0.56.04 madness build - features plus encoding changes
Status
Not open for further replies.
Re: 0.56.03 MADNESS build - features plus encoding changes
Can now record with quick sync on i5-3450(intel hd 2500) 1920x1080 at amazing 120fps, oi oi oi. Earlier build can't do it. Great work. Future for specific hardware encoders, not x86 cpu only. With next 5 years i bealive it be common use hardware encoders to stream. Quality increases with each next generations of encoders.
freehuhn
which driver version did you use.
i'm able to do this with 0.554b but not with madness.
9.17.10.2932 for win7 x64. Have some crashes, need more testing. Also need testing 0.554b for same thing.
1366x768x100fps record without crash. Maybe need add more ram for igpu.
Anonanon
I had a reoccuring problem where video and audio are not quite in sync, especially when I'm showing a video using MPC-HC. I tried to fix this by downloading the new 0.56.03 MADNESS build, which states:
· Fixed a bug with frame timing (audio/video sync) with the new encoder thread, audio/video should be much more in sync
... but I still notice a delay between A/V. "Force desktop audio to use video timestamps as base for audio time" timestamp tickbox and "Mic sync fix hack" tickbox don't fix it either.
Edit: Sorry I think I spoke too soon. It didn't seem fixed after grabbing the 0.56.03, but after watching and waiting it out for some time, the sync seemed to click into place.
Have problem with 1920x1080 over 85 fps, when stop stream after 1 minute have crash obs. Maybe it problem of Quick Sync on i5-3450.
1920x1080 85fps records no problem.
1280x720 120fps records no problem.
Actually no complain about. 1920x1080 85fps, say what ? Amazing. For local records, fraps pls don't rape my hdd. Memory igpu use when encode like 20mb.
Defiasen
Was just streaming for about 3 hours and then my stream went offline. No crashlog or pop-up or anything but I heard a "ding" noise.
12:51:31: =====Stream Start: 2013-09-09, 12:51:31===============================================
12:51:31:   Multithreaded optimizations: On
12:51:31:   Base resolution: 1920x1080
12:51:31:   Output resolution: 960x540
12:51:31: ------------------------------------------
12:51:31: Loading up D3D10 on NVIDIA GeForce GTX 260...
12:51:31: Audio Format: 44100hz
12:51:31: Playback device {0.0.0.00000000}.{50f213d2-c701-4aa8-a02c-c7219f06fb01}
12:51:31: Using desktop audio input: Speakers (High Definition Audio Device)
12:51:31: Using auxilary audio input: Microphone (High Definition Audio Device)
12:51:31: Audio Encoding: AAC
12:51:31:     bitrate: 96
12:51:31: Using Window Capture
12:51:31: Using text output
12:51:31: Using bitmap image
12:51:31: Using graphics capture
12:51:31: Video Encoding: x264
12:51:31:     fps: 30
12:51:31:     width: 960, height: 540
12:51:31:     preset: veryfast
12:51:31:     CBR: yes
12:51:31:     CFR: yes
12:51:31:     max bitrate: 1600
12:51:31:     buffer size: 1600
12:51:31: MMDeviceAudioSource: Frequency for device 'Speakers (High Definition Audio Device)' is 352800, samples per sec is 44100
12:51:31: MMDeviceAudioSource: Frequency for device 'Microphone (High Definition Audio Device)' is 352800, samples per sec is 44100
12:51:32: SharedTexCapture hooked
12:51:33: Using RTMP service: Twitch / Justin.tv
12:51:33:   Server selection: rtmp://live.justin.tv/app
12:51:33:   Interface: Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) (ethernet, 1000 mbps)
12:51:34: SO_SNDBUF was at 8192
12:51:34: SO_SNDBUF is now 65536
13:47:49: RTMPPublisher::Socketloop: Increasing send buffer to ISB 262144 (buffer: 9275 / 217088)
15:03:02: RTMPPublisher::SocketLoop: Aborting due to FD_CLOSE, error 0
15:03:03: Total frames encoded: 236738, total frames duplicated 99 (0.04%)
15:03:03: Total frames rendered: 236730, number of late frames: 14 (0.01%) (it's okay for some frames to be late)
15:03:04: Number of times waited to send: 0, Waited for a total of 0 bytes
15:03:04: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
15:03:04:
15:03:04: Profiler results:
15:03:04:
15:03:04: ==============================================================
15:03:04: video thread frame - [100%] [avg time: 11.653 ms (cpu time: avg 2.876 ms, total 681038 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0515%]
15:03:04: | frame preprocessing and rendering - [38.9%] [avg time: 4.536 ms (cpu time: avg 1.072 ms, total 253782 ms)] [avg calls per frame: 1] [children: 36%] [unaccounted: 2.91%]
15:03:04: | | scene->Preprocess - [36%] [avg time: 4.197 ms (cpu time: avg 0.813 ms, total 192692 ms)] [avg calls per frame: 1]
15:03:04: | GPU download and color conversion - [61%] [avg time: 7.111 ms (cpu time: avg 1.798 ms, total 425867 ms)] [avg calls per frame: 1] [children: 60.6%] [unaccounted: 0.42%]
15:03:04: | | flush - [0.601%] [avg time: 0.07 ms (cpu time: avg 0.036 ms, total 8704.86 ms)] [avg calls per frame: 1]
15:03:04: | | CopyResource - [60%] [avg time: 6.986 ms (cpu time: avg 1.742 ms, total 412513 ms)] [avg calls per frame: 1]
15:03:04: | | conversion to 4:2:0 - [0.0515%] [avg time: 0.006 ms (cpu time: avg 0.005 ms, total 1232.41 ms)] [avg calls per frame: 1]
15:03:04: | Convert444Threads - [572%] [avg time: 66.667 ms (cpu time: avg 0.965 ms, total 228495 ms)] [avg calls per frame: 2]
15:03:04: encoder thread frame - [100%] [avg time: 1.071 ms (cpu time: avg 0.409 ms, total 96970.2 ms)] [avg calls per frame: 1]
15:03:04:
15:03:04: =====Stream End: 2013-09-09, 15:03:04=================================================
15:03:09: Using fixed low latency mode, factor 20
15:03:09: =====Stream Start: 2013-09-09, 15:03:09===============================================
15:03:09:   Multithreaded optimizations: On
15:03:09:   Base resolution: 1920x1080
15:03:09:   Output resolution: 960x540
15:03:09: ------------------------------------------
15:03:09: Loading up D3D10 on NVIDIA GeForce GTX 260...
15:03:10: ------------------------------------------
15:03:10: Audio Format: 44100hz
15:03:10: Playback device {0.0.0.00000000}.{50f213d2-c701-4aa8-a02c-c7219f06fb01}
15:03:10: Using desktop audio input: Speakers (High Definition Audio Device)
15:03:10: Using auxilary audio input: Microphone (High Definition Audio Device)
15:03:10: Audio Encoding: AAC
15:03:10:     bitrate: 96
15:03:10: Using Window Capture
15:03:10: Using text output
15:03:10: Using bitmap image
15:03:10: Using graphics capture
15:03:10: Video Encoding: x264
15:03:10:     fps: 30
15:03:10:     width: 960, height: 540
15:03:10:     preset: veryfast
15:03:10:     CBR: yes
15:03:10:     CFR: yes
15:03:10:     max bitrate: 1600
15:03:10:     buffer size: 1600
15:03:10: MMDeviceAudioSource: Frequency for device 'Speakers (High Definition Audio Device)' is 352800, samples per sec is 44100
15:03:10: MMDeviceAudioSource: Frequency for device 'Microphone (High Definition Audio Device)' is 352800, samples per sec is 44100
15:03:10: SharedTexCapture hooked
15:03:12: Using RTMP service: Twitch / Justin.tv
15:03:12:   Server selection: rtmp://live.justin.tv/app
15:03:12:   Interface: Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) (ethernet, 1000 mbps)
15:03:13: SO_SNDBUF was at 8192
15:03:13: SO_SNDBUF is now 65536
15:07:20: Total frames encoded: 7473, total frames duplicated 10 (0.13%)
15:07:20: Total frames rendered: 7475, number of late frames: 2 (0.03%) (it's okay for some frames to be late)
15:07:20: RTMPPublisher::SocketLoop: Graceful loop exit
15:07:20: Number of times waited to send: 0, Waited for a total of 0 bytes
15:07:20: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
15:07:20:
15:07:20: Profiler results:
15:07:20:
15:07:20: ==============================================================
15:07:20: video thread frame - [100%] [avg time: 13.239 ms (cpu time: avg 2.825 ms, total 21122.5 ms)] [avg calls per frame: 1] [children: 100%] [unaccounted: 0.0302%]
15:07:20: | frame preprocessing and rendering - [35.2%] [avg time: 4.662 ms (cpu time: avg 0.899 ms, total 6723.64 ms)] [avg calls per frame: 1] [children: 32.7%] [unaccounted: 2.47%]
15:07:20: | | scene->Preprocess - [32.7%] [avg time: 4.335 ms (cpu time: avg 0.657 ms, total 4914.03 ms)] [avg calls per frame: 1]
15:07:20: | GPU download and color conversion - [64.8%] [avg time: 8.573 ms (cpu time: avg 1.92 ms, total 14352.1 ms)] [avg calls per frame: 1] [children: 63.9%] [unaccounted: 0.899%]
15:07:20: | | flush - [0.468%] [avg time: 0.062 ms (cpu time: avg 0.045 ms, total 343.201 ms)] [avg calls per frame: 1]
15:07:20: | | CopyResource - [63.3%] [avg time: 8.384 ms (cpu time: avg 1.849 ms, total 13821.7 ms)] [avg calls per frame: 1]
15:07:20: | | conversion to 4:2:0 - [0.0604%] [avg time: 0.008 ms (cpu time: avg 0.006 ms, total 46.801 ms)] [avg calls per frame: 1]
15:07:20: | Convert444Threads - [503%] [avg time: 66.643 ms (cpu time: avg 1.051 ms, total 7862.45 ms)] [avg calls per frame: 2]
15:07:20: encoder thread frame - [100%] [avg time: 1.158 ms (cpu time: avg 0.637 ms, total 4758.03 ms)] [avg calls per frame: 1]
15:07:20:
15:07:20: =====Stream End: 2013-09-09, 15:07:20=================================================
Lain
Forum Admin
Lain
Forum Moderator
Developer
If there's an issue with quicksync message palana about it with logs and such to try to help him debug the issue.
That being said, I'm personally not officially supporting framerates higher than 60 just simply because the vast majority of people who will actually be viewing such videos/streams will be on 60hz screens at most. It requires more unnecessary encoding power for the streamer/recorder and more unnecessary decoding power for viewers. And things like youtube will transcoder it away anyway back to 30/60fps.
That's why the "allow 60-120 fps" option is in advanced, it's because I just can't really officially support it working by default. If you are the gamer, you may need 120fps to play the game, but if you are simply a viewer, 120fps is overkill for just watching someone game, it's not "needed". That being said, if you -really- want to do it, and you can get it working, that's fine, but understand my reasoning for not really paying as much attention to it. I've just got more important things to deal with unfortunately.
And if you want to continue this discussion, please do so on the suggestions forum or questions forum perhaps. I'd like to keep this thread about the test build and want to find bugs/issues for the new code, not whether it's working properly with 120fps with quicksync on.
EDIT: I would like to add that although one could hypothetically say 60 fps is not needed either by that same logic, I feel that 120 over 60 has far greater diminishing returns than 60 over 30. Almost everyone can watch 60fps. However, very few can actually realistically watch something over 60fps (in terms of common monitor capability).
HomeWorld
Developer
12:51:31:     fps: 30
12:51:31:     CBR: yes
12:51:31:     CFR: yes
15:03:04:
15:03:04:
15:03:04:
15:03:10:     fps: 30
15:03:10:     CBR: yes
15:03:10:     CFR: yes
15:07:20:
15:07:20:
15:07:20:
The only "ding" you will hear caused by OBS it's when the connection to the streaming server is lost and a reconnect is about to be attempted. Also a dialog will be shown for about 10 seconds (a countdown till reconnect is attempted).
Otherwise the "ding" you heard may be caused by something else. Question, did the stream resumed or OBS stopped working?
Also, please include full log if possible.
Defiasen
12:07:01: Failed to load plugin plugins/SC2SceneSwitcher.dll, 193
12:36:20: Open Broadcaster Software v0.56.03 MADNESS - 64bit ( ^ω^)
12:36:20: -------------------------------
12:36:20: CPU Name: AMD Phenom(tm) II X4 965 Processor
12:36:20: CPU Speed: 3422MHz
12:36:20: Physical Memory:  4093MB Total, 2311MB Free
12:36:20: stepping id: 3, model 4, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 4, total cores 4
12:36:20: monitor 1: pos={0, 0}, size={1920, 1080}
12:36:20: Windows Version: 6.1 Build 7601 S
12:36:20: Aero is Enabled
12:36:20: OBS Modules:
12:36:20: Base Address     Module
12:36:20: 000000003F390000 OBS.exe
12:36:20: 00000000F4E00000 OBSApi.dll
12:36:20: 00000000FA290000 DShowPlugin.dll
12:36:20: 00000000FB200000 GraphicsCapture.dll
12:36:20: 00000000FAB50000 NoiseGate.dll
12:36:20: 00000000FADC0000 PSVPlugin.dll
12:36:20: 00000000FA510000 scenesw.dll
12:36:20: ------------------------------------------
12:36:20: Adapter 1
12:36:20:   Video Adapter: NVIDIA GeForce GTX 260
12:36:20:   Video Adapter Dedicated Video Memory: 919994368
12:36:20:   Video Adapter Shared System Memory: 1877766144
12:36:20: =====Stream Start: 2013-09-09, 12:36:20===============================================
12:36:20:   Multithreaded optimizations: On
12:36:20:   Base resolution: 1920x1080
12:36:20:   Output resolution: 960x540
12:36:20: Loading up D3D10 on NVIDIA GeForce GTX 260...
