOBS] read header recv returned -1
again and again for each camera view.
I cannot use it with USB as this is my work laptop and it has no mobile support.
When I open the http /video stream it works, but with bad resolution. I can ping the IP and TCP is open on 4747. Not sure what else I can try.
Also to note, the stream works well on my other MacOS device, again with OBS.
DuctTapeGamer
Hello @dev47 !
Wonderful app by the way. Found a use for my old phone to stop it from being ewaste lol.
I am having an issue with the USB connection in OBS. I used to connect via wifi but I am now renting and have no access to my router so I can't port forward. It was to my understanding that the OBS plugin still worked via USB however my phone won't show up after refreshing device list. I am on windows. Looking through the log it might be ADB related but I'm not sure. Works on droidcam client.
Any help would be greatly appreciated!
  • 2025-01-25 02-31-38.txt
DuctTapeGamer
Hello @dev47 !
disregard i fixed it myself LOL
awesome app tho keep up the great work!!
varghexum
My OBS crashes when I turn the audio on:
info: [DroidCamOBS] activated: id=Android-SM-S921B._droidcamobs._tcp.local. type=4 ip=192.168.1.131 port=4747 info: [DroidCamOBS] video_format=0/avc video_resolution=0/640x480 error: v4l2-input: /dev/video0: select timed out error: v4l2-input: /dev/video0: failed to log status debug: obs_source_output_audio: Null 'audio_in' parameter debug: obs_source_output_audio: Null 'audio_in' parameter debug: Audio timestamp for 'Desktop Audio 2' exceeded TS_SMOOTHING_THRESHOLD, diff=73548834 ns, expected 5091325055877, input 5091398604711 debug: Audio timestamp for 'Desktop Audio 2' exceeded TS_SMOOTHING_THRESHOLD, diff=74468937 ns, expected 5091473604711, input 5091399135774 error: v4l2-input: /dev/video0: select timed out error: v4l2-input: /dev/video0: failed to log status debug: Audio timestamp for 'Desktop Audio 2' exceeded TS_SMOOTHING_THRESHOLD, diff=74115623 ns, expected 5091474135774, input 5091548251397 debug: Audio timestamp for 'Desktop Audio 2' exceeded TS_SMOOTHING_THRESHOLD, diff=74497523 ns, expected 5091623251397, input 5091548753874 error: v4l2-input: /dev/video0: select timed out error: v4l2-input: /dev/video0: failed to log status debug: Audio timestamp for 'Desktop Audio 2' exceeded TS_SMOOTHING_THRESHOLD, diff=73836043 ns, expected 5091623753874, input 5091697589917 debug: Audio timestamp for 'Desktop Audio 2' exceeded TS_SMOOTHING_THRESHOLD, diff=74369012 ns, expected 5091772589917, input 5091698220905 error: v4l2-input: /dev/video0: select timed out error: v4l2-input: /dev/video0: failed to log status error: v4l2-input: /dev/video0: select timed out error: v4l2-input: /dev/video0: failed to log status debug: Audio timestamp for 'Desktop Audio 2' exceeded TS_SMOOTHING_THRESHOLD, diff=76694904 ns, expected 5091898220905, input 5091974915809 debug: Audio timestamp for 'Desktop Audio 2' exceeded TS_SMOOTHING_THRESHOLD, diff=74513992 ns, expected 5092049915809, input 5091975401817 info: [DroidCamOBS] read_frame: got config: 28 error: v4l2-input: /dev/video0: select timed out error: v4l2-input: /dev/video0: failed to log status debug: Audio timestamp for 'Desktop Audio 2' exceeded TS_SMOOTHING_THRESHOLD, diff=73573912 ns, expected 5092050401817, input 5092123975729 debug: Audio timestamp for 'Desktop Audio 2' exceeded TS_SMOOTHING_THRESHOLD, diff=74845542 ns, expected 5092198975729, input 5092124130187 info: [DroidCamOBS] use hw: 1 warning: [DroidCamOBS] WARNING Stream has b-frames! debug: Audio timestamp for 'Desktop Audio 2' exceeded TS_SMOOTHING_THRESHOLD, diff=74254633 ns, expected 5092199130187, input 5092273384820 debug: Audio timestamp for 'Desktop Audio 2' exceeded TS_SMOOTHING_THRESHOLD, diff=74880230 ns, expected 5092348384820, input 5092273504590 error: v4l2-input: /dev/video0: select timed out error: v4l2-input: /dev/video0: failed to log status debug: private source 'Preview spacing label 0' (text_ft2_source) created debug: private source 'Preview spacing label 1' (text_ft2_source) created debug: private source 'Preview spacing label 2' (text_ft2_source) created debug: private source 'Preview spacing label 3' (text_ft2_source) created debug: Audio timestamp for 'Desktop Audio 2' exceeded TS_SMOOTHING_THRESHOLD, diff=74306068 ns, expected 5092348504590, input 5092422810658 debug: Audio timestamp for 'Desktop Audio 2' exceeded TS_SMOOTHING_THRESHOLD, diff=74613680 ns, expected 5092497810658, input 5092423196978 error: v4l2-input: /dev/video0: select timed out error: v4l2-input: /dev/video0: failed to log status info: [DroidCamOBS] read_frame: got config: 2 info: [DroidCamOBS] audio: sample_rate=44100 channels=1 Segmentation fault
droidcam-obs-plugin 2.3.4
OBS Studio 31.0.3.
PS: I use Samsung S24.
dev47
Hi, This is an issue with ffmpeg on some Linux distros. If possible, upgrade to a newer release or try the Flatpak version of OBS and DroidCam which are known to work.
sonk
Hey @dev47, great software. Just purchased the full version.
I was wondering if it was possible to add a shutter speed adjustment feature to the mobile app in the future. AFAIK there are other camera apps on iOS that let you do that so it should *technically* be possible, no idea about Android though but I'd be surprised if it didn't let you do it.
Apologies if that already exists or was adressed before but I haven't found any info regarding this. I'm trying film a CRT screen so letting me adjust shutter speeds is kind of crucial to avoid flickering, just in case you're wondering what use-case this could have. (I'm on iPhone 13)
Thanks.
dev47
Thank you @sonk. Manual exposure adjustments are on the list of features but not yet implemented. It is pending for both Android and iOS. (The auto exposure does a good job on phones, and the EV slider is sufficient for most use-cases).
There is no set timeline for now, but this option will come at some point.
Michael Owen C
I would really love the ability to stream with OTG Cameras (USB Webcams and such) I want to use my ZV-E10 USB Streaming function and pair it with droidcam obs as a wireless video transmitter, because streaming with droidcam obs is way faster to set up with minimal latency (Compared to RTMP Which usually has a 1 - 2 second delay)
I would really love this feature! I would buy the pro version just for this feature. lovely software!
