Add option to save recording as current scene
AlexyGalaxy
TL:DR- There is no way to automatically name your recordings as the current scene.
Add %CST = current scene title to Advanced>Recording>Filename Formatting.
Description:
To change the way a recording is saved navigate to Advanced>Recording>Filename Formatting.
Currently there are 23/27 variables for time/date and 4/27 variables for video settings.
Issue:
There are currently no variables set so that the user can automatically save different file names.
Solution:
Add variable %CST = current scene title when the recording starts. This will give the user the ability to better define recoding's. If the user has a plugin that changes the scenes this wont matter as the variable should be declared as the current scene title when the recording started.
Reddit posts where people ask for this exact feature:
