Advanced Scene Switcher
Prestorec
You can do exactly what you described. If you have trouble with something specific, it'd be great if you specified what. Variable actions/conditions help with var changes like setting, incrementing or checking if bigger, File condition + macro properties to get changes and lastly either Timer condition with every 3s comparison or changing macro settings to wait at least 3 seconds between runs.
Where I face issues is I can't figure the next step after setting
If>File>score.txt
Local File>score.txt>has changed
then
Variable
I've set a new variable as
Name>Initial Score
Current Value>0
Save / Load Behavior>Save Variable Value
Then which setting from the drop down menu i need in the set to condition value to set it in order to get score.txt value?
Destroy666
`Set to macro property` is what you need. Then `File content`. `Set to condition value` with proper condition could also work, but this is much cleaner.
Prestorec
Could you please be more specific with images or pseudo language for what i need to do. Im a bit lost on how to use macro property since it doesnt have anything that shows in the drop down menu and I dont find file content on then section unless you mean File as the above image i sent you.
Mind you Initial Score is not set to anything since I can't find how for it to fetch score.txt
Prestorec
Hi @Warmuptill, Is there a function that allows us to toggle conditions on/off within the actions of a macro?
I believe the thing you are looking for is under Macro on then section where you can select from the drop down menu to Toggle action (Enable action / Disable action /... + ) and can even specify which action you want to disable based on the number.
For example this Macro is set to 1 and will toggle the switch condition above it which is the Variable. If it was on 2 it would toggle the Macro since its the 2nd one in order. Macro 8 is basically the naming of the Macro you want this to be applied to.
Destroy666
Do you mean action that turns off some macro conditions? If so, I remember this being a feature request https://github.com/WarmUpTill/SceneSwitcher/issues/974 - they can't be turned off in the 1st place, only actions can. You need to currently use a variable (e.g. SomeConditionEnabled) and proper if condition priority for checking it to work around it.
attaboyBrad
Is there any documentation available for the RUN action in advss? I'm trying to find *any* way to automatically re-select the correct window capture sources for MacOS Window Capture when I launch OBS.
I have a script (appended below) that returns the window ID when I run it in terminal, and have confirmed it's the same ID that advss returns when I click "get current" after manually selecting the intended window, but when I try to run the script from advss, the only output I can seem to get is the "Process ID" of the running script. Everything else is just blank when I try to view it either as a variable or "set" the Standard or Error Output as a property of the source.
The best I can do for now is get advss to at least open the "properties" dialog automatically when the relevant app runs so I can select the window manually--and for that I'm very grateful as lacking "Window Match Priority" for MacOS screen capture has been a yearslong hassle at this point and it appears to be deliberately omitted. Apparently it used to be available in the deprecated Window Capture source options, but it seems to be gone now.
Grateful for any suggestions.
#!/bin/zsh
# Get the Notability window ID (excluding "Window" title)
WINDOW_ID=$(/opt/homebrew/bin/yabai -m query --windows | /opt/homebrew/bin/jq -r '.[] | select(.app=="Notability" and .title != "Window") | .id' | head -n 1)
# Log for debugging
echo "Yabai Output: $WINDOW_ID" > /tmp/yabai_debug.log
# Force output to stdout
echo $WINDOW_ID
Addiefied
Hi, I'm experiencing issues on advanced scene switcher on macOS. I've made a macro which open up the interaction menu and is supposed to do hotkey CTRL+Return, but for some reason its not toggling that hotkey inside of the interaction menu that opens. I've tested it on my windows system and it works great there. What could be the workaround for this?
Destroy666
No documentation needed. Do you have `Wait for process exit or at most` option ticked in the action? There's a hint there that it has to be ticked for macro properties to work, since if you don't wait the process is detached and this plugin has no control over it. Well, it could be read in theory, but to not disturb the flow of actions it'd need to wait for process to finish anyways. Would be great to also add that info when selecting the affected macro properties, but no such capability as of now.
attaboyBrad
I do have that option ticked. No joy.
