Cannot click anything in the window capture. please help newbie here
obsnewbiehere
please help me fix my issues in using obs.
1. i see some tutorial that it's allowed to click anything inside the "window capture" but I cannot click anything in my window capture. it stuck and won't allow clicking everything in my window capture. what do I need to do? here;s the screenshot. https://prnt.sc/stj59f
2. I tweak the chroma key for a couple of times now but I cannot remove the background, I already used greenscreen. Please help. here are the settings in chroma key. https://prnt.sc/stj9hw https://prnt.sc/stjakn
Please help
In OBS you can only interact with "Browser" source. When you add a "Browser" source you enter the webpage URL and the resolution. Then you can interact with your "Browser" source by right clicking over the source and selecting "Interact"
i cannot click anything on window capture on my device everything else is working fine but in case of window capture there is nothing i can click nothing i can select not even a single button work expect for the close one....... what to do please help anyone
Actually the list is not being populated for any reason
As when i opened windows security it gave me option to capture that in list otherwise no window is available to me for capturing
I have even turned off my hardware acceleration in chrome and there is no dedicated graphics card on my laptop
Sorry guys got the solution actually i was minimising the windows to be captured prior than window capture so it wasn't showing up on the list.