12:36:21: ------------------------------------------
12:36:21: Audio Format: 44100hz
12:36:21: Playback device {0.0.0.00000000}.{50f213d2-c701-4aa8-a02c-c7219f06fb01}
12:36:21: Using desktop audio input: Speakers (High Definition Audio Device)
12:36:21: Using auxilary audio input: Microphone (High Definition Audio Device)
12:36:21: Audio Encoding: AAC
12:36:21:     bitrate: 96
12:36:21: Using Window Capture
12:36:21: Using text output
12:36:21: Using bitmap image
12:36:21: Using graphics capture
12:36:21: Video Encoding: x264
12:36:21:     fps: 30
12:36:21:     width: 960, height: 540
12:36:21:     preset: veryfast
12:36:21:     CBR: yes
12:36:21:     CFR: yes
12:36:21:     max bitrate: 1600
12:36:21:     buffer size: 1600
12:36:21: MMDeviceAudioSource: Frequency for device 'Speakers (High Definition Audio Device)' is 352800, samples per sec is 44100
12:36:21: MMDeviceAudioSource: Frequency for device 'Microphone (High Definition Audio Device)' is 352800, samples per sec is 44100
12:36:22: SharedTexCapture hooked
12:36:22:
12:36:22: Profiler result for the last frame:
12:36:22: ==============================================================
12:36:22: video thread frame - [time: 25.231 ms (cpu time: 0 ms)]
12:36:22: | frame preprocessing and rendering - [time: 25.185 ms (cpu time: 0 ms)]
12:36:22: | | scene->Preprocess - [time: 8.86 ms (cpu time: 0 ms)]
12:36:22: | GPU download and color conversion - [time: 0.044 ms (cpu time: 0 ms)]
12:36:22: | | flush - [time: 0.042 ms (cpu time: 0 ms)]
12:36:22:
12:36:32: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:36:32:   New Scene
12:36:38: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:36:38:   New Scene
12:36:38: Using graphics capture
12:36:38: SharedTexCapture hooked
12:36:40: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:36:40:   New Scene
12:36:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:36:46:   New Scene
12:36:46: Using graphics capture
12:36:47: SharedTexCapture hooked
12:38:05: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:38:05:   New Scene
12:38:05: Using graphics capture
12:38:08: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:38:08:   New Scene
12:38:08: Using graphics capture
12:38:10: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:38:10:   New Scene
12:38:10: Using graphics capture
12:38:11: SharedTexCapture hooked
12:38:12: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:38:12:   New Scene
12:38:12: Using graphics capture
12:38:13: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:38:13:   New Scene
12:38:17: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:38:17:   New Scene
12:38:17: Using graphics capture
12:38:17: SharedTexCapture hooked
12:38:19: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:38:19:   New Scene
12:38:19: Using graphics capture
12:38:19:   New Scene
12:38:19:   New Scene
12:38:21: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:38:21:   New Scene
12:38:22: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:38:22:   New Scene
12:38:22: Using graphics capture
12:38:22:   New Scene
12:38:22: SharedTexCapture hooked
12:38:24: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:38:24:   New Scene
12:38:24: Using graphics capture
12:38:31: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:38:31:   New Scene
12:38:31: Using graphics capture
12:38:39: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:38:39:   New Scene
12:38:39: Using graphics capture
12:39:07: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:39:07:   New Scene
12:39:07: Using graphics capture
12:39:23: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:39:23:   New Scene
12:39:23: Using graphics capture
12:39:53: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:39:53:   New Scene
12:39:53: Using graphics capture
12:39:53: SharedTexCapture hooked
12:50:05: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:50:05:   New Scene
12:50:05: Using graphics capture
12:50:08: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:50:08:   New Scene
12:50:08: Using graphics capture
12:50:08: SharedTexCapture hooked
12:50:09: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:50:09:   New Scene
12:50:09: Using graphics capture
12:50:14: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:50:14:   New Scene
12:50:14: Using graphics capture
12:50:14: SharedTexCapture hooked
12:51:02: Total frames encoded: 26412, total frames duplicated 7 (0.03%)
12:51:02: Total frames rendered: 26413, number of late frames: 1 (0.00%) (it's okay for some frames to be late)
12:51:02:
12:51:02: Profiler results:
12:51:02:
12:51:02: ==============================================================
12:51:02: video thread frame - [100%] [avg time: 5.542 ms (cpu time: avg 2.594 ms, total 68515.6 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0722%]
12:51:02: | frame preprocessing and rendering - [45.3%] [avg time: 2.512 ms (cpu time: avg 1.375 ms, total 36332.6 ms)] [avg calls per frame: 1] [children: 36.6%] [unaccounted: 8.77%]
12:51:02: | | scene->Preprocess - [36.6%] [avg time: 2.026 ms (cpu time: avg 1.24 ms, total 32760.2 ms)] [avg calls per frame: 1]
12:51:02: | GPU download and color conversion - [54.6%] [avg time: 3.026 ms (cpu time: avg 1.215 ms, total 32105 ms)] [avg calls per frame: 1] [children: 54.4%] [unaccounted: 0.198%]
12:51:02: | | flush - [0.902%] [avg time: 0.05 ms (cpu time: avg 0.041 ms, total 1107.61 ms)] [avg calls per frame: 1]
12:51:02: | | CopyResource - [53.1%] [avg time: 2.943 ms (cpu time: avg 1.16 ms, total 30654.2 ms)] [avg calls per frame: 1]
12:51:02: | | conversion to 4:2:0 - [0.397%] [avg time: 0.022 ms (cpu time: avg 0.006 ms, total 171.601 ms)] [avg calls per frame: 1]
12:51:02: | Convert444Threads - [1.2e+003%] [avg time: 66.66 ms (cpu time: avg 1.233 ms, total 32573 ms)] [avg calls per frame: 2]
12:51:02: encoder thread frame - [100%] [avg time: 0.911 ms (cpu time: avg 0.056 ms, total 1482.01 ms)] [avg calls per frame: 1]
12:51:02:
12:51:02: =====Stream End: 2013-09-09, 12:51:02=================================================
12:51:31: Using fixed low latency mode, factor 20
12:51:31:     fps: 30
12:51:31:     CBR: yes
12:51:31:     CFR: yes
15:03:04:
15:03:04:
15:03:04:
15:03:10:     fps: 30
15:03:10:     CBR: yes
15:03:10:     CFR: yes
15:07:20:
15:07:20:
15:07:20:
I believe that's the full log. As for whether it resumed, I don't think it did. I had to manually restart it (Using bind) as none of my viewers told me I went offline in chat.
dehixem
Hey there, OBS is really getting on my nerves lately. I don't know what you guys changed since 0.56 but I just can't do local recordings without fearing the software will just crash when I hit the stop button.
It's just not reliable anymore. I lose all my footage and have to start over (several times?). I know using .flv would prevent the footage loss, but seriously, flv to mp4 conversion is time consuming and not 100% reliable (desyncs if you lose just a couple frames).
Please look into this,
Cheers.
OBS has encountered an unhandled exception and has terminated. If you are able to
reproduce this crash, please submit this crash report on the forums at
http://www.obsproject.com/ - include the contents of this crash log and the
minidump .dmp file (if available) as well as your regular OBS log files and
a description of what you were doing at the time of the crash.
This crash appears to have occured in the 'c:\windows\system32\kernelbase.dll' module.
**** UNHANDLED EXCEPTION: 80000003
Fault address: 000007FEFD053C72 (c:\windows\system32\kernelbase.dll)
OBS version: Open Broadcaster Software v0.554b
Windows version: 6.1 (Build 7600)
CPU: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
Crashing thread stack trace:
000000000024EBB8 000007FEFD053C72 000007FEE56C5870 000000000000EA60 000000000024EB18 000000000024ED70 kernelbase.dll!0x7fefd053c72
000000000024EBC0 000007FEE553D323 0000000000001389 0000000076E09AA6 000000000024EC38 0000000200000030 obsapi.dll!OSTerminateThread+0x33
000000000024EBF0 000000013FD9D999 0000000000001389 000000000024ED70 0000000000000111 0000000000000000 obs.exe!OBS::Stop+0x59
000000000024EC70 000000013FDBDA8E 0000000000000070 FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF 0000000076E09B43 obs.exe!OBS::OBSProc+0xa8e
000000000024EE00 0000000076E09BD1 0000000001095470 000000013FDBD000 00000000FFFFFED1 000000000004122A user32.dll!0x76e09bd1
000000000024EEC0 0000000076E06AA8 0000000000190AD6 0000000000000111 0000000000001389 000007FEFB5E0A29 user32.dll!0x76e06aa8
000000000024EF50 0000000076E06BAD 0000000004876620 0000000000000001 0000000000000000 0000000000000001 user32.dll!0x76e06bad
000000000024EFA0 000007FEFB5E0BBF 000000000004122A 0000000000000001 0000000004876620 000007FEFE492421 comctl32.dll!0x7fefb5e0bbf
000000000024EFE0 000007FEFB5E47FE 000000000000FF00 0000000000030000 0000000000000202 0000000000000000 comctl32.dll!0x7fefb5e47fe
000000000024F0A0 0000000076E09BD1 000000000024F388 000007FEFB5E3B20 0000000001095470 0000000001093210 user32.dll!0x76e09bd1
000000000024F160 0000000076E098DA 0000000000000000 0000000000000000 000007FEFB5E3B20 0000000000000001 user32.dll!0x76e098da
000000000024F1E0 0000000076E067C2 000000000D760327 000000000D760327 000007FEFB5BF450 0000000000281000 user32.dll!0x76e067c2
000000000024F270 000000013FD91CD9 0000000000000000 0000000000000000 000000013FD70000 0000000000000000 obs.exe!WinMain+0x9c9
000000000024F810 000000013FE07150 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!strstr+0x1ac
000000000024F8C0 0000000076F0652D 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x76f0652d
000000000024F8F0 000000007703C541 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7703c541
A minidump was saved to C:\Users\Kevin\AppData\Roaming\OBS\crashDumps\OBSCrashDump2013-09-11_1.dmp.
Please include this file when posting a crash report.
List of loaded modules:
Base Address                      Module
PS:
Here is the dump : https://mega.co.nz/#!95gB2KoS!Na7lbGg55 ... XIDwRXaT1Q
The "upload attachment" module of the obsforum is broken and redirects to a dead page each time I try to use it. So please don't just ignore this because you have to download a 1mb dump.
Lain
Forum Admin
Lain
Forum Moderator
Developer
Well if possible don't let it annoy you -- it's just a test version after all. Thank you for the dump though, I'll take a look to see where it's freezing in the thread.
Crashes are what I've been needing to be honest
Spyrunite
This build has been working perfectly for me so far, so perfectly in fact, that I literally can't use the default version of OBS. Whenever I try to it makes the stream just a green screen. Test build works perfect for me though.
Log of normal build
23:08:11: Open Broadcaster Software v0.554b - 32bit (´・ω・`)
23:08:11: -------------------------------
23:08:11: CPU Name: AMD FX(tm)-6100 Six-Core Processor
23:08:11: CPU Speed: 3315MHz
23:08:11: Physical Memory:  4095MB Total, 4095MB Free
23:08:11: stepping id: 2, model 1, family 15, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 6, total cores 3
23:08:11: monitor 1: pos={1920, 0}, size={1280, 1024}
23:08:11: monitor 2: pos={0, 0}, size={1920, 1080}
23:08:11: Windows Version: 6.1 Build 7601 S
23:08:11: Aero is Disabled
23:08:11: OBS Modules:
23:08:11: Base Address     Module
23:08:11: 00B20000         OBS.exe
23:08:11: 0F670000         OBSApi.dll
23:08:11: 51E10000         DShowPlugin.dll
23:08:11: 51B90000         GraphicsCapture.dll
23:08:11: 645A0000         NoiseGate.dll
23:08:11: 51A70000         PSVPlugin.dll
23:08:11: ------------------------------------------
23:08:11: Adapter 1
23:08:11:   Video Adapter: NVIDIA GeForce GTX 560
23:08:11:   Video Adapter Dedicated Video Memory: 2096562176
23:08:11:   Video Adapter Shared System Memory: 2147364864
23:08:11: =====Stream Start: 2013-09-02, 23:08:11===============================================
23:08:11:   Multithreaded optimizations: On
23:08:11:   Base resolution: 1920x1080
23:08:11:   Output resolution: 960x540
23:08:11: Loading up D3D10 on NVIDIA GeForce GTX 560...
23:08:11: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
23:08:11: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
23:08:11: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DownscaleBilinear1YUV.pShader.blob
23:08:11: Playback device Default
23:08:11: Using desktop audio input: Speakers (Realtek High Definition Audio)
23:08:11: Using auxilary audio input: Microphone (4- ATR USB microphone )
23:08:11: Audio Encoding: AAC
23:08:11:     bitrate: 160
23:08:11: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
23:08:11: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
23:08:11: Using Window Capture
23:08:11: Using graphics capture
23:08:11: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
23:08:11: Video Encoding: x264
23:08:11:     fps: 30
23:08:11:     width: 960, height: 540
23:08:11:     preset: veryfast
23:08:11:     CBR: yes
23:08:11:     CFR: no
23:08:11:     max bitrate: 1750
23:08:11:     buffer size: 1750
23:08:11: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
23:08:11: MMDeviceAudioSource: Frequency for device 'Microphone (4- ATR USB microphone )' is 352800, samples per sec is 44100
23:08:11: Audio timestamp for device 'Microphone (4- ATR USB microphone )' was behind target timestamp by 27!  Had to delete audio segment.
23:08:11:
23:08:11: Audio timestamp for device 'Microphone (4- ATR USB microphone )' was behind target timestamp by 17!  Had to delete audio segment.
23:08:11:
23:08:11: Audio timestamp for device 'Microphone (4- ATR USB microphone )' was behind target timestamp by 7!  Had to delete audio segment.
23:08:11:
23:08:13: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
23:08:13:   New Scene
23:08:13: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
23:08:13: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
23:08:13: Using bitmap image
23:09:24: Total frames rendered: 2172, number of late frames: 2 (0.09%) (it's okay for some frames to be late)
23:09:24:
23:09:24: Profiler results:
23:09:24:
23:09:24: ==============================================================
23:09:24: frame - [100%] [avg time: 1.989 ms (cpu time: avg 1.738 ms, total 3775.22 ms)] [avg calls per frame: 1] [children: 99.6%] [unaccounted: 0.352%]
23:09:24: | frame preprocessing and rendering - [40.7%] [avg time: 0.81 ms (cpu time: avg 0.682 ms, total 1482.01 ms)] [avg calls per frame: 1] [children: 0.754%] [unaccounted: 40%]
23:09:24: | | scene->Preprocess - [0.754%] [avg time: 0.015 ms (cpu time: avg 0.014 ms, total 31.2 ms)] [avg calls per frame: 1]
23:09:24: | video encoding and uploading - [58.9%] [avg time: 1.172 ms (cpu time: avg 1.048 ms, total 2277.61 ms)] [avg calls per frame: 1] [children: 57.2%] [unaccounted: 1.71%]
23:09:24: | | flush - [5.03%] [avg time: 0.1 ms (cpu time: avg 0.079 ms, total 171.601 ms)] [avg calls per frame: 1]
23:09:24: | | CopyResource - [1.01%] [avg time: 0.02 ms (cpu time: avg 0.028 ms, total 62.4 ms)] [avg calls per frame: 0]
23:09:24: | | conversion to 4:2:0 - [1.21%] [avg time: 0.024 ms (cpu time: avg 0.007 ms, total 15.6 ms)] [avg calls per frame: 0]
23:09:24: | | call to encoder - [49.9%] [avg time: 0.992 ms (cpu time: avg 0.912 ms, total 1981.21 ms)] [avg calls per frame: 0]
23:09:24: | | sending stuff out - [0.101%] [avg time: 0.002 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
23:09:24: | Convert444Threads - [1.66e+003%] [avg time: 33.086 ms (cpu time: avg 0.926 ms, total 2012.41 ms)] [avg calls per frame: 0]
23:09:24:
23:09:24: =====Stream End: 2013-09-02, 23:09:24================================================
Log of Madness build
18:13:04: Open Broadcaster Software v0.554b - 32bit (´・ω・`)
18:13:04: -------------------------------
18:13:04: CPU Name: AMD FX(tm)-6100 Six-Core Processor
18:13:04: CPU Speed: 3315MHz
18:13:04: Physical Memory:  4095MB Total, 4095MB Free
18:13:04: stepping id: 2, model 1, family 15, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 6, total cores 3
18:13:04: monitor 1: pos={1920, 0}, size={1280, 1024}
18:13:04: monitor 2: pos={0, 0}, size={1920, 1080}
18:13:04: Windows Version: 6.1 Build 7601 S
18:13:04: Aero is Disabled
18:13:04: OBS Modules:
18:13:04: Base Address     Module
18:13:04: 01370000         OBS.exe
18:13:04: 505B0000         OBSApi.dll
18:13:04: 51E10000         DShowPlugin.dll
18:13:04: 51EB0000         GraphicsCapture.dll
18:13:04: 51F00000         NoiseGate.dll
18:13:04: 51B90000         PSVPlugin.dll
18:13:04: ------------------------------------------
18:13:04: Adapter 1
18:13:04:   Video Adapter: NVIDIA GeForce GTX 560
18:13:04:   Video Adapter Dedicated Video Memory: 2096562176
18:13:04:   Video Adapter Shared System Memory: 2147364864
18:13:04: =====Stream Start: 2013-09-02, 18:13:04===============================================
18:13:04:   Multithreaded optimizations: On
18:13:04:   Base resolution: 1920x1080
18:13:04:   Output resolution: 960x540
18:13:04: Loading up D3D10 on NVIDIA GeForce GTX 560...