Oh, dang it. I hadn't made the script executable! I'd just been running the Yabai command, which worked, and not the script itself!
Figures. Sorry to waste your time.
  • ScreenCap 2025-03-01 [OBS Studio] Advanced Scene Switcher - 1.28.1 000654.png
dcchapman7
I just tried installing the Advanced Scene Switcher 1.28.1 universal pkg on my Mac Mini M1 that is running OBS 31.0.1 and believe I authorized all the necessary permissions in Settings and installation showed successful. When I open OBS and click on the Tools drop down I am not seeing Advance Scene Switcher as an option. If you could please follow up with any support I would appreciate it.
Warmuptill
Can you please share an OBS log file?
This might give an indication why the plugin failed to load.
Rozenman
Dear WarmUpTill, without your plugin now as without hands - all lecture work is based on it. A fantastic product! But there was a problem: the antivirus program Intego, after another update of the virus databases, detected a virus in version 1.28.1. I am attaching a screenshot and really counting on your help.
Thank you!
AaronD
...antivirus program...detected a virus in [legitimate software]
I'm not surprised. Their purpose was over about a decade ago. They're mostly theater now. They have to convince you that they're doing something and worth continuing to pay for, and so they do stuff like this.
If you practice good internet hygiene yourself, you don't need third-party AV anymore. Get rid of it.
The OS itself now, handles the threats that you have nothing to do with (this is why you keep it up to date), and you don't "play in the mud" yourself.
Warmuptill
Thank you!
Similar things happened in the past with other antivirus vendors, but resolved itself / were resolved after reporting the false positive.
The plugin is open source.
If you want to and are able to you can re-build the plugin yourself, which will probably be enough for it be no longer being detected:
https://github.com/WarmUpTill/SceneSwitcher/blob/master/BUILDING.md
Alternatively, if you have an GitHub account, you can try using the most recent CI build from the master branch:
I just can't guarantee that it is bug free.
Unfortunately, besides saying that there is not much I can do about it.
dcchapman7
20:50:04.579: [macOS] Permission for audio device access granted.
20:50:04.582: [macOS] Permission for video device access granted.
20:50:04.585: [macOS] Permission for accessibility granted.
20:50:04.589: [macOS] Permission for screen capture granted.
20:50:04.590: CPU Name: Apple M1
20:50:04.590: CPU Speed: 2400MHz
20:50:04.590: Physical Cores: 8, Logicaal Cores: 8
20:50:04.590: Physical Memory: 16384MB Total
20:50:04.590: Model Identifier: Macmini9,1
20:50:04.590: OS Name: macOS
20:50:04.590: OS Version: Version 13.6.9 (Build 22G830)
20:50:04.590: Rosetta translation used: true
20:50:04.590: Kernel Version: 22.6.0
20:50:04.591: hotkeys-cocoa: Using keyboard layout 'com.apple.keylayout.US'
20:50:04.593: Current Date/Time: 2025-03-05, 20:50:04
20:50:04.593: Browser Hardware Acceleration: true
20:50:04.593: Qt Version: 6.6.3 (runtime), 6.6.3 (compiled)
20:50:04.593: Portable mode: false
20:50:04.780: OBS 31.0.1 (mac)
20:50:04.780: ---------------------------------
20:50:04.783: ---------------------------------
20:50:04.783: audio settings reset:
20:50:04.783: samples per sec: 48000
20:50:04.783: speakers: 2
20:50:04.783: max buffering: 960 milliseconds
20:50:04.783: buffering type: dynamically increasing
20:50:04.786: ---------------------------------
20:50:04.786: Initializing OpenGL...
