Audio Monitor
Audio Monitor 0.10.0
MatDepInfo
Hello, this plugin works well ! But when I connect a mix table, I only see WDM. Is it possible to add ASIO channel ? Like the plugin obs-asio do it with input ?
AaronD
Love this functionality. Just wondering if there is a Linux version planned?
Hi, is there ever going to be a Linux version?
Thanks,
Tom
Any chance the mac version might work on a linux installation?
Can we please have an answer? I feel like we're being ignored.
Ehh... Not really. Not as I understand this plugin. OBS does have a native monitor output, and this link seems to just be a tutorial on how to use that. I already have that going to my headphones, which is slightly different on purpose from what the stream is. I also want to have an exact copy of what the stream is, going to the same HDMI output as the full-screen Program projector.
So that's what I want this plugin for: it's an *additional* audio output, on top of what OBS already has and is already in use. Don't really need the dock for what I'm doing, but if it can stay out of the way, then that's fine.
(While mixing a band on a separate console, feeding OBS as a "dumb passthrough", I can switch the headphones between stereo and mono *as OBS receives it* without affecting the stream. That's useful because a lot of viewers are going to hear it in mono anyway (too small of an angle between speakers, from the listening position, if they even *have* two speakers), and some actually have a true stereo rig, so it needs to work for both.)
AaronD
@AaronD I tried making a linux version but failed:
So I will need help from a developer with more linux experience to get it working on linux.
Mac and linux sound environments are not the same so the Mac version can not be used.
Thanks for the reply! I wish I could help with that, but I feel more like a "script kiddie" myself with most of Linux's functions. I use it because it's free and I can (eventually) make it do anything, even if it's not the "proper" way to do it. You probably want someone that actually knows how it works and how it's supposed to be used, to write your Linux version, and unfortunately that's not me.
GrumpyDog
I am not sure why, but as soon as I change the Audio Monitoring level the driver crash. The only way to fix it is to restart OBS.
Any ideas?
I re-installed the plugin
GrumpyDog
I included a video/audio file to hear the issue. Just to be clear, OBS does not crash, there is no Notification. If I change the setting, the audio breaks. I usually get the same artifacts when there is an audio driver conflict. If there would be a log output somewhere, please point me in the right direction?
  • 2022-07-31 11-41-51.zip
Nastyllama
This is an amazing plugin, just have one question is it possible to install this on a portable SSD install? I can't seem to see any option on the installer.
voltoman
I think I've found a glitch. I set the Audio Monitor Mute status as "Linked to source muting". Problem is, this doesn't work until I open the Filter and make any change, no matter how simple (eg. tick Locked, then untick again). So I can easily work around the problem but thought it might be worth looking at if you're in the code at some point.
same thing.
RustySly
any news on obs 28 compatibility? huge fan of this plug-in and it's the only thing keeping me from using the new obs.
pciccone
Love this plugin, it has become a core function when we use OBS. We are having one problem that causes us some issues unexpectedly. For reasons unknown, audio will stop outputting on the selected device indefinitely until we edit every single instance where the plugin is used and select any other output device from the dropdown then toggle back to the selected audio device. In some cases we have to edit dozens of scenes simply to select some other device then come back to the proper device. Rebooting, restarting never resolves this. Once the "problem" hits it stays until we select off and come back on the correct device from the dropdown menu. Is there anything I can do to help troubleshoot this when we have it occur to help find a solution?
Filgaja
Hey there :) i gave this tool a 5 star because it ist absolutely a Plugin that i searched for years even with bugs.
Now where i know when de Crackeling starts i can avoid it :)I Wrote down in my Review what isnt working, but i tried more.
The Error still appears when i slide volume to 0 and up again while it is monitoring through this plugin.
But only when i put an checkmark on "Volume linked to source volume"
Somehow as soon as i enable this and hit the audio slider it starts crackle like hell :D
If i do not use this option, i can slide the volume as much as i want and there is no error. But at the same time the musik will not toggled by volume slider so i have to put this volume down manualy ^^ and thats not that much satesfying as manualy slide audio volume by szene change etc automaticly ^^
maybe it could be my Sounddriver or hardware? Am i the only one with this problem?
If you need, i can record a video of this error and give you the log files :)
greetings
Filgaja
Ares1192
i have like 2ms lag :c
i dunno if its a normal thing, buuuut in my case is really confusin speaking and reciving the monitoring with the little delay
AaronD
I'm an audio guy. 2ms is not noticeable. That's about 2 feet in air. If you noticed, then you have a lot more lag than that.
