Question / Help 4K streaming with the temp fix on Catalina?
stellaStarxhild
Hey guys. I’m not finding any 4K resolution as an option in settings. I’m a novice and not sure If I’m missing something or if this is an issue with that temporary fix until they complete the update to run on Catalina.
Can anyone shed some light? I’m using a loaded iMac ( i7 ) and 1gb internet speed so my equipment can handle. I just can’t get any 4K settings. Help!! Such a noob...
Omg. (Facepalm). It looked like I could only choose not of their options. And none of them went that high. I feel dumb. Lol. Thank you. I almost think i tried that... if there’s any chance someone can send me a screen shot... I’d be grateful. I’m off my computer and will try soon.
Thank you soooooo much!!
Thank you. I have a new issue. I can configure the settings you showed above. I can’t however configure it on the specific “cam” settings. It seeMs i can’t manually enter See attachments. Helllllllp! Lol. And thank you for your time, expertise, and wisdom!!
You can't set a resolution there that the cam does not support.
Choose one of the available options and stretch the window in your source pane if required. (Scaling will occur.)