18:13:04: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
18:13:04: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
18:13:04: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DownscaleBilinear1YUV.pShader.blob
18:13:04: Playback device Default
18:13:04: Using desktop audio input: Speakers (Realtek High Definition Audio)
18:13:04: Using auxilary audio input: Microphone (4- ATR USB microphone )
18:13:04: Audio Encoding: AAC
18:13:04:     bitrate: 160
18:13:04: Using graphics capture
18:13:04: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:13:04: Video Encoding: x264
18:13:04:     fps: 30
18:13:04:     width: 960, height: 540
18:13:04:     preset: veryfast
18:13:04:     CBR: yes
18:13:04:     CFR: no
18:13:04:     max bitrate: 1750
18:13:04:     buffer size: 1750
18:13:04: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
18:13:04: MMDeviceAudioSource: Frequency for device 'Microphone (4- ATR USB microphone )' is 352800, samples per sec is 44100
18:13:05: SharedTexCapture hooked
18:13:05: Audio timestamp for device 'Microphone (4- ATR USB microphone )' was behind target timestamp by 17!  Had to delete audio segment.
18:13:05:
18:13:05: Audio timestamp for device 'Microphone (4- ATR USB microphone )' was behind target timestamp by 7!  Had to delete audio segment.
18:13:05:
18:13:06: Using RTMP service: Twitch / Justin.tv
18:13:06:   Server selection: rtmp://live-ord.justin.tv/app
18:13:06:   Interface: NVIDIA nForce 10/100/1000 Mbps Ethernet  (ethernet, 100 mbps)
18:13:07: SO_SNDBUF was at 8192
18:13:07: SO_SNDBUF is now 65536
18:13:09: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 0 / 243712)
18:13:09: RTMPPublisher::Socketloop: Increasing send buffer to ISB 262144 (buffer: 0 / 243712)
18:13:11: RTMPPublisher::Socketloop: Increasing send buffer to ISB 524288 (buffer: 0 / 243712)
18:36:02: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:36:02:   New Scene
18:36:02: ------------------------------------------
18:36:02:     device: Logitech HD Webcam C525,
18:36:02:     device id \\?\usb#vid_046d&pid_0826&mi_02#6&1afb5b45&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:36:02:     chosen type: I420, usingFourCC: false, res: 1600x896 - 1600x896, frameIntervals: 333333-2000000, fourCC: 'I420'
18:36:02:     audio device: Disable,
18:36:02:     audio device id Disabled,
18:36:02:
18:36:02: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/plugins/DShowPlugin/shaders/YUVToRGB.pShader.blob
18:36:02: Using directshow input
18:36:02: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:36:02: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:36:03: Using Window Capture
18:36:03: Using graphics capture
18:36:03: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:36:03: PERFORMANCE WARNING: Scene change took 702 ms, maybe some sources should be global sources?
18:36:03: SharedTexCapture hooked
18:36:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:36:56:   New Scene
18:36:56: Using graphics capture
18:36:56: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:36:56: SharedTexCapture hooked
18:36:58: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:36:58: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:36:58: Using Window Capture
18:37:14: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:37:14: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:37:14: Using Window Capture
18:38:40: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:38:40:   New Scene
18:38:40: ------------------------------------------
18:38:40:     device: Logitech HD Webcam C525,
18:38:40:     device id \\?\usb#vid_046d&pid_0826&mi_02#6&1afb5b45&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:38:40:     chosen type: I420, usingFourCC: false, res: 1600x896 - 1600x896, frameIntervals: 333333-2000000, fourCC: 'I420'
18:38:40:     audio device: Disable,
18:38:40:     audio device id Disabled,
18:38:40:
18:38:40: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/plugins/DShowPlugin/shaders/YUVToRGB.pShader.blob
18:38:40: Using directshow input
18:38:40: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:38:40: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:38:40: Using Window Capture
18:38:40: Using graphics capture
18:38:40: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:38:41: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:38:41: PERFORMANCE WARNING: Scene change took 753 ms, maybe some sources should be global sources?
18:38:41: SharedTexCapture hooked
18:39:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:39:06:   New Scene
18:39:06: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:39:06: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:39:06: Using Window Capture
18:39:06: Using graphics capture
18:39:07: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:39:07: PERFORMANCE WARNING: Scene change took 551 ms, maybe some sources should be global sources?
18:39:07: SharedTexCapture hooked
18:39:08: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:39:08:   New Scene
18:39:08: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:39:08: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:39:08: Using bitmap image
18:39:10: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:39:10:   New Scene
18:39:10: ------------------------------------------
18:39:10:     device: Logitech HD Webcam C525,
18:39:10:     device id \\?\usb#vid_046d&pid_0826&mi_02#6&1afb5b45&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:39:10:     chosen type: I420, usingFourCC: false, res: 1600x896 - 1600x896, frameIntervals: 333333-2000000, fourCC: 'I420'
18:39:10:     audio device: Disable,
18:39:10:     audio device id Disabled,
18:39:10:
18:39:10: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/plugins/DShowPlugin/shaders/YUVToRGB.pShader.blob
18:39:10: Using directshow input
18:39:10: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:39:10: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:39:10: Using Window Capture
18:39:10: Using graphics capture
18:39:10: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:39:10: PERFORMANCE WARNING: Scene change took 635 ms, maybe some sources should be global sources?
18:39:10: SharedTexCapture hooked
18:42:04: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:42:04: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:42:04: Using Monitor Capture
18:47:40: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:47:40:   New Scene
18:47:40: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:47:40: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:47:40: Using Window Capture
18:47:40: Using graphics capture
18:47:40: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:47:40: PERFORMANCE WARNING: Scene change took 641 ms, maybe some sources should be global sources?
18:47:45: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:47:45:   New Scene
18:47:45: ------------------------------------------
18:47:45:     device: Logitech HD Webcam C525,
18:47:45:     device id \\?\usb#vid_046d&pid_0826&mi_02#6&1afb5b45&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:47:45:     chosen type: I420, usingFourCC: false, res: 1600x896 - 1600x896, frameIntervals: 333333-2000000, fourCC: 'I420'
18:47:45:     audio device: Disable,
18:47:45:     audio device id Disabled,
18:47:45:
18:47:45: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/plugins/DShowPlugin/shaders/YUVToRGB.pShader.blob
18:47:45: Using directshow input
18:47:45: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:47:45: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:47:45: Using Window Capture
18:47:45: Using Monitor Capture
18:47:45: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:47:45: PERFORMANCE WARNING: Scene change took 649 ms, maybe some sources should be global sources?
18:47:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:47:46:   New Scene
18:47:46: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:47:46: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:47:46: Using bitmap image
18:47:46: PERFORMANCE WARNING: Scene change took 567 ms, maybe some sources should be global sources?
18:50:10: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:50:10:   New Scene
18:50:10: ------------------------------------------
18:50:10:     device: Logitech HD Webcam C525,
18:50:10:     device id \\?\usb#vid_046d&pid_0826&mi_02#6&1afb5b45&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:50:10:     chosen type: I420, usingFourCC: false, res: 1600x896 - 1600x896, frameIntervals: 333333-2000000, fourCC: 'I420'
18:50:10:     audio device: Disable,
18:50:10:     audio device id Disabled,
18:50:10:
18:50:10: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/plugins/DShowPlugin/shaders/YUVToRGB.pShader.blob
18:50:10: Using directshow input
18:50:10: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:50:10: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:50:10: Using Window Capture
18:50:10: Using Monitor Capture
18:50:10: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:50:10: PERFORMANCE WARNING: Scene change took 661 ms, maybe some sources should be global sources?
Warning -- Capture BitBlt failed (6)..  just so you know
18:52:14: Using graphics capture
18:52:14: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:52:19: SharedTexCapture hooked
18:53:31: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:53:31:   New Scene
18:53:31: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:53:32: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:53:32: Using bitmap image
18:53:32: PERFORMANCE WARNING: Scene change took 531 ms, maybe some sources should be global sources?
18:53:34: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:53:34:   New Scene
18:53:34: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:53:34: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:53:34: Using Window Capture
18:53:34: Using graphics capture
18:53:34: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:53:34: SharedTexCapture hooked
18:53:50: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:53:50:   New Scene
18:53:50: ------------------------------------------
18:53:50:     device: Logitech HD Webcam C525,
18:53:50:     device id \\?\usb#vid_046d&pid_0826&mi_02#6&1afb5b45&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:53:50:     chosen type: I420, usingFourCC: false, res: 1600x896 - 1600x896, frameIntervals: 333333-2000000, fourCC: 'I420'
18:53:50:     audio device: Disable,
18:53:50:     audio device id Disabled,
18:53:50:
18:53:50: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/plugins/DShowPlugin/shaders/YUVToRGB.pShader.blob
18:53:50: Using directshow input
18:53:50: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:53:50: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:53:50: Using Window Capture
18:53:50: Using graphics capture
18:53:50: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:53:51: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:53:51: PERFORMANCE WARNING: Scene change took 675 ms, maybe some sources should be global sources?
18:53:51: SharedTexCapture hooked
18:53:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:53:56:   New Scene
18:53:56: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:53:56: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:53:56: Using bitmap image
18:53:57: PERFORMANCE WARNING: Scene change took 523 ms, maybe some sources should be global sources?
18:53:57: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:53:57:   New Scene
18:53:57: ------------------------------------------
18:53:57:     device: Logitech HD Webcam C525,
18:53:57:     device id \\?\usb#vid_046d&pid_0826&mi_02#6&1afb5b45&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:53:57:     chosen type: I420, usingFourCC: false, res: 1600x896 - 1600x896, frameIntervals: 333333-2000000, fourCC: 'I420'
18:53:57:     audio device: Disable,
18:53:57:     audio device id Disabled,
18:53:57:
18:53:57: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/plugins/DShowPlugin/shaders/YUVToRGB.pShader.blob
18:53:57: Using directshow input
18:53:58: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:53:58: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:53:58: Using Window Capture
18:53:58: Using graphics capture
18:53:58: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:53:58: PERFORMANCE WARNING: Scene change took 669 ms, maybe some sources should be global sources?
18:53:58: SharedTexCapture hooked
18:54:04: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:54:04:   New Scene
18:54:04: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:54:04: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:54:04: Using bitmap image
18:54:04: PERFORMANCE WARNING: Scene change took 527 ms, maybe some sources should be global sources?
18:54:07: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:54:07:   New Scene
18:54:07: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:54:07: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:54:08: Using Window Capture
18:54:08: Using graphics capture
18:54:08: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:54:08: SharedTexCapture hooked
18:54:32: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:54:32:   New Scene
18:54:32: ------------------------------------------
18:54:32:     device: Logitech HD Webcam C525,
18:54:32:     device id \\?\usb#vid_046d&pid_0826&mi_02#6&1afb5b45&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:54:32:     chosen type: I420, usingFourCC: false, res: 1600x896 - 1600x896, frameIntervals: 333333-2000000, fourCC: 'I420'
18:54:32:     audio device: Disable,
18:54:32:     audio device id Disabled,
18:54:32:
18:54:32: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/plugins/DShowPlugin/shaders/YUVToRGB.pShader.blob
18:54:32: Using directshow input
18:54:32: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
18:54:32: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
18:54:32: Using Window Capture
18:54:32: Using graphics capture
18:54:32: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:54:33: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
18:54:33: PERFORMANCE WARNING: Scene change took 646 ms, maybe some sources should be global sources?
18:54:33: SharedTexCapture hooked
19:42:32: Total frames rendered: 160741, number of late frames: 128 (0.08%) (it's okay for some frames to be late)
19:42:32: RTMPPublisher::SocketLoop: Graceful loop exit
19:42:32: Number of times waited to send: 0, Waited for a total of 0 bytes
19:42:32: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
19:42:32:
19:42:32: Profiler results:
19:42:32:
19:42:32: ==============================================================
19:42:32: frame - [100%] [avg time: 4.444 ms (cpu time: avg 3.253 ms, total 522978 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.203%]
19:42:32: | frame preprocessing and rendering - [67%] [avg time: 2.976 ms (cpu time: avg 2.047 ms, total 329147 ms)] [avg calls per frame: 1] [children: 48.4%] [unaccounted: 18.6%]
19:42:32: | | scene->Preprocess - [48.4%] [avg time: 2.15 ms (cpu time: avg 1.335 ms, total 214720 ms)] [avg calls per frame: 1]
19:42:32: | video encoding and uploading - [32.8%] [avg time: 1.459 ms (cpu time: avg 1.201 ms, total 193207 ms)] [avg calls per frame: 1] [children: 32%] [unaccounted: 0.788%]
19:42:32: | | flush - [2.32%] [avg time: 0.103 ms (cpu time: avg 0.071 ms, total 11497.3 ms)] [avg calls per frame: 1]
19:42:32: | | CopyResource - [0.45%] [avg time: 0.02 ms (cpu time: avg 0.019 ms, total 3088.82 ms)] [avg calls per frame: 0]
19:42:32: | | conversion to 4:2:0 - [0.72%] [avg time: 0.032 ms (cpu time: avg 0.007 ms, total 1201.21 ms)] [avg calls per frame: 0]
19:42:32: | | call to encoder - [27.5%] [avg time: 1.223 ms (cpu time: avg 1.049 ms, total 168699 ms)] [avg calls per frame: 0]
19:42:32: | | sending stuff out - [1.04%] [avg time: 0.046 ms (cpu time: avg 0.034 ms, total 5553.63 ms)] [avg calls per frame: 0]
19:42:32: | Convert444Threads - [751%] [avg time: 33.382 ms (cpu time: avg 1.008 ms, total 162132 ms)] [avg calls per frame: 0]
19:42:32:
19:42:32: =====Stream End: 2013-09-02, 19:42:32=================================================
19:42:33: =====Stream Start: 2013-09-02, 19:42:33===============================================
19:42:33:   Multithreaded optimizations: On
19:42:33:   Base resolution: 1920x1080
19:42:33:   Output resolution: 960x540
19:42:33: ------------------------------------------
19:42:33: Loading up D3D10 on NVIDIA GeForce GTX 560...
19:42:33: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
19:42:33: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
19:42:33: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DownscaleBilinear1YUV.pShader.blob
19:42:33: Playback device Default
19:42:33: Using desktop audio input: Speakers (Realtek High Definition Audio)
19:42:33: Using auxilary audio input: Microphone (4- ATR USB microphone )
19:42:33: Audio Encoding: AAC
19:42:33:     bitrate: 160
19:42:33:     device: Logitech HD Webcam C525,
19:42:33:     device id \\?\usb#vid_046d&pid_0826&mi_02#6&1afb5b45&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
19:42:33:     chosen type: I420, usingFourCC: false, res: 1600x896 - 1600x896, frameIntervals: 333333-2000000, fourCC: 'I420'
19:42:33:     audio device: Disable,
19:42:33:     audio device id Disabled,
19:42:33:
19:42:33: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/plugins/DShowPlugin/shaders/YUVToRGB.pShader.blob
19:42:33: Using directshow input
19:42:33: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
19:42:33: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
19:42:33: Using Window Capture
19:42:33: Using graphics capture
19:42:33: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
19:42:34: ------------------------------------------
19:42:34: Video Encoding: x264
19:42:34:     fps: 30
19:42:34:     width: 960, height: 540
19:42:34:     preset: veryfast
19:42:34:     CBR: yes
19:42:34:     CFR: no
19:42:34:     max bitrate: 1750
19:42:34:     buffer size: 1750
19:42:34: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
19:42:34: MMDeviceAudioSource: Frequency for device 'Microphone (4- ATR USB microphone )' is 352800, samples per sec is 44100
19:42:34: SharedTexCapture hooked
19:42:34: Audio timestamp for device 'Microphone (4- ATR USB microphone )' was behind target timestamp by 27!  Had to delete audio segment.
19:42:34:
19:42:34: Audio timestamp for device 'Microphone (4- ATR USB microphone )' was behind target timestamp by 17!  Had to delete audio segment.
19:42:34:
19:42:34: Audio timestamp for device 'Microphone (4- ATR USB microphone )' was behind target timestamp by 7!  Had to delete audio segment.
19:42:34:
19:42:35: Using RTMP service: Twitch / Justin.tv
19:42:35:   Server selection: rtmp://live-ord.justin.tv/app
19:42:35:   Interface: NVIDIA nForce 10/100/1000 Mbps Ethernet  (ethernet, 100 mbps)
19:42:36: SO_SNDBUF was at 8192
19:42:36: SO_SNDBUF is now 65536
19:42:38: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 1126 / 243712)
19:42:40: RTMPPublisher::Socketloop: Increasing send buffer to ISB 262144 (buffer: 0 / 243712)
19:43:49: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
19:43:49: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
19:43:49: Using Monitor Capture
19:47:48: Using graphics capture
19:47:48: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
19:47:48: SharedTexCapture hooked
19:48:30: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
19:48:30:   New Scene
19:48:30: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
19:48:30: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
19:48:30: Using Window Capture
19:48:30: Using graphics capture
19:48:30: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
19:48:31: PERFORMANCE WARNING: Scene change took 543 ms, maybe some sources should be global sources?
19:48:31: SharedTexCapture hooked
19:48:31: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
19:48:31:   New Scene
19:48:31: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
19:48:31: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
19:48:31: Using bitmap image
19:48:34: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
19:48:34:   New Scene
19:48:34: ------------------------------------------
19:48:34:     device: Logitech HD Webcam C525,
19:48:34:     device id \\?\usb#vid_046d&pid_0826&mi_02#6&1afb5b45&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
19:48:34:     chosen type: I420, usingFourCC: false, res: 1600x896 - 1600x896, frameIntervals: 333333-2000000, fourCC: 'I420'
19:48:34:     audio device: Disable,
19:48:34:     audio device id Disabled,
19:48:34:
19:48:34: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/plugins/DShowPlugin/shaders/YUVToRGB.pShader.blob
19:48:34: Using directshow input
19:48:34: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
19:48:34: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
19:48:34: Using Window Capture
19:48:34: Using graphics capture
19:48:34: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
19:48:34: PERFORMANCE WARNING: Scene change took 630 ms, maybe some sources should be global sources?
19:48:34: SharedTexCapture hooked
20:03:30: RTMPPublisher::SocketLoop: Aborting due to FD_CLOSE, error 0
20:03:31: Total frames rendered: 37662, number of late frames: 19 (0.05%) (it's okay for some frames to be late)
20:03:31: Number of times waited to send: 2, Waited for a total of 6262 bytes
20:03:31: Number of b-frames dropped: 11 (0.029%), Number of p-frames dropped: 12 (0.032%), Total 23 (0.061%)
20:03:31:
20:03:31: Profiler results:
20:03:31:
20:03:31: ==============================================================
20:03:31: frame - [100%] [avg time: 5.857 ms (cpu time: avg 4.256 ms, total 160322 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.171%]
20:03:31: | frame preprocessing and rendering - [74.4%] [avg time: 4.357 ms (cpu time: avg 2.97 ms, total 111868 ms)] [avg calls per frame: 1] [children: 59.1%] [unaccounted: 15.2%]
20:03:31: | | scene->Preprocess - [59.1%] [avg time: 3.464 ms (cpu time: avg 2.192 ms, total 82571.3 ms)] [avg calls per frame: 1]
20:03:31: | video encoding and uploading - [25.4%] [avg time: 1.49 ms (cpu time: avg 1.281 ms, total 48266.7 ms)] [avg calls per frame: 1] [children: 24.9%] [unaccounted: 0.546%]
20:03:31: | | flush - [1.55%] [avg time: 0.091 ms (cpu time: avg 0.077 ms, total 2917.22 ms)] [avg calls per frame: 1]
20:03:31: | | CopyResource - [0.341%] [avg time: 0.02 ms (cpu time: avg 0.014 ms, total 561.605 ms)] [avg calls per frame: 0]
20:03:31: | | conversion to 4:2:0 - [0.529%] [avg time: 0.031 ms (cpu time: avg 0.007 ms, total 280.802 ms)] [avg calls per frame: 0]
20:03:31: | | call to encoder - [21.6%] [avg time: 1.263 ms (cpu time: avg 1.134 ms, total 42744.3 ms)] [avg calls per frame: 0]
20:03:31: | | sending stuff out - [0.905%] [avg time: 0.053 ms (cpu time: avg 0.029 ms, total 1107.61 ms)] [avg calls per frame: 0]
20:03:31: | Convert444Threads - [569%] [avg time: 33.352 ms (cpu time: avg 1.044 ms, total 39343.5 ms)] [avg calls per frame: 0]
20:03:31:
20:03:31: =====Stream End: 2013-09-02, 20:03:31=================================================
20:03:41: =====Stream Start: 2013-09-02, 20:03:41===============================================
20:03:41:   Multithreaded optimizations: On
20:03:41:   Base resolution: 1920x1080
20:03:41:   Output resolution: 960x540
20:03:41: ------------------------------------------
20:03:42: Loading up D3D10 on NVIDIA GeForce GTX 560...
20:03:42: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
20:03:42: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
20:03:42: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DownscaleBilinear1YUV.pShader.blob
20:03:42: Playback device Default
20:03:42: ------------------------------------------
20:03:42: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:03:42: Using auxilary audio input: Microphone (4- ATR USB microphone )
20:03:42: Audio Encoding: AAC
20:03:42:     bitrate: 160
20:03:42:     device: Logitech HD Webcam C525,
20:03:42:     device id \\?\usb#vid_046d&pid_0826&mi_02#6&1afb5b45&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
20:03:42:     chosen type: I420, usingFourCC: false, res: 1600x896 - 1600x896, frameIntervals: 333333-2000000, fourCC: 'I420'
20:03:42:     audio device: Disable,
20:03:42:     audio device id Disabled,
20:03:42:
20:03:42: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/plugins/DShowPlugin/shaders/YUVToRGB.pShader.blob
20:03:42: Using directshow input
20:03:42: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
20:03:42: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
20:03:42: Using Window Capture
20:03:42: Using graphics capture
20:03:42: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
20:03:42: Video Encoding: x264
20:03:42:     fps: 30
20:03:42:     width: 960, height: 540
20:03:42:     preset: veryfast
20:03:42:     CBR: yes
20:03:42:     CFR: no
20:03:42:     max bitrate: 1750
20:03:42:     buffer size: 1750
20:03:42: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
20:03:42: MMDeviceAudioSource: Frequency for device 'Microphone (4- ATR USB microphone )' is 352800, samples per sec is 44100
20:03:42: SharedTexCapture hooked
20:03:43: Audio timestamp for device 'Microphone (4- ATR USB microphone )' was behind target timestamp by 27!  Had to delete audio segment.
20:03:43:
20:03:43: Audio timestamp for device 'Microphone (4- ATR USB microphone )' was behind target timestamp by 17!  Had to delete audio segment.
20:03:43:
20:03:43: Audio timestamp for device 'Microphone (4- ATR USB microphone )' was behind target timestamp by 7!  Had to delete audio segment.
20:03:43:
20:03:44: Using RTMP service: Twitch / Justin.tv
20:03:44:   Server selection: rtmp://live-ord.justin.tv/app
20:03:44:   Interface: NVIDIA nForce 10/100/1000 Mbps Ethernet  (ethernet, 100 mbps)
20:03:45: SO_SNDBUF was at 8192
20:03:45: SO_SNDBUF is now 65536
20:03:46: Total frames rendered: 111, number of late frames: 4 (3.60%) (it's okay for some frames to be late)
20:03:47: RTMPPublisher::SocketLoop: Graceful loop exit
20:03:47: Number of times waited to send: 0, Waited for a total of 0 bytes
20:03:47: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:03:47:
20:03:47: Profiler results:
20:03:47:
20:03:47: ==============================================================
20:03:47: frame - [100%] [avg time: 5.786 ms (cpu time: avg 4.356 ms, total 483.603 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.156%]
20:03:47: | frame preprocessing and rendering - [75.6%] [avg time: 4.377 ms (cpu time: avg 3.232 ms, total 358.802 ms)] [avg calls per frame: 1] [children: 31.7%] [unaccounted: 44%]
20:03:47: | | scene->Preprocess - [31.7%] [avg time: 1.834 ms (cpu time: avg 0.843 ms, total 93.601 ms)] [avg calls per frame: 1]
20:03:47: | video encoding and uploading - [24.2%] [avg time: 1.4 ms (cpu time: avg 1.124 ms, total 124.801 ms)] [avg calls per frame: 1] [children: 22.4%] [unaccounted: 1.78%]
20:03:47: | | flush - [2.77%] [avg time: 0.16 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
20:03:47: | | CopyResource - [0.294%] [avg time: 0.017 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
20:03:47: | | conversion to 4:2:0 - [0.328%] [avg time: 0.019 ms (cpu time: avg 0.14 ms, total 15.6 ms)] [avg calls per frame: 0]
20:03:47: | | call to encoder - [18.9%] [avg time: 1.096 ms (cpu time: avg 0.983 ms, total 109.201 ms)] [avg calls per frame: 0]
20:03:47: | | sending stuff out - [0.0864%] [avg time: 0.005 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
20:03:47: | Convert444Threads - [494%] [avg time: 28.56 ms (cpu time: avg 0.983 ms, total 109.2 ms)] [avg calls per frame: 0]
20:03:47:
20:03:47: =====Stream End: 2013-09-02, 20:03:47=================================================
20:03:48: =====Stream Start: 2013-09-02, 20:03:48===============================================
20:03:48:   Multithreaded optimizations: On
20:03:48:   Base resolution: 1920x1080
20:03:48:   Output resolution: 960x540
20:03:48: ------------------------------------------
20:03:48: Loading up D3D10 on NVIDIA GeForce GTX 560...
20:03:48: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
20:03:48: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
20:03:48: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DownscaleBilinear1YUV.pShader.blob
20:03:48: Playback device Default
20:03:48: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:03:48: Using auxilary audio input: Microphone (4- ATR USB microphone )
20:03:48: Audio Encoding: AAC
20:03:48:     bitrate: 160
20:03:48:     device: Logitech HD Webcam C525,
20:03:48:     device id \\?\usb#vid_046d&pid_0826&mi_02#6&1afb5b45&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
20:03:48:     chosen type: I420, usingFourCC: false, res: 1600x896 - 1600x896, frameIntervals: 333333-2000000, fourCC: 'I420'
20:03:48:     audio device: Disable,
20:03:48:     audio device id Disabled,
20:03:48:
20:03:48: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/plugins/DShowPlugin/shaders/YUVToRGB.pShader.blob
20:03:48: Using directshow input
20:03:48: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
20:03:48: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
20:03:48: Using Window Capture
20:03:48: Using graphics capture
20:03:48: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
20:03:48: Video Encoding: x264
20:03:48:     fps: 30
20:03:48:     width: 960, height: 540
20:03:48:     preset: veryfast
20:03:48:     CBR: yes
20:03:48:     CFR: no
20:03:48:     max bitrate: 1750
20:03:48:     buffer size: 1750
20:03:48: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
20:03:48: MMDeviceAudioSource: Frequency for device 'Microphone (4- ATR USB microphone )' is 352800, samples per sec is 44100
20:03:48: SharedTexCapture hooked
20:03:49: Audio timestamp for device 'Microphone (4- ATR USB microphone )' was behind target timestamp by 27!  Had to delete audio segment.
20:03:49:
20:03:49: Audio timestamp for device 'Microphone (4- ATR USB microphone )' was behind target timestamp by 17!  Had to delete audio segment.
20:03:49:
20:03:49: Audio timestamp for device 'Microphone (4- ATR USB microphone )' was behind target timestamp by 7!  Had to delete audio segment.
20:03:49:
20:03:50: Using RTMP service: Twitch / Justin.tv
20:03:50:   Server selection: rtmp://live-ord.justin.tv/app
20:03:50:   Interface: NVIDIA nForce 10/100/1000 Mbps Ethernet  (ethernet, 100 mbps)
20:03:52: SO_SNDBUF was at 8192
20:03:52: SO_SNDBUF is now 65536
20:03:53: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 10590 / 243712)
20:03:55: RTMPPublisher::Socketloop: Increasing send buffer to ISB 262144 (buffer: 0 / 243712)
20:04:16: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
20:04:16:   New Scene
20:04:16: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
20:04:16: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
20:04:16: Using Window Capture
20:04:16: Using graphics capture
20:04:16: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
20:04:16: PERFORMANCE WARNING: Scene change took 569 ms, maybe some sources should be global sources?
20:04:16: SharedTexCapture hooked
20:04:18: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
20:04:18:   New Scene
20:04:18: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
20:04:18: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
20:04:18: Using bitmap image
20:06:08: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
20:06:08:   New Scene
20:06:08: ------------------------------------------
20:06:08:     device: Logitech HD Webcam C525,
20:06:08:     device id \\?\usb#vid_046d&pid_0826&mi_02#6&1afb5b45&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
20:06:08:     chosen type: I420, usingFourCC: false, res: 1600x896 - 1600x896, frameIntervals: 333333-2000000, fourCC: 'I420'
20:06:08:     audio device: Disable,
20:06:08:     audio device id Disabled,
20:06:08:
20:06:08: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/plugins/DShowPlugin/shaders/YUVToRGB.pShader.blob
20:06:08: Using directshow input
20:06:08: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
20:06:08: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
20:06:08: Using Window Capture
20:06:08: Using graphics capture
20:06:08: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
20:06:09: C:/Users/Talon/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
20:06:09: PERFORMANCE WARNING: Scene change took 592 ms, maybe some sources should be global sources?
20:06:09: SharedTexCapture hooked
20:11:39: Capture window 0x00050834 invalid or changing, terminating capture
20:12:28: SharedTexCapture hooked
20:52:50: Total frames rendered: 88125, number of late frames: 26 (0.03%) (it's okay for some frames to be late)
20:52:53: RTMPPublisher::SocketLoop: Graceful loop exit
20:52:54: Number of times waited to send: 0, Waited for a total of 0 bytes
20:52:54: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:52:54:
20:52:54: Profiler results:
20:52:54:
20:52:54: ==============================================================
20:52:54: frame - [100%] [avg time: 3.836 ms (cpu time: avg 3.355 ms, total 295731 ms)] [avg calls per frame: 1] [children: 99.7%] [unaccounted: 0.261%]
20:52:54: | frame preprocessing and rendering - [60%] [avg time: 2.302 ms (cpu time: avg 2.101 ms, total 185236 ms)] [avg calls per frame: 1] [children: 39%] [unaccounted: 21%]
20:52:54: | | scene->Preprocess - [39%] [avg time: 1.496 ms (cpu time: avg 1.359 ms, total 119762 ms)] [avg calls per frame: 1]
20:52:54: | video encoding and uploading - [39.7%] [avg time: 1.524 ms (cpu time: avg 1.25 ms, total 110183 ms)] [avg calls per frame: 1] [children: 38.9%] [unaccounted: 0.808%]
20:52:54: | | flush - [2.55%] [avg time: 0.098 ms (cpu time: avg 0.068 ms, total 6068.43 ms)] [avg calls per frame: 1]
20:52:54: | | CopyResource - [0.495%] [avg time: 0.019 ms (cpu time: avg 0.021 ms, total 1856.41 ms)] [avg calls per frame: 0]
20:52:54: | | conversion to 4:2:0 - [0.704%] [avg time: 0.027 ms (cpu time: avg 0.009 ms, total 811.205 ms)] [avg calls per frame: 0]
20:52:54: | | call to encoder - [33.8%] [avg time: 1.298 ms (cpu time: avg 1.107 ms, total 97609.8 ms)] [avg calls per frame: 0]
20:52:54: | | sending stuff out - [1.33%] [avg time: 0.051 ms (cpu time: avg 0.03 ms, total 2683.22 ms)] [avg calls per frame: 0]
20:52:54: | Convert444Threads - [870%] [avg time: 33.371 ms (cpu time: avg 1.054 ms, total 92961 ms)] [avg calls per frame: 0]
20:52:54:
20:52:54: =====Stream End: 2013-09-02, 20:52:54=================================================
Last game capture log:
2013-09-02, 20:12:26: we're booting up:
20:12:26: D3D9 Present
20:12:26: NV Capture available
20:12:26: FBO available
20:12:26: GL Present
20:12:26: (half life scientist) everything..  seems to be in order
20:12:28: D3D9EndScene called
20:12:28: D3DPRESENT_PARAMETERS {
20:12:28: 	BackBufferWidth: 1920
20:12:28: 	BackBufferHeight: 1080
20:12:28: 	BackBufferFormat: D3DFMT_A8R8G8B8
20:12:28: 	BackBufferCount: 1
20:12:28: 	MultiSampleType: D3DMULTISAMPLE_8_SAMPLES
20:12:28: 	MultiSampleQuality: 0
20:12:28: 	SwapEffect: D3DSWAPEFFECT_DISCARD
20:12:28: 	hDeviceWindow: 132444
20:12:28: 	Windowed: true
20:12:28: 	EnableAutoDepthStencil: true
20:12:28: 	AutoDepthStencilFormat: D3DFMT_D24S8
20:12:28: 	Flags: None
20:12:28: 	FullScreen_RefreshRateInHz: 0
20:12:28: 	PresentationInterval: 2147483648
20:12:28: };
20:12:28: successfully set up d3d9 hooks
20:12:28: D3D9Present called
20:12:28: DoD3D9GPUHook: success
20:12:28: D3DSURFACE_DESC {
20:12:28: 	Format: D3DFMT_A8R8G8B8
20:12:28: 	Type: D3DRTYPE_SURFACE
20:12:28: 	Usage: D3DUSAGE_RENDERTARGET
20:12:28: 	Pool: D3DPOOL_DEFAULT
20:12:28: 	Width: 1920
20:12:28: 	Height: 1080
20:12:28: };
20:12:28: successfully capturing d3d9 frames via GPU
20:52:53: ---------------------- Cleared D3D9 Capture ----------------------
20:52:53: received restart event, capturing
20:52:53: DoD3D9GPUHook: success
20:52:53: D3D9EndScene called
20:52:53: D3D9Present called
Lain
Forum Admin
Lain
Forum Moderator
Developer
Re: 0.56.03 MADNESS build - features plus encoding changes
Funny, but did that always happen?
Spyrunite
It has started happening since I first used the madness build, before the normal build worked fine.
Absarn
The stream goes black whenever i start the stream for some reason, usualy helps to stop/start streaming a couple of times. But it's really annoying though.
15:08:12: Open Broadcaster Software v0.56.03 MADNESS - 64bit ( ^ω^)
15:08:12: -------------------------------
15:08:12: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
15:08:12: CPU Speed: 3292MHz
15:08:12: Physical Memory:  8109MB Total, 5985MB Free
15:08:12: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
15:08:12: monitor 1: pos={0, 0}, size={1920, 1080}
15:08:12: monitor 2: pos={1920, 0}, size={1680, 1050}
15:08:12: monitor 3: pos={3600, 0}, size={1024, 768}
15:08:12: Windows Version: 6.1 Build 7600
15:08:12: Aero is Disabled
15:08:12: OBS Modules:
15:08:12: Base Address     Module
15:08:12: 000000003F750000 OBS.exe
15:08:12: 00000000E27E0000 OBSApi.dll
15:08:12: 00000000F1FF0000 DShowPlugin.dll
15:08:12: 00000000F1FC0000 GraphicsCapture.dll
15:08:12: 00000000FB230000 NoiseGate.dll
15:08:12: 00000000FA9A0000 PSVPlugin.dll
15:08:12: ------------------------------------------
15:08:12: Adapter 1
15:08:12:   Video Adapter: NVIDIA GeForce GTX 660 Ti
15:08:12:   Video Adapter Dedicated Video Memory: 2091319296
15:08:12:   Video Adapter Shared System Memory: 2147807232
15:08:12: Adapter 2
15:08:12:   Video Adapter: Intel(R) HD Graphics 3000
15:08:12:   Video Adapter Dedicated Video Memory: 67108864
15:08:12:   Video Adapter Shared System Memory: 1711276032
15:08:12: =====Stream Start: 2013-09-10, 15:08:12===============================================
15:08:12:   Multithreaded optimizations: On
15:08:12:   Base resolution: 1920x1080
15:08:12:   Output resolution: 1280x720
15:08:12: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
15:08:12: Audio Format: 44100hz
15:08:12: Playback device {0.0.0.00000000}.{dce8d686-16b6-41a0-b683-9ffe05bfd313}
15:08:12: Using desktop audio input: Högtalare (Realtek High Definition Audio)
15:08:12: Using auxilary audio input: Mikrofon (Realtek High Definition Audio)
15:08:12: Audio Encoding: AAC
15:08:12:     bitrate: 160
15:08:12: Using text output
15:08:12: Using bitmap image
15:08:12:     device: Logitech HD Webcam C270,
15:08:12:     device id \\?\usb#vid_046d&pid_0825&mi_00#7&20540419&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
15:08:12:     chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000, fourCC: 'I420'
15:08:12:     audio device: Disable,
15:08:12:     audio device id Disabled,
15:08:12:
15:08:13: Using directshow input
15:08:13: Using graphics capture
15:08:15: Found QSV hardware support
15:08:15: ------------------------------------------
15:08:15: QSV version 1.4 using MFX_IMPL_HARDWARE_ANY | MFX_IMPL_VIA_ANY (actual: MFX_IMPL_HARDWARE3 | MFX_IMPL_VIA_D3D9)
15:08:15: Using 13 encode tasks
15:08:15: Video Encoding: QSV
15:08:15:     fps: 60
15:08:15:     width: 1280, height: 720
15:08:15:     target-usage: MFX_TARGETUSAGE_BEST_QUALITY
15:08:15:     CBR: yes
15:08:15:     CFR: yes
15:08:15:     max bitrate: 3000
15:08:15: MMDeviceAudioSource: Frequency for device 'Högtalare (Realtek High Definition Audio)' is 384000, samples per sec is 48000
15:08:15: MMDeviceAudioSource: Frequency for device 'Mikrofon (Realtek High Definition Audio)' is 352800, samples per sec is 44100
15:08:17: ------------------------------------------
15:08:17:     device: AVerMedia HD Capture C985 Bus 2,
15:08:17:     device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&1aa6ed88&0&0009#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
15:08:17:     chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666, fourCC: 'YV12'
15:08:17:
15:08:17:     device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
15:08:17: Using directshow input
15:09:19: Total frames encoded: 3816, total frames duplicated 34 (0.89%)
15:09:19: Total frames rendered: 3793, number of late frames: 3 (0.08%) (it's okay for some frames to be late)
15:09:20:
15:09:20: Profiler results:
15:09:20:
15:09:20: ==============================================================
15:09:20: video thread frame - [100%] [avg time: 3.349 ms (cpu time: avg 1.727 ms, total 6552.04 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.149%]
15:09:20: | frame preprocessing and rendering - [88.3%] [avg time: 2.958 ms (cpu time: avg 1.665 ms, total 6318.04 ms)] [avg calls per frame: 1] [children: 52.5%] [unaccounted: 35.9%]
15:09:20: | | scene->Preprocess - [52.5%] [avg time: 1.757 ms (cpu time: avg 1.32 ms, total 5007.63 ms)] [avg calls per frame: 1]
15:09:20: | GPU download and color conversion - [11.5%] [avg time: 0.386 ms (cpu time: avg 0.061 ms, total 234.001 ms)] [avg calls per frame: 1] [children: 8.18%] [unaccounted: 3.34%]
15:09:20: | | flush - [6.03%] [avg time: 0.202 ms (cpu time: avg 0.02 ms, total 78 ms)] [avg calls per frame: 1]
15:09:20: | | CopyResource - [2%] [avg time: 0.067 ms (cpu time: avg 0.008 ms, total 31.201 ms)] [avg calls per frame: 1]
15:09:20: | | conversion to 4:2:0 - [0.149%] [avg time: 0.005 ms (cpu time: avg 0.012 ms, total 46.8 ms)] [avg calls per frame: 1]
15:09:20: | Convert444Threads - [1e+003%] [avg time: 33.543 ms (cpu time: avg 1.455 ms, total 5522.43 ms)] [avg calls per frame: 2]
15:09:20: encoder thread frame - [100%] [avg time: 0.078 ms (cpu time: avg 0.004 ms, total 15.6 ms)] [avg calls per frame: 1]
15:09:20:
15:09:20: =====Stream End: 2013-09-10, 15:09:20=================================================
15:09:20: =====Stream Start: 2013-09-10, 15:09:20===============================================
15:09:20:   Multithreaded optimizations: On
15:09:20:   Base resolution: 1920x1080
15:09:20:   Output resolution: 1280x720
15:09:20: ------------------------------------------
15:09:20: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
15:09:20: Audio Format: 44100hz
15:09:20: Playback device {0.0.0.00000000}.{dce8d686-16b6-41a0-b683-9ffe05bfd313}
15:09:20: Using desktop audio input: Högtalare (Realtek High Definition Audio)
15:09:20: Using auxilary audio input: Mikrofon (Realtek High Definition Audio)
15:09:20: Audio Encoding: AAC
15:09:20:     bitrate: 160
15:09:20: Using bitmap image
15:09:20:     device: Logitech HD Webcam C270,
15:09:20:     device id \\?\usb#vid_046d&pid_0825&mi_00#7&20540419&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
15:09:20:     chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000, fourCC: 'I420'
15:09:20:     audio device: Disable,
15:09:20:     audio device id Disabled,
15:09:20:
15:09:20: Using directshow input
15:09:20:     device: AVerMedia HD Capture C985 Bus 2,
15:09:20:     device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&1aa6ed88&0&0009#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
15:09:20:     chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666, fourCC: 'YV12'
15:09:20:
15:09:20:     device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
15:09:21: Using directshow input
15:09:22: Found QSV hardware support
15:09:22: ------------------------------------------
15:09:22: QSV version 1.4 using MFX_IMPL_HARDWARE_ANY | MFX_IMPL_VIA_ANY (actual: MFX_IMPL_HARDWARE3 | MFX_IMPL_VIA_D3D9)
15:09:22: Using 13 encode tasks
15:09:22: Video Encoding: QSV
15:09:22:     fps: 60
15:09:22:     width: 1280, height: 720
15:09:22:     target-usage: MFX_TARGETUSAGE_BEST_QUALITY
15:09:22:     CBR: yes
15:09:22:     CFR: yes
15:09:22:     max bitrate: 3000
15:09:22: MMDeviceAudioSource: Frequency for device 'Högtalare (Realtek High Definition Audio)' is 384000, samples per sec is 48000
15:09:22: MMDeviceAudioSource: Frequency for device 'Mikrofon (Realtek High Definition Audio)' is 352800, samples per sec is 44100
15:09:23: Using RTMP service: Twitch / Justin.tv
15:09:23:   Server selection: rtmp://live-arn.justin.tv/app
15:09:23:   Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
15:09:24: SO_SNDBUF was at 8192
15:09:24: SO_SNDBUF is now 65536
15:09:55: Total frames encoded: 1991, total frames duplicated 25 (1.26%)
15:09:55: Total frames rendered: 1977, number of late frames: 3 (0.15%) (it's okay for some frames to be late)
15:09:56: RTMPPublisher::SocketLoop: Graceful loop exit
15:09:56: Number of times waited to send: 0, Waited for a total of 0 bytes
15:09:56: Number of b-frames dropped: 1 (0.054%), Number of p-frames dropped: 0 (0%), Total 1 (0.054%)
15:09:56:
15:09:56: Profiler results:
15:09:56:
15:09:56: ==============================================================
15:09:56: video thread frame - [100%] [avg time: 2.923 ms (cpu time: avg 1.428 ms, total 2823.62 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.103%]
15:09:56: | frame preprocessing and rendering - [71.7%] [avg time: 2.096 ms (cpu time: avg 1.325 ms, total 2620.82 ms)] [avg calls per frame: 1] [children: 58.6%] [unaccounted: 13.1%]
15:09:56: | | scene->Preprocess - [58.6%] [avg time: 1.712 ms (cpu time: avg 1.23 ms, total 2433.62 ms)] [avg calls per frame: 1]
15:09:56: | GPU download and color conversion - [28.2%] [avg time: 0.824 ms (cpu time: avg 0.102 ms, total 202.801 ms)] [avg calls per frame: 1] [children: 21.7%] [unaccounted: 6.5%]
15:09:56: | | flush - [15.8%] [avg time: 0.461 ms (cpu time: avg 0.078 ms, total 156 ms)] [avg calls per frame: 1]
15:09:56: | | CopyResource - [5.64%] [avg time: 0.165 ms (cpu time: avg 0.015 ms, total 31.2 ms)] [avg calls per frame: 1]
15:09:56: | | conversion to 4:2:0 - [0.274%] [avg time: 0.008 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
15:09:56: | Convert444Threads - [1.15e+003%] [avg time: 33.564 ms (cpu time: avg 1.483 ms, total 2932.82 ms)] [avg calls per frame: 2]
15:09:56: encoder thread frame - [100%] [avg time: 0.086 ms (cpu time: avg 0.015 ms, total 31.2 ms)] [avg calls per frame: 1]
15:09:56:
15:09:56: =====Stream End: 2013-09-10, 15:09:56=================================================
15:09:57: =====Stream Start: 2013-09-10, 15:09:57===============================================
15:09:57:   Multithreaded optimizations: On
15:09:57:   Base resolution: 1920x1080
15:09:57:   Output resolution: 1280x720
15:09:57: ------------------------------------------
15:09:57: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
15:09:57: Audio Format: 44100hz
15:09:57: Playback device {0.0.0.00000000}.{dce8d686-16b6-41a0-b683-9ffe05bfd313}
15:09:57: Using desktop audio input: Högtalare (Realtek High Definition Audio)
15:09:57: Using auxilary audio input: Mikrofon (Realtek High Definition Audio)
15:09:57: Audio Encoding: AAC
15:09:57:     bitrate: 160
15:09:57: Using bitmap image
15:09:57:     device: Logitech HD Webcam C270,
15:09:57:     device id \\?\usb#vid_046d&pid_0825&mi_00#7&20540419&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
15:09:57:     chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000, fourCC: 'I420'
15:09:57:     audio device: Disable,
15:09:57:     audio device id Disabled,
15:09:57:
15:09:57: Using directshow input
15:09:57: Using Monitor Capture
15:09:58: Found QSV hardware support
15:09:58: ------------------------------------------
15:09:58: QSV version 1.4 using MFX_IMPL_HARDWARE_ANY | MFX_IMPL_VIA_ANY (actual: MFX_IMPL_HARDWARE3 | MFX_IMPL_VIA_D3D9)
15:09:58: Using 13 encode tasks
15:09:58: Video Encoding: QSV
15:09:58:     fps: 60
15:09:58:     width: 1280, height: 720
15:09:58:     target-usage: MFX_TARGETUSAGE_BEST_QUALITY
15:09:58:     CBR: yes
15:09:58:     CFR: yes
15:09:58:     max bitrate: 3000
15:09:58: MMDeviceAudioSource: Frequency for device 'Högtalare (Realtek High Definition Audio)' is 384000, samples per sec is 48000
15:09:58: MMDeviceAudioSource: Frequency for device 'Mikrofon (Realtek High Definition Audio)' is 352800, samples per sec is 44100
15:09:59: Using RTMP service: Twitch / Justin.tv
15:09:59:   Server selection: rtmp://live-arn.justin.tv/app
15:09:59:   Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
15:10:01: SO_SNDBUF was at 8192
15:10:01: SO_SNDBUF is now 65536
15:10:18: Total frames encoded: 1139, total frames duplicated 16 (1.40%)
15:10:18: Total frames rendered: 1134, number of late frames: 2 (0.18%) (it's okay for some frames to be late)
15:10:19: RTMPPublisher::SocketLoop: Graceful loop exit
15:10:20: Number of times waited to send: 0, Waited for a total of 0 bytes
15:10:20: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
15:10:20:
15:10:20: Profiler results:
15:10:20:
15:10:20: ==============================================================
15:10:20: video thread frame - [100%] [avg time: 5.751 ms (cpu time: avg 3.067 ms, total 3478.82 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0522%]
15:10:20: | frame preprocessing and rendering - [98.7%] [avg time: 5.675 ms (cpu time: avg 2.998 ms, total 3400.82 ms)] [avg calls per frame: 1] [children: 88.8%] [unaccounted: 9.86%]
15:10:20: | | scene->Preprocess - [88.8%] [avg time: 5.108 ms (cpu time: avg 2.476 ms, total 2808.02 ms)] [avg calls per frame: 1]
15:10:20: | GPU download and color conversion - [1.27%] [avg time: 0.073 ms (cpu time: avg 0.068 ms, total 78 ms)] [avg calls per frame: 1] [children: 1.06%] [unaccounted: 0.209%]
15:10:20: | | flush - [0.765%] [avg time: 0.044 ms (cpu time: avg 0.068 ms, total 78 ms)] [avg calls per frame: 1]
15:10:20: | | CopyResource - [0.226%] [avg time: 0.013 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
15:10:20: | | conversion to 4:2:0 - [0.0696%] [avg time: 0.004 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
15:10:20: | Convert444Threads - [582%] [avg time: 33.47 ms (cpu time: avg 1.403 ms, total 1591.21 ms)] [avg calls per frame: 2]
15:10:20: encoder thread frame - [100%] [avg time: 0.093 ms (cpu time: avg 0.027 ms, total 31.2 ms)] [avg calls per frame: 1]
15:10:20:
15:10:20: =====Stream End: 2013-09-10, 15:10:20=================================================
15:10:21: =====Stream Start: 2013-09-10, 15:10:21===============================================
15:10:21:   Multithreaded optimizations: On
15:10:21:   Base resolution: 1920x1080
15:10:21:   Output resolution: 1280x720
15:10:21: ------------------------------------------
15:10:21: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
15:10:21: Audio Format: 44100hz
15:10:21: Playback device {0.0.0.00000000}.{dce8d686-16b6-41a0-b683-9ffe05bfd313}
15:10:21: Using desktop audio input: Högtalare (Realtek High Definition Audio)
15:10:21: Using auxilary audio input: Mikrofon (Realtek High Definition Audio)
15:10:21: Audio Encoding: AAC
15:10:21:     bitrate: 160
15:10:21: Using Monitor Capture
15:10:21: Found QSV hardware support
15:10:22: QSV version 1.4 using MFX_IMPL_HARDWARE_ANY | MFX_IMPL_VIA_ANY (actual: MFX_IMPL_HARDWARE3 | MFX_IMPL_VIA_D3D9)
15:10:22: Using 13 encode tasks
15:10:22: ------------------------------------------
15:10:22: Video Encoding: QSV
15:10:22:     fps: 60
15:10:22:     width: 1280, height: 720
15:10:22:     target-usage: MFX_TARGETUSAGE_BEST_QUALITY
15:10:22:     CBR: yes
15:10:22:     CFR: yes
15:10:22:     max bitrate: 3000
15:10:22: MMDeviceAudioSource: Frequency for device 'Högtalare (Realtek High Definition Audio)' is 384000, samples per sec is 48000
15:10:22: MMDeviceAudioSource: Frequency for device 'Mikrofon (Realtek High Definition Audio)' is 352800, samples per sec is 44100
15:10:23: Using RTMP service: Twitch / Justin.tv
15:10:23:   Server selection: rtmp://live-arn.justin.tv/app
15:10:23:   Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
15:10:24: SO_SNDBUF was at 8192
15:10:24: SO_SNDBUF is now 65536
15:10:45: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
15:10:45:   New Scene
15:10:45: Using bitmap image
15:10:45: ------------------------------------------
15:10:45:     device: Logitech HD Webcam C270,
15:10:45:     device id \\?\usb#vid_046d&pid_0825&mi_00#7&20540419&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
15:10:45:     chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000, fourCC: 'I420'
15:10:45:     audio device: Disable,
15:10:45:     audio device id Disabled,
15:10:45:
15:10:45: Using directshow input
15:10:45:     device: AVerMedia HD Capture C985 Bus 2,
15:10:45:     device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&1aa6ed88&0&0009#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
15:10:45:     chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666, fourCC: 'YV12'
15:10:45:
15:10:45:     device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
15:10:46: Using directshow input
15:10:46: PERFORMANCE WARNING: Scene change took 1111 ms, maybe some sources should be global sources?
15:10:48: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
15:10:48:   New Scene
15:10:48: Using Monitor Capture
15:10:50: PERFORMANCE WARNING: Scene change took 1844 ms, maybe some sources should be global sources?
15:11:02: Total frames encoded: 2406, total frames duplicated 172 (7.15%)
15:11:02: Total frames rendered: 2248, number of late frames: 5 (0.22%) (it's okay for some frames to be late)
15:11:02: RTMPPublisher::SocketLoop: Graceful loop exit
15:11:03: Number of times waited to send: 0, Waited for a total of 0 bytes
15:11:03: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
15:11:03:
15:11:03: Profiler results:
15:11:03:
15:11:03: ==============================================================
15:11:03: video thread frame - [100%] [avg time: 5.979 ms (cpu time: avg 2.428 ms, total 5460.04 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0502%]
15:11:03: | frame preprocessing and rendering - [99%] [avg time: 5.917 ms (cpu time: avg 2.421 ms, total 5444.44 ms)] [avg calls per frame: 1] [children: 68.8%] [unaccounted: 30.1%]
15:11:03: | | scene->Preprocess - [68.8%] [avg time: 4.116 ms (cpu time: avg 2.04 ms, total 4586.43 ms)] [avg calls per frame: 1]
15:11:03: | GPU download and color conversion - [0.987%] [avg time: 0.059 ms (cpu time: avg 0.006 ms, total 15.6 ms)] [avg calls per frame: 1] [children: 0.87%] [unaccounted: 0.117%]
15:11:03: | | flush - [0.552%] [avg time: 0.033 ms (cpu time: avg 0.006 ms, total 15.6 ms)] [avg calls per frame: 1]
15:11:03: | | CopyResource - [0.234%] [avg time: 0.014 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
15:11:03: | | conversion to 4:2:0 - [0.0836%] [avg time: 0.005 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
15:11:03: | Convert444Threads - [597%] [avg time: 35.672 ms (cpu time: avg 1.346 ms, total 3026.42 ms)] [avg calls per frame: 2]
15:11:03: encoder thread frame - [100%] [avg time: 0.081 ms (cpu time: avg 0.013 ms, total 31.2 ms)] [avg calls per frame: 1]
15:11:03:
15:11:03: =====Stream End: 2013-09-10, 15:11:03=================================================
15:11:05: =====Stream Start: 2013-09-10, 15:11:05===============================================
15:11:05:   Multithreaded optimizations: On
15:11:05:   Base resolution: 1920x1080
15:11:05:   Output resolution: 1280x720
15:11:05: ------------------------------------------
15:11:05: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
15:11:05: Audio Format: 44100hz
15:11:05: Playback device {0.0.0.00000000}.{dce8d686-16b6-41a0-b683-9ffe05bfd313}
15:11:05: Using desktop audio input: Högtalare (Realtek High Definition Audio)
15:11:05: Using auxilary audio input: Mikrofon (Realtek High Definition Audio)
15:11:05: Audio Encoding: AAC
15:11:05:     bitrate: 160
15:11:05: Using Monitor Capture
15:11:05: Found QSV hardware support
15:11:05: QSV version 1.4 using MFX_IMPL_HARDWARE_ANY | MFX_IMPL_VIA_ANY (actual: MFX_IMPL_HARDWARE3 | MFX_IMPL_VIA_D3D9)
15:11:05: Using 13 encode tasks
15:11:05: Video Encoding: QSV
15:11:05:     fps: 60
15:11:05:     width: 1280, height: 720
15:11:05:     target-usage: MFX_TARGETUSAGE_BEST_QUALITY
15:11:05:     CBR: yes
15:11:05:     CFR: yes
15:11:05:     max bitrate: 3000
15:11:05: MMDeviceAudioSource: Frequency for device 'Högtalare (Realtek High Definition Audio)' is 384000, samples per sec is 48000
15:11:05: MMDeviceAudioSource: Frequency for device 'Mikrofon (Realtek High Definition Audio)' is 352800, samples per sec is 44100
15:11:06: Using RTMP service: Twitch / Justin.tv
15:11:06:   Server selection: rtmp://live-arn.justin.tv/app
15:11:06:   Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
15:11:08: SO_SNDBUF was at 8192
15:11:08: SO_SNDBUF is now 65536
15:11:44: Total frames encoded: 2277, total frames duplicated 1 (0.04%)
15:11:44: Total frames rendered: 2286, number of late frames: 1 (0.04%) (it's okay for some frames to be late)
15:11:44: RTMPPublisher::SocketLoop: Graceful loop exit
15:11:44: Number of times waited to send: 0, Waited for a total of 0 bytes
15:11:44: Number of b-frames dropped: 4 (0.19%), Number of p-frames dropped: 1 (0.047%), Total 5 (0.23%)
15:11:44:
15:11:44: Profiler results:
15:11:44:
15:11:44: ==============================================================
15:11:44: video thread frame - [100%] [avg time: 4.842 ms (cpu time: avg 2.661 ms, total 6084.04 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.062%]
15:11:44: | frame preprocessing and rendering - [98.7%] [avg time: 4.78 ms (cpu time: avg 2.586 ms, total 5912.44 ms)] [avg calls per frame: 1] [children: 88.6%] [unaccounted: 10.2%]
15:11:44: | | scene->Preprocess - [88.6%] [avg time: 4.288 ms (cpu time: avg 2.224 ms, total 5085.63 ms)] [avg calls per frame: 1]
15:11:44: | GPU download and color conversion - [1.22%] [avg time: 0.059 ms (cpu time: avg 0.075 ms, total 171.602 ms)] [avg calls per frame: 1] [children: 1.05%] [unaccounted: 0.165%]
15:11:44: | | flush - [0.723%] [avg time: 0.035 ms (cpu time: avg 0.061 ms, total 140.401 ms)] [avg calls per frame: 1]
15:11:44: | | CopyResource - [0.248%] [avg time: 0.012 ms (cpu time: avg 0.006 ms, total 15.601 ms)] [avg calls per frame: 1]
15:11:44: | | conversion to 4:2:0 - [0.0826%] [avg time: 0.004 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
15:11:44: | Convert444Threads - [686%] [avg time: 33.197 ms (cpu time: avg 1.487 ms, total 3400.82 ms)] [avg calls per frame: 2]
15:11:44: encoder thread frame - [100%] [avg time: 0.085 ms (cpu time: avg 0.006 ms, total 15.6 ms)] [avg calls per frame: 1]
15:11:44:
15:11:44: =====Stream End: 2013-09-10, 15:11:44=================================================
15:11:53: =====Stream Start: 2013-09-10, 15:11:53===============================================
15:11:53:   Multithreaded optimizations: On
15:11:53:   Base resolution: 1920x1080
15:11:53:   Output resolution: 1280x720
15:11:53: ------------------------------------------
15:11:53: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
15:11:53: Audio Format: 44100hz
15:11:53: Playback device {0.0.0.00000000}.{dce8d686-16b6-41a0-b683-9ffe05bfd313}
15:11:53: Using desktop audio input: Högtalare (Realtek High Definition Audio)
15:11:53: Using auxilary audio input: Mikrofon (Realtek High Definition Audio)
15:11:53: Audio Encoding: AAC
15:11:53:     bitrate: 160
15:11:53: Using Monitor Capture
15:11:53: Found QSV hardware support
15:11:53: QSV version 1.4 using MFX_IMPL_HARDWARE_ANY | MFX_IMPL_VIA_ANY (actual: MFX_IMPL_HARDWARE3 | MFX_IMPL_VIA_D3D9)
15:11:54: Using 13 encode tasks
15:11:54: ------------------------------------------
15:11:54: Video Encoding: QSV
15:11:54:     fps: 60
15:11:54:     width: 1280, height: 720
15:11:54:     target-usage: MFX_TARGETUSAGE_BEST_QUALITY
15:11:54:     CBR: yes
15:11:54:     CFR: no
15:11:54:     max bitrate: 3000
15:11:54: MMDeviceAudioSource: Frequency for device 'Högtalare (Realtek High Definition Audio)' is 384000, samples per sec is 48000
15:11:54: MMDeviceAudioSource: Frequency for device 'Mikrofon (Realtek High Definition Audio)' is 352800, samples per sec is 44100
15:11:55: Using RTMP service: Twitch / Justin.tv
15:11:55:   Server selection: rtmp://live-arn.justin.tv/app
15:11:55:   Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
15:11:56: SO_SNDBUF was at 8192
15:11:56: SO_SNDBUF is now 65536
15:12:37: Total frames encoded: 2596, total frames duplicated 47 (1.81%)
15:12:37: Total frames rendered: 2563, number of late frames: 4 (0.16%) (it's okay for some frames to be late)
15:12:37: RTMPPublisher::SocketLoop: Graceful loop exit
15:12:40: Number of times waited to send: 0, Waited for a total of 0 bytes
15:12:40: Number of b-frames dropped: 4 (0.16%), Number of p-frames dropped: 1 (0.041%), Total 5 (0.2%)
15:12:40:
15:12:40: Profiler results:
15:12:40:
15:12:40: ==============================================================
15:12:40: video thread frame - [100%] [avg time: 5.138 ms (cpu time: avg 2.525 ms, total 6474.04 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0779%]
15:12:40: | frame preprocessing and rendering - [98.9%] [avg time: 5.079 ms (cpu time: avg 2.434 ms, total 6240.04 ms)] [avg calls per frame: 1] [children: 89.5%] [unaccounted: 9.4%]
15:12:40: | | scene->Preprocess - [89.5%] [avg time: 4.596 ms (cpu time: avg 2.112 ms, total 5413.23 ms)] [avg calls per frame: 1]
15:12:40: | GPU download and color conversion - [1.07%] [avg time: 0.055 ms (cpu time: avg 0.091 ms, total 234.001 ms)] [avg calls per frame: 1] [children: 0.954%] [unaccounted: 0.117%]
15:12:40: | | flush - [0.623%] [avg time: 0.032 ms (cpu time: avg 0.042 ms, total 109.2 ms)] [avg calls per frame: 1]
15:12:40: | | CopyResource - [0.253%] [avg time: 0.013 ms (cpu time: avg 0.036 ms, total 93.601 ms)] [avg calls per frame: 1]
15:12:40: | | conversion to 4:2:0 - [0.0779%] [avg time: 0.004 ms (cpu time: avg 0.006 ms, total 15.6 ms)] [avg calls per frame: 1]
15:12:40: | Convert444Threads - [657%] [avg time: 33.76 ms (cpu time: avg 1.424 ms, total 3650.42 ms)] [avg calls per frame: 2]
15:12:40: encoder thread frame - [100%] [avg time: 0.083 ms (cpu time: avg 0.012 ms, total 31.2 ms)] [avg calls per frame: 1]
15:12:40:
15:12:40: =====Stream End: 2013-09-10, 15:12:40=================================================
MMOStars
Good day,
I have been testing at least a couple of OBS builds after the opencl was released, but up to this latest test release it just isn't stable enough even during testing. It seems like the error is always the same:
Error: Texture->Map failed: ..............................................
