Advanced Scene Switcher
Mark Weiss
What I'm having difficulty understanding is the variable part. Is that like poking a bit into a register and then later reading it based on a conditional branch? What is the purpose of the variable?
I think if I could modify my macros to be aware of what the other macro is doing with regard to the break/bumper, I could avoid having bumpers accidentally playing back to back. It happens when the bumper plays, triggered by the end of one program and the start of another, but then 15 minutes is also coming to a close and the 15 minute macro executes too, causing the bumper to play again too soon. The idea is for the 15 minute timer to reset when a program ends and starts another. But I don't know if one macro can modify/reset the timer on another macro.
Laczkó
It can. You can use "Timer" action (shown below) and set it to "Reset timers on Commercial Timer". In the condition part of the macro you check if a program change happens, so every time it happens, your timer in your "Commercial Timer" macro going to reset.
AaronD
That can work too. Like I've said a number of times, "This is a programming language. There are lots of different ways to do the same thing, and all of them have different side-effects."
If you really care about the details, and you know what you're doing, then you'll likely have several different ways in your head at the same time, already simulated, and you'll spend more effort designing the side-effects for various reasons, than you spend on the main function.
As an example of designing the side-effects, Laczkó's version guarantees that there will always be exactly 15 minutes between the program change and the first break, while mine doesn't have that guarantee. Mine is "free-running", as we say, similar to your first example, and only causes some of the timer events to do nothing, depending on the value of the variable at that moment. Most of my logic, then, is to manage the value of that variable.
It might be hard to see that, because I'm using the value alone as the direct trigger for the break, but it should emerge when you consider *when* that particular value appears, and what else also happens in that context, both before and after, as all of the macros do what they're set for.
Hey, guys, i have been told to post my question over here, so here goes:
I am running a makro on Win 11 with Obs 30.0.0 that checks for text in video and works fine as long as i hit "Run macro". It finds the text and executes the makroactions just like i want.
I would like it to continuously check for that condition and execute said makro if conditions are true. I took the general page with "check conditions every x ms" to do just that (compare added screenshot, i tried variants of 50-500ms). Apparently it doesn't? Can i make it do that? Does it even make sense to do that?
The scenario is literally me queuing a game. Queue Pops at an undetermined point in time ("accept" or some variant appears, which i am confident i can find) and then i would like the makro to execute.
Thanks for your help in advance! <3
Warmuptill
Hitting the "Run macro" button runs the actions for the selected macro regardless of the current condition state.
So it does not attempt to find any text in that case.
You will have to tweak the OCR settings so the text can be detected.
Without knowing what the text looks like it is very difficult to say what would need to be adjusted exactly, but I assume you will have to adjust the text color.
Note that depending on what the text looks like it might also be an option to simply rely on pattern matching instead of OCR.
Thank you for your response!
I believe i have done that. I am trying to make a simpler version of my idea work first, so i am capturing the normal editor with the text "Switch". Please find attached screenshot of proof it is indeed finding the only word "Switch". Im comfortable with finding the right colour scheme and everything.
I understand the entire thing to be: "Upper screen" of the macro with "if" condition clause and the bottom to be a "then" clause with whatever i want it to do. Is that correct?
The only part that doesn't seem to work is either the makro not caring about the condition, not connecting condition with action or not even checking continuously for the action as far as i can tell and i do not know how to check for any of these things at this point.
Warmuptill
Yes, that is correct.
Can you export your macros to a file so I can test it on my end?
What also could be useful is a verbose OBS log of the time when the actions are not performed while you expect them to.
You can find the log files in OBS under Help > Log Files.
settings are uploaded.
logs are returning this:
23:58:47.729: [adv-ss] Macro Dota Picking Screen Macro is paused
23:58:47.729: [adv-ss] Macro Normal Dota Scene is paused
23:58:47.738: [adv-ss] condition video returned 0
23:58:47.738: [adv-ss] Macro Testmacro returned 0
23:58:47.739: [adv-ss] try to sleep for 490
23:58:48.229: [adv-ss] Macro Dota Picking Screen Macro is paused
23:58:48.229: [adv-ss] Macro Normal Dota Scene is paused
23:58:48.238: [adv-ss] condition video returned 0
23:58:48.238: [adv-ss] Macro Testmacro returned 0
23:58:48.240: [adv-ss] try to sleep for 490
i guess try to sleep is the intervall i entered in general as 500ms
The text under "Show match" is being found the way i typed it i would expect condition video to return a 1 in this situation.
i guess another thing i could try is removing all the individual scenes and make it vanilla (i have like 20 scenes for different games/scenarios, idk if that affects anything), but it shouldnt cause the obs main output is being scanned agaik.
i believe the scene switcher version is 1.23.1 atm.
thank you for your help!
