BEST audio without adding filters
danielmoranthem
Hi there,
I'm exporting mkv files, and i've connected a simple boya microphone. Issue is:
Some times, audio will output at higher volume
Sometimes, it will go out at a lower volume
Sometimes, it will go out in a better quality, some times isn't so clear.
So it's weird, though i'm not changing my setup, i don't know how to get a constant top quality.
Maybe my config its wrong.
Or i don't know, if it has to do with the fact, that sometimes, between recordings, i plug in and out the mic jack. (obviously, i plug it back in before recording again)
I'll appreciate any help, i'd like to achieve the best sound quality that my hardware and software allows.
