0.54.09 network test build
Status
Not open for further replies.
Fourson
Re: 0.54.06 network test build
Gave it a quick few tests and ran into something scary. It seems to more than triple the CPU use of my game (DMC4) after a few moments and leave it there til I close the game, at least using game hook. Goes from 8-10% average use to 33-35% constantly. Stable acts as expected however and leave it at 8-10%.
Session log
12:00:24: Open Broadcaster Software v0.54.06 network/gc test - 64bit ( ^ω^)
12:00:24: -------------------------------
12:00:24: CPU Name: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
12:00:24: CPU Speed: 3401MHz
12:00:24: Physical Memory:  8157MB Total, 4761MB Free
12:00:24: stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
12:00:24: monitor 1: pos={1920, 0}, size={1920, 1080}
12:00:24: monitor 2: pos={0, 0}, size={1920, 1080}
12:00:24: Windows Version: 6.1 Build 7600
12:00:24: Aero is Disabled
12:00:24: OBS Modules:
12:00:24: Base Address     Module
12:00:24: 000000003FF70000 OBS.exe
12:00:24: 00000000E30F0000 OBSApi.dll
12:00:24: 00000000E6740000 DShowPlugin.dll
12:00:24: 00000000E6710000 GraphicsCapture.dll
12:00:24: 00000000FAF40000 NoiseGate.dll
12:00:24: 00000000F54F0000 PSVPlugin.dll
12:00:24: ------------------------------------------
12:00:24: Adapter 1
12:00:24:   Video Adapter: AMD Radeon HD 6700 Series
12:00:24:   Video Adapter Dedicated Video Memory: 1060859904
12:00:24:   Video Adapter Shared System Memory: 4008216576
12:00:24: =====Stream Start: 2013-08-02, 12:00:24===============================================
12:00:24:   Multithreaded optimizations: On
12:00:24:   Base resolution: 1600x900
12:00:24:   Output resolution: 912x514
12:00:24: Loading up D3D10...
12:00:24: Playback device Default
12:00:24: Using desktop audio input: Speakers (2- Realtek High Definition Audio)
12:00:24: Using auxilary audio input: Mic in at front panel (Pink) (2- Realtek High Definition Audio)
12:00:24: Audio Encoding: AAC
12:00:24:     bitrate: 128
12:00:24: Using graphics capture
12:00:24: Video Encoding: x264
12:00:24:     fps: 48
12:00:24:     width: 912, height: 514
12:00:24:     preset: fast
12:00:24:     CBR: no
12:00:24:     CFR: no
12:00:24:     max bitrate: 3300
12:00:24:     buffer size: 3200
12:00:24:     quality: 9
12:00:24: MMDeviceAudioSource: Frequency for device 'Speakers (2- Realtek High Definition Audio)' is 1536000, samples per sec is 192000
12:00:24: MMDeviceAudioSource: Frequency for device 'Mic in at front panel (Pink) (2- Realtek High Definition Audio)' is 384000, samples per sec is 48000
12:00:24: SharedTexCapture hooked
12:00:24: Total frames rendered: 32, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
12:00:24: =====Stream End: 2013-08-02, 12:00:24=================================================
12:00:25: =====Stream Start: 2013-08-02, 12:00:25===============================================
12:00:25:   Multithreaded optimizations: On
12:00:25:   Base resolution: 1600x900
12:00:25:   Output resolution: 912x514
12:00:25: ------------------------------------------
12:00:25: Loading up D3D10...
12:00:25: Playback device Default
12:00:25: Using desktop audio input: Speakers (2- Realtek High Definition Audio)
12:00:25: Using auxilary audio input: Mic in at front panel (Pink) (2- Realtek High Definition Audio)
12:00:25: Audio Encoding: AAC
12:00:25:     bitrate: 128
12:00:25: Using graphics capture
12:00:25: Video Encoding: x264
12:00:25:     fps: 48
12:00:25:     width: 912, height: 514
12:00:25:     preset: fast
12:00:25:     CBR: no
12:00:25:     CFR: no
12:00:25:     max bitrate: 3300
12:00:25:     buffer size: 3200
12:00:25:     quality: 9
12:00:25: MMDeviceAudioSource: Frequency for device 'Speakers (2- Realtek High Definition Audio)' is 1536000, samples per sec is 192000
12:00:25: MMDeviceAudioSource: Frequency for device 'Mic in at front panel (Pink) (2- Realtek High Definition Audio)' is 384000, samples per sec is 48000
12:00:25: SharedTexCapture hooked
12:00:28: Total frames rendered: 118, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
12:00:28: =====Stream End: 2013-08-02, 12:00:28=================================================
12:00:57: =====Stream Start: 2013-08-02, 12:00:57===============================================
12:00:57:   Multithreaded optimizations: On
12:00:57:   Base resolution: 1600x900
12:00:57:   Output resolution: 912x514
12:00:57: ------------------------------------------
12:00:57: Loading up D3D10...