20:50:04.834: Loading up OpenGL on adapter Apple Apple M1
20:50:04.834: OpenGL loaded successfully, version 4.1 Metal - 83.1, shading language 4.10
20:50:05.142: ---------------------------------
20:50:05.142: video settings reset:
20:50:05.142: base resolution: 1920x1080
20:50:05.142: output resolution: 1920x1080
20:50:05.142: downscale filter: Bicubic
20:50:05.142: fps: 30/1
20:50:05.142: format: NV12
20:50:05.142: YUV mode: Rec. 709/Partial
20:50:05.143: NV12 texture support enabled
20:50:05.143: P010 texture support not available
20:50:05.143: Audio monitoring device:
20:50:05.143: name: Default
20:50:05.143: id: default
20:50:05.145: ---------------------------------
20:50:05.160: No AJA devices found, skipping loading AJA UI plugin
20:50:05.160: Failed to initialize module 'aja-output-ui'
20:50:05.173: No AJA devices found, skipping loading AJA plugin
20:50:05.173: Failed to initialize module 'aja'
20:50:05.176: Failed to load 'en-US' text for module: 'decklink-captions'
20:50:05.178: Failed to load 'en-US' text for module: 'decklink-output-ui'
20:50:05.195: Decklink API Compiled version 12.0
20:50:05.195: Decklink API Installed version 12.7.1
20:50:09.469: [obs-browser]: Version 2.24.4
20:50:09.469: [obs-browser]: CEF Version 127.0.6533.100 (runtime), 127.3.2+gf1af617+chromium-127.0.6533.100 (compiled)
20:50:09.514: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.5.4 | RPC Version: 1)
20:50:09.514: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.6.3 | Qt version (run-time): 6.6.3
20:50:09.514: [obs-websocket] [obs_module_load] Linked ASIO Version: 103100
20:50:09.515: DEPRECATION: obs_frontend_get_global_config is deprecated. Read from global or user configuration explicitly instead.
20:50:09.526: [obs-websocket] [obs_module_load] Module loaded.
20:50:09.537: os_dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib->/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib): dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib, 0x0105): tried: '/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib' (no such file), '/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib' (no such file)
20:50:09.537:
20:50:09.537: [vlc-video]: Couldn't find VLC installation, VLC video source disabled
20:50:09.540: os_dlopen(/Library/Application Support/obs-studio/plugins/obs-ndi/bin/obs-ndi.so->/Library/Application Support/obs-studio/plugins/obs-ndi/bin/obs-ndi.so): dlopen(/Library/Application Support/obs-studio/plugins/obs-ndi/bin/obs-ndi.so, 0x0105): Library not loaded: @rpath/libobs.0.dylib
20:50:09.540: Referenced from: <5988A92D-E853-3766-B96D-F6F4555BF38A> /Library/Application Support/obs-studio/plugins/obs-ndi/bin/obs-ndi.so
20:50:09.540: Reason: tried: '/Users/runner/runners/2.166.4/work/1/obs-studio/build/libobs/libobs.0.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Users/runner/runners/2.166.4/work/1/obs-studio/build/libobs/libobs.0.dylib' (no such file), '/Users/runner/runners/2.166.4/work/1/s/build/../../obs-studio/build/UI/obs-frontend-api/libobs.0.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Users/runner/runners/2.166.4/work/1/s/build/../../obs-studio/build/UI/obs-frontend-api/libobs.0.dylib' (no such file), '/Users/runner/runners/2.166.4/work/1/obs-studio/build/libobs/libobs.0.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Users/runner/runners/2.166.4/work/1/obs-studio/build/libobs/libobs.0.dylib' (no such file), '/Users/runner/runners/2.166.4/work/1/s/build/../../obs-studio/build/UI/obs-frontend-api/libobs.0.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Users/runner/runners/2.166.4/work/1/s/build/../../obs-studio/build/UI/obs-frontend-api/libobs.0.dylib' (no such file), '/Applications/OBS.app/Contents/Frameworks/libobs.0.dylib' (no such file), '/Applications/OBS.app/Contents/Frameworks/libobs.0.dylib' (no such file), '/usr/lib/libobs.0.dylib' (no such file, not in dyld cache)
