Advanced Scene Switcher
AaronD
That's what I mean
So the scene changes underneath and all that, but Adv.SS only applies/removes filters after the fact
Yep, what I said should work in theory:
Put the stinger in its own scene as a media source, or however you can make it work as a standalone dedicated scene (rebuild it with OBS tools and plugins if you have to), and then DSK it on top with that plugin. Then use Adv. SS to coordinate all of the moving parts to make the right effect in the end. Blur, then run the stinger, cut scenes while the stinger is entirely opaque, then unblur.
It's a lot of work to get around what seems to me like a limitation of OBS itself - not enough multithreading, to use a technical term, similar to this post - but at least it's possible.
Lantecer
Hi, sorry no answer for your problem, and I hope i"m not being too nosy, I love to learn from other people, but what is the purpose of cycling thru 3 scenes?
Sure, we operate a shooting range with tournaments, 2 scenes for 2 webcams and a screen where all targets can be seen.
The viewers can see all 3 scenes in a 30s cycle.
Unless there's a reason to do otherwise, I would always check the "only on change" box. Not checked, means that it runs again on every scan as long as the condition remains true. In your case, it doesn't really matter because all three macros kill their own conditions anyway, but it's a good habit to get into.
For running in parallel, I've recently started doing that by default as well, because of some timing issues, especially when I run them manually with the dockable buttons.
  • Not in parallel, locks up the user interface until the macro is completely finished (when triggered by the dock, at least), and causes OBS to schedule some of its own responses to happen afterwards too, which can override some of what I wanted the macro to do.
  • Running in parallel, lets the GUI thread come back immediately and continue to respond while the macro runs, and allows OBS to do its automatic stuff immediately, that the same macro can then wait for and override like I want it to.
More details in this post:
I turned on the options but nothing changed. I think I also found a pattern.
1st Scene manual select -> switches to 2nd scene -> OK
2nd scene doesn't switch to 3rd scene at all, even at manual selection
3rd scene switches to 1st scene again if selected manually -> OK -> Stays here. No automatic transition to 1st scene again.
Edit: "Run macro" button works when I`m on the 2nd scene. I`m really confused with that little issue...
There is a tournament which will be streamed in 1 week.
Here are screenshots from our real setup:
AaronD
View attachment 108624View attachment 108625View attachment 108626
That is weird. Those screenshots should work. All the other macros are paused, so they shouldn't matter. You *can* run a macro from another one, even if it's paused, but you're not doing that either.
What does the General tab look like? Any weird settings there?
Are there any other controls that might be overriding this?
bcoyle
Thanks for answering my question about the 3 scenes
Warmuptill
As already mentioned by AaronD everything seems fine in the screenshots.
Can you try enabling verbose logging, reproducing the issue, and sharing the corresponding OBS log file?
Maybe I can spot the issue this way.
echoplexmedia
Ubuntu Studio 24.04
Both the mainline and beta do install from deb package, but I get this error
dpkg: dependency problems prevent configuration of advanced-scene-switcher:
advanced-scene-switcher depends on libopencv-core4.5d (>= 4.5.4+dfsg); however:
Package libopencv-core4.5d is not installed.
advanced-scene-switcher depends on libopencv-imgproc4.5d (>= 4.5.4+dfsg); however:
Package libopencv-imgproc4.5d is not installed.
advanced-scene-switcher depends on libopencv-objdetect4.5d (>= 4.5.4+dfsg); however:
Package libopencv-objdetect4.5d is not installed.
dpkg: error processing package advanced-scene-switcher (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
The plugin works fine in OBS (i currently have the beta running), but then when certain packages update (chrome for example, for whatever reason) the package manager says that advanced scene switcher must be removed.
