Draw
Draw 0.3.0
Hi Exeldro, I wanted make you aware that three of your plugins seem to be causing 32.0.0 beta 1 to crash upon start up. I manually tried each one, one at a time and found that when loaded it crashes at startup. I realize beta's are sometimes do not work sometimes, but I wanted you to be aware that draw dock, downstream keyer and audio monitor.
Analyzed URL:
Crash report:
THANKS FOR ALL YOU DO!
Loomis360
Analyzed URL:
Crash report:
Exeldro helped me solve my own issue with DSK over the weekend. I had an old StreamUp scene that was causing my video sources to freeze. When I deleted those it worked again. I can confirm that all three of the plugins you mentioned work for me on OBS 32 on Windows 11.
Thank You and yes, he has helped me before. He's awesome to say the least. However, it might be that I'm on a Mac, because it's crashing when they are installed. I literally installed one plugin at a time, so when they were uninstalled, no crash. I'm not a programmer, so I don't know what is happening, but they do warn us about beta's to. Just wanted to make him aware of it. That's all.
Exeldro
@Want To Learn both crash reports are source outputting video while OBS is closing and seem unrelated to the plugins. Can you provide an OBS log file of a session with the issue?
Thank you for your follow up! You're asking for a crash report while using it, right? Sorry, but I don't know how to get one when it crashes at startup. It sometimes doesn't even open up when they are loaded. It crashes right away unfortunately. Can you talk me through it.....a little more information....I always keep the last version of OBS and the newest one in case the newer one doesn't work. It always seems the newer one takes on the innerds of the old one. so even when I load them into the old the new still crashes. I realize this is just an update as opposed to a new full version. I just had a thought that maybe the old is corrupted and conflicting with your plugins, but not the other ones apparently. Thanks.
Update: I made a backup copy of OBS, erased the original scenes etc....opened OBS 32.0.0 beta1 up then it still crashed with those 3 plugins. Just an fyi. Thanks for all you do!
if this means anything in 32 beta 2 Draw didn't crash at startup. it's just in red and unusable. If I look into properties it's greyed out, an can't get into it at all, but it comes up as one of your shaderfilters in the filters menu as a digital clock but don't see one. Also it doesn't show up in the new plugin manager either. Thanks
Sorry, I think I just understood your question.
Log file if it helps:
@Want To Learn the OBS log file indicates that it is trying to load an older version of the draw plugin and failing. When you try to install the new version, do you get any errors?
I believe that was the current version, but I may have confused them. I was manually installing plugins to see what was making it crash, but I was pretty sure I installed the newest one. Or, perhaps it's the installer not correcting it. Or, I didn't choose the right mac installer? I always use universal for intel and it works....another note it might be my software.....I just discovered Chroma key is missing some parts. I am reluctant to reinstall OBS in fear of the installer over riding the OBS. that works...however, I do keep both! I'll try the installer now and let you know. Thanks so much!
Update: It might be the installer? I just installed the most recent taken from your download history with the #2 implying I already downloaded and installed it. Draw shows up nowhere in the menus except it is in the plugins folder of the main OBS folder. Thanks.
Update #2. I'm thinking even more that it's your installer. Draw dock date is April 17th that shows up in the OBS plugins folder and your newest one was made in August. Hope this helps. Thank You for helping me!
Update #3 I manually deleted Draw dock from the plugins folder then tried reinstalling the newest Draw dock. It shows up nowhere. Not even in the plugins folder of Beta 2.
Update #4 In OBS 31.1.2 when I see Draw as something I already started it shows in the filter option as like a shaderfilter of yours. However, I just manually reinstalled it in 31.1.2 and it works, but not beta!