20:50:09.540:
20:50:09.540: Module '/Library/Application Support/obs-studio/plugins/obs-ndi/bin/obs-ndi.so' not loaded
20:50:09.541: ---------------------------------
20:50:09.541: Loaded Modules:
20:50:09.541: vlc-video
20:50:09.541: text-freetype2
20:50:09.541: rtmp-services
20:50:09.541: obs-x264
20:50:09.541: obs-websocket
20:50:09.541: obs-webrtc
20:50:09.541: obs-vst
20:50:09.541: obs-transitions
20:50:09.541: obs-outputs
20:50:09.541: obs-filters
20:50:09.541: obs-ffmpeg
20:50:09.541: obs-browser
20:50:09.541: mac-virtualcam
20:50:09.541: mac-videotoolbox
20:50:09.541: mac-syphon
20:50:09.541: mac-capture
20:50:09.541: mac-avcapture
20:50:09.541: mac-avcapture-legacy
20:50:09.541: image-source
20:50:09.541: frontend-tools
20:50:09.541: decklink
20:50:09.541: decklink-output-ui
20:50:09.541: decklink-captions
20:50:09.541: coreaudio-encoder
20:50:09.550: [VideoToolbox encoder]: Added VideoToolbox encoders
20:50:09.551: ---------------------------------
20:50:09.551: Available Encoders:
20:50:09.551: Video Encoders:
20:50:09.551: - ffmpeg_aom_av1 (AOM AV1)
20:50:09.551: - obs_x264 (x264)
20:50:09.551: - com.apple.videotoolbox.videoencoder.prores-422 (Apple VT ProRes Software Encoder)
20:50:09.551: - com.apple.videotoolbox.videoencoder.ave.avc (Apple VT H264 Hardware Encoder)
20:50:09.551: - com.apple.videotoolbox.videoencoder.h264 (Apple VT H264 Software Encoder)
20:50:09.551: - com.apple.videotoolbox.videoencoder.ave.hevc (Apple VT HEVC Hardware Encoder)
20:50:09.551: - com.apple.videotoolbox.videoencoder.hevc.vcp (Apple VT HEVC Software Encoder)
20:50:09.551: Audio Encoders:
20:50:09.551: - CoreAudio_AAC (CoreAudio AAC)
20:50:09.551: - ffmpeg_aac (FFmpeg AAC)
20:50:09.551: - ffmpeg_opus (FFmpeg Opus)
20:50:09.551: - ffmpeg_pcm_s16le (FFmpeg PCM (16-bit))
20:50:09.551: - ffmpeg_pcm_s24le (FFmpeg PCM (24-bit))
20:50:09.551: - ffmpeg_pcm_f32le (FFmpeg PCM (32-bit float))
20:50:09.551: - ffmpeg_alac (FFmpeg ALAC (24-bit))
20:50:09.551: - ffmpeg_flac (FFmpeg FLAC (16-bit))
20:50:09.551: ==== Startup complete ===============================================
20:50:09.631: All scene data cleared
20:50:09.631: ------------------------------------------------
20:50:09.640: Source ID 'ndi_source' not found
20:50:09.640: Failed to create source 'NDI™ Source'!
20:50:09.642: Switched to scene 'Scene'
20:50:09.643: ------------------------------------------------
20:50:09.643: Loaded scenes:
20:50:09.643: - scene 'Scene':
20:50:09.643: - source: 'NDI™ Source' (ndi_source)
20:50:09.867: [mac-virtualcam] macOS Camera Extension activated successfully.
Warmuptill
20:50:09.537:
20:50:09.540:
There doesn't seem to be any indication of the plugin being even attempted to be loaded.
Can you check if the following folder exists?
<path to your user folder>/Library/Application Support/obs-studio/plugins/advanced-scene-switcher.plugin
dcchapman7
Thanks for the reply. I don't see the "plugins" folder under the Application Support/obs-studio folder. See screen shot... I believe I have given all necessary permissions to OBS in the Mac settings... not sure what to try...
