5070 GPU maxing 100% usage when capturing PS5 in 1440p
Yiyichiang
Hello All,
I have an issue about the 5070 GPU maxing usage when using Elgato HD60X to capture PS5 at 1440p, if the quality change to 1080p the GPU usage will suddenly drop to 40~60%, I have tried with Elgato Studio to capture and the studio can capture the screen in 1440p and run smoothly, tho it has audio issue with cracking sound, but that another matter.
I only use OBS for game capture from PS5, not running recording or streaming in the background, would like to ask if anything can be done to solve the issue.
Here are the log :
https://obsproject.com/logs/s1WvcqHMKOBcXbkr (this is the log when the resolution is at 1980 x 1080 p)
https://obsproject.com/logs/uBkKcBCVSfKdqoHB (Resolution at 2440 x 1440p)
Back up note: Have tried with reinstall the GPU driver, but the usage still performs the same
Thank you,
Best,
