Aitum Vertical
Aitum Vertical 1.6.4
Can anyone help me I have the vertical plugin but I closed the vertical preview window and vertical source window and I don’t know how to get them back?????
I would like to trigger automatically the saving/recording of the vertical replay buffer. Is it possible to do so with an OBS Raw event ?
This is what I use for that, I have it set to a button on a software based stream deck I use, and I have the same button also set to grab the regular replay buffer as well, so this way one press of my "grab the replay buffer and make a clip" button does both the horizontal and vertical canvas.
This is the obs raw for the vertical replay buffer part:
{ "op": 6, "d": { "requestType": "CallVendorRequest", "requestData": { "vendorName": "aitum-vertical-canvas", "requestType": "save_backtrack", "requestData": null } } }
It 'is' a beta, so I just put OBS 31 back. I did see Exeldro commented somewhere that he's updating various plugins for OBS version 32 and I know that Downstream Keyer and Draw Dock have just been updated today. Best advice is to wait till your various plugins are updated, then make the move to version 32 :)
Aitum updated Aitum Vertical with a new update entry:
Version 1.6.0
  • Requires OBS 31.1 or higher
  • Converts existing Aitum Vertical scenes to the new OBS canvas system
  • Adds additional canvas option for Twitch Dual Format Streaming using Enhanced Broadcasting. Dual Format streaming on Twitch is currently in Alpha. This can only be used by streamers that are in Twitch's Dual Format Alpha group.
  • Fix transition override menu
  • Fix source sorting by name
  • Fix crash on closing OBS
  • Fix crash removing scene
Hello @Exeldro! Sorry to bother but it seems that Streamer.bot is not able to list/show vertical scenes anymore. Just installed OBS V32. Did I miss something here? Thanks
when I launch OBS, one time / 2 is crash, and the second time my set-up is fucked up. so it's very ennuying because I take 5 or 10min to prepared all, and after that I'm tired and don't want stream
Yeah same with me on vertical scenes dissapearing but mine is on stream deck. I used the filter stream deck button to use source record on a vertical scene but none of the vertical scenes or sources appear on stream deck any more for any of the obs buttons
Hi, I’m currently using the latest version of OBS and the latest Aitum Vertical plugin. I noticed in the release notes that it should be possible to “convert existing Aitum Vertical scenes to the new OBS canvas system.”
However, I cannot find any option in OBS or the Aitum plugin to make vertical scenes available in the main OBS canvas. I’ve already checked the Docks menu, plugin settings, and tried creating new scenes, but the feature doesn’t seem to show up.
Am I missing a step to enable this feature, or is it still experimental/only available under certain conditions? Any guidance would be really appreciated.
Thanks in advance!
please, add an option to download in zip format like other plugins! I have two portable instances of obs, and can't install it on both, it allows me to install only in one, and when I try to install to another one, it doesn't allow me to change the path!