  • Scene switcher settings.txt
Latest update is causing OBS to crash on start here. Removed Advanced Scene Switcher and OBS starts fine. tested multiple times.
I see the message from Advanced Scene Switcher asking to backup settings on launch of PBS, but do not see OBS itself. It then crashes.
Unhandled exception: c0000005
Date/Time: 2023-12-11, 09:20:30
Fault address: 7FFADDD80B7D (c:\program files\obs-studio\bin\64bit\qt6widgets.dll)
libobs version: 30.0.0 (64-bit)
Windows version: 10.0 build 22631 (release: 23H2; revision: 2792; 64-bit)
CPU: 13th Gen Intel(R) Core(TM) i9-13900K
Maybe the issue is the backup message itself.
I put the plugin files back and now OBS starts but there was no backup message from Advanced Scene Switcher and all my Macros have gone.
Warmuptill
Strange - I am not able to reproduce that behavior.
The backup message would only be shown if there is a version change.
If you have uninstalled the plugin and started OBS and then re-installed the plugin there will be no backup message.
I doubt that it will help, but can you share the full crash log?
If you start OBS without the plugin installed then the plugin settings are gone, unfortunately.
Hi thanks for the reply.
Yes I can share one of the logs. I still have it on clipboard. (Attaching).
I downloaded and installed the latest update released (yesterday)
I started OBS a number of times, OBS just disappeared and one or two times I saw the Advanced Scene Switcher backup message (which I always see after updating Advanced Scene Switcher to the latest version). But could not interact with that message.
The message stayed up front even after OBS had crashed but could not be interacted with.
Advanced Scene Switcher was the only thing I had changed since my last OBS session so I figured this may be the issue.
I dragged the plugin files away and OBS started fine.
Put them back and OBS started fine but as you say, settings all gone.
Restored settings from backup. All OK now.
I did also have a little trouble restoring from backup. Some settings were not restored. I had to remove all Advanced Scene Switcher settings again and then restore.
While I am here, you mention that opening OBS without the plugin, it is expected that the settings are gone. is there anything that can be done about this? And where are those settings stored? (Yes, we can Export backup but it would be good to be able to actually backup the entire settings just in case).
Cheers,
  • log.txt
There are 2 Windows dmp files here too. I have zipped them in case any use to you. (I always have dmp files enabled for crashes as I work with QA testing). They are too big for the forum. (64Mb each)
AaronD
...opening OBS without the plugin, it is expected that the settings are gone. is there anything that can be done about this? And where are those settings stored? (Yes, we can Export backup but it would be good to be able to actually backup the entire settings just in case).
They're part of the Scene Collection. All one chunk of data that contains everything that is loaded at that moment. If a plugin doesn't load, then neither are its settings from the old Collection, and so the new Collection doesn't have them.
I really don't like how that works, especially since the change from OBS v27 to v28 was automatic for a lot of people, and the change of graphics engines at that specific point meant that almost all plugins failed to load. No warning, and no recourse. And it affected *all* plugins, not just this one. Hope you backed everything up before the unwarned automatic upgrade, because it's gone otherwise!
Ahh got it, thanks for the info. yes I always have lots of backups.
(Oh... OBS now updating... 30.0.2 fwiw.)
All running fine now anyway.
Warmuptill
I think the issue might simply be that the OCR library appends a new line character at the end of the detected text and thus your input pattern does not match the detected text.
You can either add the new line to your input pattern or you can enable regular expression support to allow partial matches.
Cheers,
Thanks for sharing the crash log!
It seems to somehow be related to the OBS websocket library attempting to display a system tray notification.
That will help me figure out what went wrong.
You, Sir, are a god. I did not even see the buttons on the right there, because the window opens in a smaller size or else i would have been able to help myself - probably. Well done and many thanks!
Cheers,
This is more to @Warmuptill but I wanted to confirm that I'm getting a crash on one of my setups, but it's the single-most-complex setup in my cluster of four computers. However, I can also say that I (thankfully) did not lose my current setup. Same here; I get the backup dialog but cannot interact with it because OBS Studio is in the process of crashing in the background.
I don't know if you need any further loggage or not; please let me know.
Anyway, my setup is as follows:
VTuber: 1.24.1. Successfully backed up.
Gamer: 1.24.1. Successfully backed up.
Studio: 1.24.0. Had to roll back as this machine will crash with 1.24.1.
Encoder: 1.24.1: Successfully backed up.
All are now running OBS Studio 30.0.2.
--Katt. =^.^=
Just a quick follow up:
Yes, this sounds possible, most of my macros have system tray notifications.
I only lost my setup because I had to remove the plugin in order to get OBS to start without crashing. Other than that, the symptoms were identical, (the non-interactable backup dialog + OBS crashing in bg).