Your video card or driver froze and was reset. Please check for possible hardware / driver issues. This error can also occur if you have enabled opencl in x264 custom settings.
I have tried 13.10, 13.10 b1 and b2 after I bought the new card.
Using full screen capture, using game capture, same result.
It can be 5 minutes, it can be 50 minutes, but eventually OBS crashes down.
It can crash when browsing the web or even just playing the game.
GPU is cool, underclocked and undervolted, but tried with overdrive disabled.
I understand that opencl implementation isn't even build in as an option just yet, but it would really help with streaming high end games on older/not so powerful CPUs if this feature would be implemented to perfection.
Posting a log and I hope that one of the OBS dev's who understands opencl, could review the code and what is causing this crashes, reading the forum, people who have tested opencl for long hours seem to get the crashes as well.
http://pastebin.com/p7CEY8fJ
Fas
Hi!
Just streamed a little and had a disconnect with a, what seemed to be, successful reconnect.
Stream was offline though and had to restart it.
15:45:05: Video Source Plugin strings not found, dynamically loading 38 strings
16:10:35: Open Broadcaster Software v0.56.03 MADNESS - 64bit ( ^ω^)
16:10:35: -------------------------------
16:10:35: CPU Name: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
16:10:35: CPU Speed: 3400MHz
16:10:35: Physical Memory:  8087MB Total, 4857MB Free
16:10:35: stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
16:10:35: monitor 1: pos={0, 0}, size={1920, 1080}
16:10:35: monitor 2: pos={-1920, 0}, size={1920, 1080}
16:10:35: Windows Version: 6.1 Build 7601 S
16:10:35: Aero is Disabled
16:10:35: OBS Modules:
16:10:35: Base Address     Module
16:10:35: 000000003FDB0000 OBS.exe
16:10:35: 00000000E2AF0000 OBSApi.dll
16:10:35: 00000000F8550000 DShowPlugin.dll
16:10:35: 00000000F8490000 GraphicsCapture.dll
16:10:35: 00000000F8530000 NoiseGate.dll
16:10:35: 00000000F8510000 PSVPlugin.dll
16:10:35: 00000000F8500000 VideoSourcePluginWrapper.dll
16:10:35: ------------------------------------------
16:10:35: Adapter 1
16:10:35:   Video Adapter: AMD Radeon HD 7800 Series
16:10:35:   Video Adapter Dedicated Video Memory: 2128814080a
16:10:35:   Video Adapter Shared System Memory: 3971522560
16:10:35: Adapter 2
16:10:35:   Video Adapter: Intel(R) HD Graphics 4000
16:10:35:   Video Adapter Dedicated Video Memory: 67108864
16:10:35:   Video Adapter Shared System Memory: 1711276032
16:10:35: =====Stream Start: 2013-09-12, 16:10:35===============================================
16:10:35:   Multithreaded optimizations: On
16:10:35:   Base resolution: 1920x1080
16:10:35:   Output resolution: 1280x720
16:10:35: Loading up D3D10 on AMD Radeon HD 7800 Series...
16:10:35: Audio Format: 48000hz
16:10:35: Playback device {0.0.0.00000000}.{cdedfd46-1f2a-4fb3-a59c-c62588df9f9f}
16:10:35: Using desktop audio input: Komplete Audio 6 Main Output (Komplete Audio 6 WDM Audio)
16:10:35: Using auxilary audio input: Komplete Audio 6 Input 1/2 (Komplete Audio 6 WDM Audio)
16:10:35: Audio Encoding: AAC
16:10:35:     bitrate: 160
16:10:35: Using text output
16:10:35: Using bitmap image
16:10:35: Video Encoding: x264
16:10:35:     fps: 60
16:10:35:     width: 1280, height: 720
16:10:35:     preset: veryfast
16:10:35:     CBR: yes
16:10:35:     CFR: yes
16:10:35:     max bitrate: 1900
16:10:35:     buffer size: 1900
16:10:35: MMDeviceAudioSource: Frequency for device 'Komplete Audio 6 Main Output (Komplete Audio 6 WDM Audio)' is 352800, samples per sec is 44100
16:10:35: MMDeviceAudioSource: Frequency for device 'Komplete Audio 6 Input 1/2 (Komplete Audio 6 WDM Audio)' is 352800, samples per sec is 44100
16:10:38: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:10:38:   New Scene
16:10:38: Using graphics capture
16:10:38: SharedTexCapture hooked
16:10:44: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:10:44:   New Scene
16:10:50: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:10:50:   New Scene
16:10:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:10:56:   New Scene
16:11:03: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:11:03:   New Scene
16:13:37: Using Video Source
16:15:42: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:15:42:   New Scene
16:15:49: Using bitmap image
16:15:50: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:15:50:   New Scene
16:15:57: Using bitmap image
16:16:17: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:16:17:   New Scene
16:16:32: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:16:32:   New Scene
16:16:32: Using bitmap image
16:16:32:   New Scene
16:17:07: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:17:07:   New Scene
16:17:20: Using bitmap image
16:18:23: Using bitmap image
16:21:03: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:21:03:   New Scene
16:21:03: Using text output
16:21:03: Using bitmap image
16:21:04: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:21:04:   New Scene
16:21:04: Using bitmap image
16:21:04:   New Scene
16:21:07: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:21:07:   New Scene
16:21:08: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:21:08:   New Scene
16:21:08: Using Video Source
16:21:09: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:21:09:   New Scene
16:21:09: Using Video Source
16:21:09:   New Scene
16:21:13: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:21:13:   New Scene
16:21:13: Using text output
16:21:13: Using bitmap image
16:21:18: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:21:18:   New Scene
16:21:19: Using bitmap image
16:21:24: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:21:24:   New Scene
16:21:24: Using text output
16:21:24: Using bitmap image
16:21:34: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:21:34:   New Scene
16:21:34: Using bitmap image
16:21:38: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:21:38:   New Scene
16:21:38: Using bitmap image
16:21:44: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:21:44:   New Scene
16:21:44: Using Video Source
16:21:50: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:21:50:   New Scene
16:21:50: Using Video Source
16:21:55: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:21:55:   New Scene
16:21:55: Using Video Source
16:22:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:22:01:   New Scene
16:22:02: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:22:02:   New Scene
16:22:02: Using bitmap image
16:22:21: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:22:21:   New Scene
16:22:21: Using bitmap image
16:22:25: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:22:25:   New Scene
16:22:25: Using bitmap image
16:22:29: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:22:29:   New Scene
16:22:29: Using Video Source
16:22:35: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:22:35:   New Scene
16:22:35: Using bitmap image
16:24:36: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:24:36:   New Scene
16:24:36: Using bitmap image
16:24:37: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:24:37:   New Scene
16:24:37: Using bitmap image
16:24:38: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:24:38:   New Scene
16:24:38: Using bitmap image
16:24:39: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:24:39:   New Scene
16:24:39:   New Scene
16:24:40: Using bitmap image
16:24:40: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:24:40:   New Scene
16:24:40: Using Video Source
16:24:41: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:24:41:   New Scene
16:24:41: Using bitmap image
16:26:30: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:26:30:   New Scene
16:26:30: Using bitmap image
16:26:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:26:46:   New Scene
16:26:46: Using bitmap image
16:26:53: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:26:53:   New Scene
16:26:53: Using Video Source
16:26:54: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:26:54:   New Scene
16:26:55: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:26:55:   New Scene
16:26:55: Using bitmap image
16:26:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:26:56:   New Scene
16:26:56: Using bitmap image
16:26:56:   New Scene
16:26:57: Using bitmap image
16:26:58: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:26:58:   New Scene
16:26:58:   New Scene
16:26:58: Using bitmap image
16:36:04: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:36:04:   New Scene
17:25:50: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:25:50:   New Scene
17:25:50: Using bitmap image
17:25:51: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:25:51:   New Scene
17:25:51: Using bitmap image
17:25:51:   New Scene
17:25:52: Using bitmap image
17:25:53: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:25:53:   New Scene
17:25:53: Using Video Source
17:25:53:   New Scene
17:25:54: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:25:54:   New Scene
17:25:54: Using bitmap image
17:25:55: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:25:55:   New Scene
17:25:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:25:56:   New Scene
17:25:56: Using bitmap image
17:44:31: Total frames encoded: 338085, total frames duplicated 1127 (0.33%)
17:44:31: Total frames rendered: 337554, number of late frames: 339 (0.10%) (it's okay for some frames to be late)
17:44:31:
17:44:31: Profiler results:
17:44:31:
17:44:31: ==============================================================
17:44:31: video thread frame - [100%] [avg time: 1.118 ms (cpu time: avg 0.315 ms, total 106533 ms)] [avg calls per frame: 1] [children: 99.7%] [unaccounted: 0.268%]
17:44:31: | frame preprocessing and rendering - [42.8%] [avg time: 0.479 ms (cpu time: avg 0.133 ms, total 45068.7 ms)] [avg calls per frame: 1] [children: 0.179%] [unaccounted: 42.7%]
17:44:31: | | scene->Preprocess - [0.179%] [avg time: 0.002 ms (cpu time: avg 0.001 ms, total 530.401 ms)] [avg calls per frame: 1]
17:44:31: | GPU download and color conversion - [56.9%] [avg time: 0.636 ms (cpu time: avg 0.181 ms, total 61121.2 ms)] [avg calls per frame: 1] [children: 54.9%] [unaccounted: 1.97%]
17:44:31: | | flush - [52.4%] [avg time: 0.586 ms (cpu time: avg 0.163 ms, total 55333.6 ms)] [avg calls per frame: 1]
17:44:31: | | CopyResource - [1.97%] [avg time: 0.022 ms (cpu time: avg 0.007 ms, total 2371.21 ms)] [avg calls per frame: 1]
17:44:31: | | conversion to 4:2:0 - [0.537%] [avg time: 0.006 ms (cpu time: avg 0.002 ms, total 826.806 ms)] [avg calls per frame: 1]
17:44:31: | Convert444Threads - [2.99e+003%] [avg time: 33.385 ms (cpu time: avg 1.976 ms, total 667279 ms)] [avg calls per frame: 2]
17:44:31: encoder thread frame - [100%] [avg time: 1.456 ms (cpu time: avg 1.098 ms, total 371267 ms)] [avg calls per frame: 1]
17:44:31:
17:44:31: =====Stream End: 2013-09-12, 17:44:31=================================================
17:44:31: =====Stream Start: 2013-09-12, 17:44:31===============================================
17:44:31:   Multithreaded optimizations: On
17:44:31:   Base resolution: 1920x1080
17:44:31:   Output resolution: 1280x720
17:44:31: ------------------------------------------
17:44:31: Loading up D3D10 on AMD Radeon HD 7800 Series...
17:44:32: ------------------------------------------
17:44:32: Audio Format: 48000hz
17:44:32: Playback device {0.0.0.00000000}.{cdedfd46-1f2a-4fb3-a59c-c62588df9f9f}
17:44:32: Using desktop audio input: Komplete Audio 6 Main Output (Komplete Audio 6 WDM Audio)
17:44:32: Using auxilary audio input: Komplete Audio 6 Input 1/2 (Komplete Audio 6 WDM Audio)
17:44:32: Audio Encoding: AAC
17:44:32:     bitrate: 160
17:44:32: Using bitmap image
17:44:32: Video Encoding: x264
17:44:32:     fps: 60
17:44:32:     width: 1280, height: 720
17:44:32:     preset: veryfast
17:44:32:     CBR: yes
17:44:32:     CFR: yes
17:44:32:     max bitrate: 1900
17:44:32:     buffer size: 1900
17:44:32: MMDeviceAudioSource: Frequency for device 'Komplete Audio 6 Main Output (Komplete Audio 6 WDM Audio)' is 352800, samples per sec is 44100
17:44:32: MMDeviceAudioSource: Frequency for device 'Komplete Audio 6 Input 1/2 (Komplete Audio 6 WDM Audio)' is 352800, samples per sec is 44100
17:44:33: Using RTMP service: Twitch / Justin.tv
17:44:33:   Server selection: rtmp://live-ams.justin.tv/app
17:44:33:   Interface: Broadcom NetLink (TM) Gigabit Ethernet (ethernet, 100 mbps)
17:44:35: SO_SNDBUF was at 8192
17:44:35: SO_SNDBUF is now 65536
18:12:48: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:12:48:   New Scene
18:12:48: Using bitmap image
18:12:48: Using graphics capture
18:12:48: SharedTexCapture hooked
18:19:53: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:19:53:   New Scene
18:19:53: Using bitmap image
18:56:51: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:56:51:   New Scene
18:57:25: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:57:25:   New Scene
18:57:25: Using bitmap image
18:57:53: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:57:53:   New Scene
18:57:53: Using Video Source
18:58:37: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:58:37:   New Scene
18:58:37: Using bitmap image
19:02:39: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
19:02:39:   New Scene
19:02:39: Using bitmap image
19:12:27: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
19:12:27:   New Scene
19:12:27: Using bitmap image
19:58:58: RTMPPublisher::SocketLoop: Aborting due to FD_CLOSE, error 0
19:58:58: Total frames encoded: 483944, total frames duplicated 3616 (0.75%)
19:58:58: Total frames rendered: 481986, number of late frames: 1158 (0.24%) (it's okay for some frames to be late)
19:58:58: Number of times waited to send: 0, Waited for a total of 0 bytes
19:58:58: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
19:58:59:
19:58:59: Profiler results:
19:58:59:
19:58:59: ==============================================================
19:58:59: video thread frame - [100%] [avg time: 2.406 ms (cpu time: avg 0.604 ms, total 291535 ms)] [avg calls per frame: 1] [children: 99.7%] [unaccounted: 0.291%]
19:58:59: | frame preprocessing and rendering - [60.2%] [avg time: 1.449 ms (cpu time: avg 0.486 ms, total 234470 ms)] [avg calls per frame: 1] [children: 0.208%] [unaccounted: 60%]
19:58:59: | | scene->Preprocess - [0.208%] [avg time: 0.005 ms (cpu time: avg 0.002 ms, total 1388.4 ms)] [avg calls per frame: 1]
19:58:59: | GPU download and color conversion - [39.5%] [avg time: 0.95 ms (cpu time: avg 0.116 ms, total 56144.8 ms)] [avg calls per frame: 1] [children: 31.7%] [unaccounted: 7.81%]
19:58:59: | | flush - [29.7%] [avg time: 0.714 ms (cpu time: avg 0.074 ms, total 35973.8 ms)] [avg calls per frame: 1]
19:58:59: | | CopyResource - [1.66%] [avg time: 0.04 ms (cpu time: avg 0.014 ms, total 7176.04 ms)] [avg calls per frame: 1]
19:58:59: | | conversion to 4:2:0 - [0.333%] [avg time: 0.008 ms (cpu time: avg 0.005 ms, total 2511.61 ms)] [avg calls per frame: 1]
19:58:59: | Convert444Threads - [1.39e+003%] [avg time: 33.467 ms (cpu time: avg 1.903 ms, total 917458 ms)] [avg calls per frame: 2]
19:58:59: encoder thread frame - [100%] [avg time: 1.771 ms (cpu time: avg 1.182 ms, total 572430 ms)] [avg calls per frame: 1]
19:58:59:
19:58:59: =====Stream End: 2013-09-12, 19:58:59=================================================
19:59:09: =====Stream Start: 2013-09-12, 19:59:09===============================================
19:59:09:   Multithreaded optimizations: On
19:59:09:   Base resolution: 1920x1080
19:59:09:   Output resolution: 1280x720
19:59:09: ------------------------------------------
19:59:09: Loading up D3D10 on AMD Radeon HD 7800 Series...
