Display Fightstick Motions
Free Display Fightstick Motions 210124
Xerna
This fix didn't work for me. Anytime I click off of my browser it just completely stops registering inputs. It worked fine a few days ago, and then today I boot up stream and it just completely stopped registering my inputs when I was in-game. Any other workarounds, since SF6 doesn't allow you to be focused on another window and register inputs from your controller at the same time
CyanPhoenix
So, this is a really cool find! I'm using this with my Neo Geo Arcade Stick Pro! Here are the values if anyone at all is interested:
Neutral93.28
Up9-1
Down90.14
Left90.71
Right9-0.42
Up-Left91
Down-Left90.42
Up-Right9-0.71
Down-Right9-0.14
Alright. So far so good, right? I do have a couple of problems with the graphics and the button detection, it looks. Even after moving them around in the editor above the parameters field(s), my changes don't want to apply over to the actual overlay for some reason. For example, I use a custom image (directly from Google Images, by the way) and it doesn't want to show properly at all, so the OBS link just dismisses it completely and uses the default. Another thing that's dismissed is my button layout to match the buttons better because initially when I press the buttons, they were all over the place, so I had some moving around to do. Now, it looks like it is saved to the layout properly when I save my edits and then load them back in after refreshing the page, but here's the kicker. It doesn't seem to actually apply when I look at the overlay in OBS. The overlay works fine, it just doesn't know that I changed some things for some reason. So, it's the complete default background and images and layout on the overlay, essentially and I kind of would not like that. I keep looking around, but it doesn't seem to be in my control for some reason. To make matters worse, it looks like this thing hasn't been updated in nearly 4 years. But, I don't really know quite where else I can find something like this. Is there going to be updates to this soon to help fix this or should I look for something newer?
xxdocobxx
Hello, I just tested it and didn't find the problem you mentioned. Have you overwritten it with the new layout.sav after changing the layout?
CyanPhoenix
Nevermind! I fixed it! Apparently, you can't use a TIFF file for the background, but you can use the WebP from the site, weirdly enough. Also, I didn't notice that you can just press the button to re-map the layout. I thought I had to move them around each time because of how weird the differences were. Thirdly, this time I made sure to have all of the files in the same folder and that seemed to have helped a ton! I don't know if I wanna stream tonight, but this is great I finally have this set-up now!
Torello
I changed the color and size of the buttons to match my hitbox, but I can't save the changes. When I click on Save As MySetting.html, it saves the default preset, just with a different background. Does anyone have any idea how to fix this?
QwertyzoroVague
If it's okay, I'd like to share a custom layout i made. It works well enough for me but i figured others might find use for it since it looks simplistic.
a way to swap out the joystick textures (stick-center.png and stick-up.png) without needing to replace them in the preset folder would probably help a bit.
edit: sorry for necro'ing a forum post for something like this
  • frame-imperfect.zip