I also get this message whenever I open updates in discover (it's long I know)
W: Target Packages (universe/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target Translations (universe/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target DEP-11 (universe/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target DEP-11 (universe/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target DEP-11-icons-small (universe/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target DEP-11-icons (universe/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target DEP-11-icons-hidpi (universe/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target DEP-11-icons-large (universe/dep11/icons-128x128.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target CNF (universe/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target CNF (universe/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target Packages (multiverse/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target Packages (multiverse/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target Translations (multiverse/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target DEP-11 (multiverse/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target DEP-11 (multiverse/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target DEP-11-icons-small (multiverse/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target DEP-11-icons (multiverse/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target DEP-11-icons-hidpi (multiverse/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target DEP-11-icons-large (multiverse/dep11/icons-128x128.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target CNF (multiverse/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target CNF (multiverse/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/dvd.list:3 and /etc/apt/sources.list.d/ubuntu.sources:2
W: Target Packages (universe/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target Translations (universe/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11 (universe/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11 (universe/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11-icons-small (universe/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11-icons (universe/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11-icons-hidpi (universe/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11-icons-large (universe/dep11/icons-128x128.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target CNF (universe/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target CNF (universe/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target Packages (multiverse/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target Packages (multiverse/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target Translations (multiverse/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11 (multiverse/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11 (multiverse/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11-icons-small (multiverse/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11-icons (multiverse/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11-icons-hidpi (multiverse/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11-icons-large (multiverse/dep11/icons-128x128.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target CNF (multiverse/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target CNF (multiverse/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/dvd.list:1 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target Packages (universe/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target Translations (universe/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11 (universe/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11 (universe/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11-icons-small (universe/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11-icons (universe/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11-icons-hidpi (universe/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11-icons-large (universe/dep11/icons-128x128.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target CNF (universe/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target CNF (universe/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target Packages (multiverse/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target Packages (multiverse/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target Translations (multiverse/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11 (multiverse/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11 (multiverse/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11-icons-small (multiverse/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11-icons (multiverse/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11-icons-hidpi (multiverse/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target DEP-11-icons-large (multiverse/dep11/icons-128x128.tar) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target CNF (multiverse/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target CNF (multiverse/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/dvd.list:2 and /etc/apt/sources.list.d/ubuntu.sources:1
E: The repository 'https://ppa.launchpadcontent.net/radeon-profile/stable/ubuntu noble Release' does not have a Release file.
W: Updating from such a repository can't be done securely, and is therefore disabled by default.
W: See apt-secure(8) manpage for repository creation and user configuration details.
Lantecer
While starting the verbose logging I noticed this setting:
After ticking this "off" it works now. Wow. Thank you guys so much for your help!
Maybe this was turned on by default with one update a few months ago?
I can't really see why there is still a pattern that some scene transitions work while others don't, but for now my issue is solved.
AaronD
Also weird. It's not default for me. Glad you found it though. Surely you weren't playing with it at some point, and forgot to turn it back off??? Or someone else, without your knowledge? (In which case, you'll want to check EVERYTHING!)
Warmuptill
SuperKitty
tried to install this plugin but Mac OS won't let me as it says:
Apple could not verify “advanced-scene-switcher-1.28.0-macos-universal (1).pkg” is free of malware that may harm your Mac or compromise your privacy.
Warmuptill
You can "right click" or "control click" on the file and select "open" to get the option to skip this check.
Paying Apple 99$ a year (at least last I checked) just to avoid this message from showing is not worth it to me.
ECto-Monkey
Hi everyone, been using Advanced SS for some time now, without any issue.
When I open it, there is a yellow ! on the General Tab. Any idea what that means?
Just updated it, still see the icon. Lately my OBS has been freezing when Recording using it. I only use the Sequence tab to change scenes on timers
AaronD
Don't know what the icon means either, without a screenshot at least, but you should probably migrate your sequencing into Macros instead.
Warmuptill said in the latest update that there are no plans to remove it *yet*, but I would still consider *all* of the legacy tabs to be endangered.
ECto-Monkey
Warmuptill
This warning icon appears when the plugin is not started.
It was added more than a year ago as a frequent source of issues back then was that the plugin was simply not switched on and this was difficult to notice.
ECto-Monkey
Thank you appreciate it. Now onto the next inquiry of why OBS freezes after 10-15 minutes of recording.
Thank you
Warmuptill
Thank you
Unfortunately without more context it will be really difficult to say what the issue might be / to analyse potential problems.
What type of macros are you using when the problem happens?
Do you have a log file of the issue?
Does OBS crash at some point and if so do you have a crash report?
ECto-Monkey
I do yes, here is the most recent from moments ago: https://obsproject.com/logs/XsyydIaGSUgjj0U4
I figured a link is ok? Or would you/anyone prefer the full body of text?
I do not use any macros, just the Sequence tab for 4 different scenes.
Warmuptill
In this case I would be very surprised if the advanced scene switcher is related to the OBS freeze.
I can't spot any obvious issues in the attached log either.
Maybe someone more knowledgable about the general OBS logs will be able to spot something in the log file.