19:59:09: Audio Format: 48000hz
19:59:09: Playback device {0.0.0.00000000}.{cdedfd46-1f2a-4fb3-a59c-c62588df9f9f}
19:59:09: Using desktop audio input: Komplete Audio 6 Main Output (Komplete Audio 6 WDM Audio)
19:59:09: Using auxilary audio input: Komplete Audio 6 Input 1/2 (Komplete Audio 6 WDM Audio)
19:59:09: Audio Encoding: AAC
19:59:09:     bitrate: 160
19:59:09: Using bitmap image
19:59:09: Using graphics capture
19:59:09: Video Encoding: x264
19:59:09:     fps: 60
19:59:09:     width: 1280, height: 720
19:59:09:     preset: veryfast
19:59:09:     CBR: yes
19:59:09:     CFR: yes
19:59:09:     max bitrate: 1900
19:59:09:     buffer size: 1900
19:59:09: MMDeviceAudioSource: Frequency for device 'Komplete Audio 6 Main Output (Komplete Audio 6 WDM Audio)' is 352800, samples per sec is 44100
19:59:09: MMDeviceAudioSource: Frequency for device 'Komplete Audio 6 Input 1/2 (Komplete Audio 6 WDM Audio)' is 352800, samples per sec is 44100
19:59:09: SharedTexCapture hooked
19:59:10: Using RTMP service: Twitch / Justin.tv
19:59:10:   Server selection: rtmp://live-ams.justin.tv/app
19:59:10:   Interface: Broadcom NetLink (TM) Gigabit Ethernet (ethernet, 100 mbps)
19:59:12: SO_SNDBUF was at 8192
19:59:12: SO_SNDBUF is now 65536
20:04:19: Total frames encoded: 18547, total frames duplicated 42 (0.23%)
20:04:19: Total frames rendered: 18534, number of late frames: 15 (0.08%) (it's okay for some frames to be late)
20:04:19: RTMPPublisher::SocketLoop: Graceful loop exit
20:04:19: Number of times waited to send: 0, Waited for a total of 0 bytes
20:04:19: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:04:19:
20:04:19: Profiler results:
20:04:19:
20:04:19: ==============================================================
20:04:19: video thread frame - [100%] [avg time: 3.285 ms (cpu time: avg 0.683 ms, total 12667.3 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.152%]
20:04:19: | frame preprocessing and rendering - [43.7%] [avg time: 1.437 ms (cpu time: avg 0.549 ms, total 10186.9 ms)] [avg calls per frame: 1] [children: 0.0913%] [unaccounted: 43.7%]
20:04:19: | | scene->Preprocess - [0.0913%] [avg time: 0.003 ms (cpu time: avg 0.004 ms, total 78.001 ms)] [avg calls per frame: 1]
20:04:19: | GPU download and color conversion - [56.1%] [avg time: 1.843 ms (cpu time: avg 0.129 ms, total 2402.42 ms)] [avg calls per frame: 1] [children: 33%] [unaccounted: 23.1%]
20:04:19: | | flush - [32.2%] [avg time: 1.058 ms (cpu time: avg 0.09 ms, total 1669.21 ms)] [avg calls per frame: 1]
20:04:19: | | CopyResource - [0.609%] [avg time: 0.02 ms (cpu time: avg 0.017 ms, total 327.601 ms)] [avg calls per frame: 1]
20:04:19: | | conversion to 4:2:0 - [0.213%] [avg time: 0.007 ms (cpu time: avg 0.005 ms, total 109.202 ms)] [avg calls per frame: 1]
20:04:19: | Convert444Threads - [1.02e+003%] [avg time: 33.355 ms (cpu time: avg 1.688 ms, total 31293.8 ms)] [avg calls per frame: 2]
20:04:19: encoder thread frame - [100%] [avg time: 1.663 ms (cpu time: avg 1.081 ms, total 20030.5 ms)] [avg calls per frame: 1]
20:04:19:
20:04:19: =====Stream End: 2013-09-12, 20:04:19=================================================
20:04:20: =====Stream Start: 2013-09-12, 20:04:20===============================================
20:04:20:   Multithreaded optimizations: On
20:04:20:   Base resolution: 1920x1080
20:04:20:   Output resolution: 1280x720
20:04:20: ------------------------------------------
20:04:20: Loading up D3D10 on AMD Radeon HD 7800 Series...
20:04:20: Audio Format: 48000hz
20:04:20: Playback device {0.0.0.00000000}.{cdedfd46-1f2a-4fb3-a59c-c62588df9f9f}
20:04:20: Using desktop audio input: Komplete Audio 6 Main Output (Komplete Audio 6 WDM Audio)
20:04:20: Using auxilary audio input: Komplete Audio 6 Input 1/2 (Komplete Audio 6 WDM Audio)
20:04:20: Audio Encoding: AAC
20:04:20:     bitrate: 160
20:04:20: Using bitmap image
20:04:20: Using graphics capture
20:04:20: Video Encoding: x264
20:04:20:     fps: 60
20:04:20:     width: 1280, height: 720
20:04:20:     preset: veryfast
20:04:20:     CBR: yes
20:04:20:     CFR: yes
20:04:20:     max bitrate: 1900
20:04:20:     buffer size: 1900
20:04:20: MMDeviceAudioSource: Frequency for device 'Komplete Audio 6 Main Output (Komplete Audio 6 WDM Audio)' is 352800, samples per sec is 44100
20:04:20: MMDeviceAudioSource: Frequency for device 'Komplete Audio 6 Input 1/2 (Komplete Audio 6 WDM Audio)' is 352800, samples per sec is 44100
20:04:20: SharedTexCapture hooked
20:04:21: Using RTMP service: Twitch / Justin.tv
20:04:21:   Server selection: rtmp://live-ams.justin.tv/app
20:04:22:   Interface: Broadcom NetLink (TM) Gigabit Ethernet (ethernet, 100 mbps)
20:04:23: SO_SNDBUF was at 8192
20:04:23: SO_SNDBUF is now 65536
20:09:33: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
20:09:33:   New Scene
20:10:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
20:10:01:   New Scene
20:10:01: Using bitmap image
20:11:37: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
20:11:37:   New Scene
20:11:37: Using Video Source
20:12:24: Total frames encoded: 29002, total frames duplicated 250 (0.86%)
20:12:24: Total frames rendered: 28908, number of late frames: 26 (0.09%) (it's okay for some frames to be late)
20:12:24: RTMPPublisher::SocketLoop: Graceful loop exit
20:12:24: Number of times waited to send: 0, Waited for a total of 0 bytes
20:12:24: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:12:24:
20:12:24: Profiler results:
20:12:24:
20:12:24: ==============================================================
20:12:24: video thread frame - [100%] [avg time: 3.133 ms (cpu time: avg 0.586 ms, total 16941.7 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.223%]
20:12:24: | frame preprocessing and rendering - [49.1%] [avg time: 1.537 ms (cpu time: avg 0.456 ms, total 13182.1 ms)] [avg calls per frame: 1] [children: 0.128%] [unaccounted: 48.9%]
20:12:24: | | scene->Preprocess - [0.128%] [avg time: 0.004 ms (cpu time: avg 0.002 ms, total 62.4 ms)] [avg calls per frame: 1]
20:12:24: | GPU download and color conversion - [50.7%] [avg time: 1.589 ms (cpu time: avg 0.128 ms, total 3712.82 ms)] [avg calls per frame: 1] [children: 44.9%] [unaccounted: 5.81%]
20:12:24: | | flush - [43.8%] [avg time: 1.371 ms (cpu time: avg 0.09 ms, total 2605.22 ms)] [avg calls per frame: 1]
20:12:24: | | CopyResource - [0.798%] [avg time: 0.025 ms (cpu time: avg 0.016 ms, total 483.602 ms)] [avg calls per frame: 1]
20:12:24: | | conversion to 4:2:0 - [0.351%] [avg time: 0.011 ms (cpu time: avg 0.002 ms, total 78 ms)] [avg calls per frame: 1]
20:12:24: | Convert444Threads - [1.07e+003%] [avg time: 33.439 ms (cpu time: avg 1.834 ms, total 53040.3 ms)] [avg calls per frame: 2]
20:12:24: encoder thread frame - [100%] [avg time: 1.667 ms (cpu time: avg 1.142 ms, total 33119 ms)] [avg calls per frame: 1]
20:12:24:
20:12:24: =====Stream End: 2013-09-12, 20:12:24=================================================
20:12:58: Video Source Plugin instance deleted; removing dynamically loaded localization strings
2013-09-12, 16:10:38: we're booting up:
16:10:38: D3D9 Present
16:10:38: D3D9EndScene called
16:10:38: D3DPRESENT_PARAMETERS {
16:10:38: 	BackBufferWidth: 1920
16:10:38: 	BackBufferHeight: 1080
16:10:38: 	BackBufferFormat: D3DFMT_A8R8G8B8
16:10:38: 	BackBufferCount: 1
16:10:38: 	MultiSampleType: D3DMULTISAMPLE_NONE
16:10:38: 	MultiSampleQuality: 0
16:10:38: 	SwapEffect: D3DSWAPEFFECT_DISCARD
16:10:38: 	hDeviceWindow: 525514
16:10:38: 	Windowed: true
16:10:38: 	EnableAutoDepthStencil: true
16:10:38: 	AutoDepthStencilFormat: D3DFMT_D24S8
16:10:38: 	Flags: None
16:10:38: 	FullScreen_RefreshRateInHz: 0
16:10:38: 	PresentationInterval: 2147483648
16:10:38: };
16:10:38: successfully set up d3d9 hooks
16:10:38: D3D9Present called
16:10:38: DoD3D9GPUHook: success - d3d9ex
16:10:38: D3DSURFACE_DESC {
16:10:38: 	Format: D3DFMT_A8R8G8B8
16:10:38: 	Type: D3DRTYPE_SURFACE
16:10:38: 	Usage: D3DUSAGE_RENDERTARGET
16:10:38: 	Pool: D3DPOOL_DEFAULT
16:10:38: 	Width: 1920
16:10:38: 	Height: 1080
16:10:38: };
16:10:38: successfully capturing d3d9 frames via GPU
16:10:38: NV Capture available
16:10:38: FBO available
16:10:38: GL Present
16:10:38: (half life scientist) everything..  seems to be in order
17:44:31: ---------------------- Cleared D3D9 Capture ----------------------
17:44:31: D3D9EndScene called
17:44:31: D3D9Present called
18:12:48: received restart event, capturing
18:12:48: DoD3D9GPUHook: success - d3d9ex
18:12:48: D3DSURFACE_DESC {
18:12:48: 	Format: D3DFMT_A8R8G8B8
18:12:48: 	Type: D3DRTYPE_SURFACE
18:12:48: 	Usage: D3DUSAGE_RENDERTARGET
18:12:48: 	Pool: D3DPOOL_DEFAULT
18:12:48: 	MultiSampleType: D3DMULTISAMPLE_NONE
18:12:48: 	MultiSampleQuality: 0
18:12:48: 	Width: 1920
18:12:48: 	Height: 1080
18:12:48: };
18:12:48: successfully capturing d3d9 frames via GPU
19:58:58: ---------------------- Cleared D3D9 Capture ----------------------
19:58:58: D3D9EndScene called
19:58:58: D3D9Present called
19:59:09: received restart event, capturing
19:59:09: DoD3D9GPUHook: success - d3d9ex
19:59:09: D3DSURFACE_DESC {
19:59:09: 	Format: D3DFMT_A8R8G8B8
19:59:09: 	Type: D3DRTYPE_SURFACE
19:59:09: 	Usage: D3DUSAGE_RENDERTARGET
19:59:09: 	Pool: D3DPOOL_DEFAULT
19:59:09: 	MultiSampleType: D3DMULTISAMPLE_NONE
19:59:09: 	MultiSampleQuality: 0
19:59:09: 	Width: 1920
19:59:09: 	Height: 1080
19:59:09: };
19:59:09: successfully capturing d3d9 frames via GPU
20:04:19: ---------------------- Cleared D3D9 Capture ----------------------
20:04:19: D3D9EndScene called
20:04:19: D3D9Present called
20:04:20: received restart event, capturing
20:04:20: DoD3D9GPUHook: success - d3d9ex
20:04:20: D3DSURFACE_DESC {
20:04:20: 	Format: D3DFMT_A8R8G8B8
20:04:20: 	Type: D3DRTYPE_SURFACE
20:04:20: 	Usage: D3DUSAGE_RENDERTARGET
20:04:20: 	Pool: D3DPOOL_DEFAULT
20:04:20: 	MultiSampleType: D3DMULTISAMPLE_NONE
20:04:20: 	MultiSampleQuality: 0
20:04:20: 	Width: 1920
20:04:20: 	Height: 1080
20:04:20: };
20:04:20: successfully capturing d3d9 frames via GPU
20:12:24: ---------------------- Cleared D3D9 Capture ----------------------
20:12:24: D3D9EndScene called
20:12:24: D3D9Present called
Ravenheart
Greetings, I am having issues with Quick Sync with the MADNESS build.
I've enabled and installed all the required drivers, the option for using quick sync is enabled and i have checked it. However if i do not add a virtual monitor OBS will NOT start streaming when I press start stream and if I press the stop streaming button it will crash.
Attached are the crashlog and dump.
My rig:
Windows7 Ultimate x64
i5-4670K Haswell (3.4GHz)
8GB ram
Radeon HD7770 1GB
EDIT: I've attached a normal OBS log when the error with QSV happens.
  • OBSCrashLog2013-09-12_1.txt
  • OBSCrashDump2013-09-12_1.dmp
  • 2013-09-13-0045-49.log
Status
Not open for further replies.
