Question / Help Advice on memory for x264 encoding
Boildown
Look at the log file. Don't pay attention to Windows CPU usage, its not a good indicator of when your CPU is overloaded for video encoding, unless you don't have a hyperthreaded CPU (and maybe even not then). Instead just look at whether you're losing frames.
18:20:59.580: [DShow Device: 'c920'] settings updated:
18:20:59.580: video device: Logitech HD Pro Webcam C920
18:20:59.580: video path: \\?\usb#vid_046d&pid_082d&mi_00#7&133d8db2&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083}
18:20:59.580: resolution: 1920x1080
18:20:59.580: fps: 30.00 (interval: 333333)
18:20:59.580: format: MJPEG
Your USB bus is probably overloaded. Unless you're a cam-girl or something, you don't need your webcam running at 1080p. Try setting it to 540p.
Maginhart
Well if you didn't know 1080p helps with better chroma keying and i don't see any problems at 1080p or 720p fps is stable
Maginhart
Hmm tried to capture gaming pc trough ndi quality is shittier but I could do Fast now on the same settings so i guess Black Magic Intensity Pro 4k capture card loads cpu even more
jerknerkel
as long as your ram is dual channel it won't need to be a higher clock speed. Have you overclocked the CPU? mines running at 3.8ghz. going to need some more details!
Maginhart
Type of content that was tested grassy fields etc...
Yow580
FYI, I just pulled an 8gb stick out of my gaming PC to test the dual channel. On 1080p 60fps medium x264 preset my CPU dropped from 95%+ down to a comfortable 60ish% and very smooth video playback. The bios set it down to 2133 from the original single sticks 2400mhz too.
Sounds like I really just need some 3200mhz ryzen 2x4gb kit, but they don't really seem to exist they are all 2x8gb kits : (
Interesting though that it made this much difference, now I need to work out what ram to buy. Maybe I'll just get another generic 8gb 2400mhz stick?
Thanks.
How well does it work because i have a dedicated streaming pc with an i5-8400 can do 936p at 30 fps at medium x264 but is oinned at 100 percent does dual channel really help that much?
Yow580
How much help does dual channel give cause i have a i5-8400 and can do 936p 30 fps at x264 fast and pinned at 100 percent
