Draw
Draw 0.3.0
IkeE
This is utterly awesome. Only thing to make this better would be to have a few pre-defineable "pens" on the toolbar.
  • Like
Reactions: TFE
MartinBrieger
On KUBUNTU 24.04 with Kernel 6.11.11 and latest OBS, I do not see the Draw Tools when using "Interact", which is a true bummer.
Are they hiding somewhere?
Thanks to you I get nothing done. LOL. I learn about your plugins, download them and play with them all day long. Fantastic! No issues with installation either! Thanks for all you do!
Exeldro
jeffofl
I'm a newbie, and can't figure out how to invoke the drawing mode. I got it installed, and I see the drawing dock on the upper left of OBS screen, I added Global Draw as a source and it is the top of the stack for my video sources.
But I started recording and can't figure out what invokes the cursor to start drawing.
Exeldro
@jeffofl in the obs dock menu you should have an option called draw. Open that dock and place it in OBS by dragging the title bar. Resize it by dragging the sides to get the layout you want.
MartinBrieger
I have a Question. If it conceivable to have a Highlighter? Transparent Draw Color?
As if you were showing a PDF or something and can Highlight a Word/Sentence?
This is too awesome for words! Thank You. However, I would like to make a suggestion or maybe I can't find it? When you open Draw as it's own source (how cool is that?) Either it doesn't have it's own erase tool or I can't find it when I go into properties for that source? Should I go into docks to erase it or am I missing something? However, I do see an option to clear, but sometimes I just want to undo the last action or two. Thanks so much for this plugin. Uodate: Oops! If you choose it from docks it doesn't edit it. 2nd update LOL: I see the undo button at the bottom that allows you as many as you want, but don't know how. Thanks.
Exeldro
@Want To Learn the draw dock allows you to do draw on source that are on the scene you are on. To set an eraser from the source properties set the alpha to -100%. For undo you can use ctrl+z.
Shazam! Setting the alpha to -100% works. However, I am having problems with my Mac keyboard with keys not working and then working , so I'll stick to this setting. It's more natural for me this way to. Thanks! Your reply and help was really quick!
Another great thing is you made it source capable. If someone wants to use that thing they created in that source, not only is it editable it is copy and pasteable. Thanks so much!
RickYaeger
I was hoping you'd create something like this!!
That said, the shader adds a blue tint to my video and hangs OBS as soon as I let go of the mouse button at the end of drawing a line.
Mac OS 15.3.1
OBS 31.0.1