12:00:57: Playback device Default
12:00:57: Using desktop audio input: Speakers (2- Realtek High Definition Audio)
12:00:57: Using auxilary audio input: Mic in at front panel (Pink) (2- Realtek High Definition Audio)
12:00:57: Audio Encoding: AAC
12:00:57:     bitrate: 128
12:00:57: Using graphics capture
12:00:57: Video Encoding: x264
12:00:57:     fps: 48
12:00:57:     width: 912, height: 514
12:00:57:     preset: fast
12:00:57:     CBR: no
12:00:57:     CFR: no
12:00:57:     max bitrate: 3300
12:00:57:     buffer size: 3200
12:00:57:     quality: 9
12:00:57: MMDeviceAudioSource: Frequency for device 'Speakers (2- Realtek High Definition Audio)' is 1536000, samples per sec is 192000
12:00:57: MMDeviceAudioSource: Frequency for device 'Mic in at front panel (Pink) (2- Realtek High Definition Audio)' is 384000, samples per sec is 48000
12:00:57: SharedTexCapture hooked
12:01:39: Total frames rendered: 2006, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
12:01:39: =====Stream End: 2013-08-02, 12:01:39=================================================
12:02:08:
12:02:08: Profiler results:
12:02:08:
12:02:08: ==============================================================
12:02:08: frame - [100%] [avg time: 1.431 ms (cpu time: avg 0.868 ms, total 1872.01 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.21%]
12:02:08: | frame preprocessing and rendering - [18.2%] [avg time: 0.261 ms (cpu time: avg 0.144 ms, total 312 ms)] [avg calls per frame: 1] [children: 0.0699%] [unaccounted: 18.2%]
12:02:08: | | scene->Preprocess - [0.0699%] [avg time: 0.001 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
12:02:08: | video encoding and uploading - [81.6%] [avg time: 1.167 ms (cpu time: avg 0.723 ms, total 1560.01 ms)] [avg calls per frame: 1] [children: 80.5%] [unaccounted: 1.05%]
12:02:08: | | flush - [27.5%] [avg time: 0.394 ms (cpu time: avg 0.021 ms, total 46.8 ms)] [avg calls per frame: 1]
12:02:08: | | CopyResource - [0.349%] [avg time: 0.005 ms (cpu time: avg 0.007 ms, total 15.6 ms)] [avg calls per frame: 0]
12:02:08: | | conversion to 4:2:0 - [0.21%] [avg time: 0.003 ms (cpu time: avg 0.007 ms, total 15.6 ms)] [avg calls per frame: 0]
12:02:08: | | call to encoder - [51.7%] [avg time: 0.74 ms (cpu time: avg 0.672 ms, total 1450.81 ms)] [avg calls per frame: 0]
12:02:08: | | sending stuff out - [0.699%] [avg time: 0.01 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
12:02:08: | Convert444Threads - [2.81e+003%] [avg time: 40.157 ms (cpu time: avg 0.846 ms, total 1825.21 ms)] [avg calls per frame: 1]
12:02:08:
Hook log
2013-08-02, 12:00:24: we're booting up:
12:00:24: DXGI Present
12:00:24: (half life scientist) everything..  seems to be in order
12:00:24: DXGI: Found D3D 10
12:00:24: setting up d3d10 data
12:00:24: ---------------------- Cleared D3D10 Capture ----------------------
12:00:24: found dxgi format (dx10) of: 28, size: {1600, 900}, multisampled: false
12:00:24: DoD3D10Hook: success
12:00:24: successfully capturing d3d10 frames via GPU
12:00:24: stop requested, terminating d3d10 capture
12:00:25: DoD3D10Hook: success
12:00:25: successfully capturing d3d10 frames via GPU
12:00:28: stop requested, terminating d3d10 capture
12:00:28: ---------------------- Cleared D3D10 Capture ----------------------
12:00:57: DoD3D10Hook: success
12:00:57: successfully capturing d3d10 frames via GPU
12:01:39: stop requested, terminating d3d10 capture
12:01:39: ---------------------- Cleared D3D10 Capture ----------------------
Not entirely related/important, but when I went to try the stable version to make sure it didn't have the same problem it wouldn't let me delete it after I finished til I closed my game as well (typical windows "in use" message with "try again").
xD4rkFire
Wait you too?! I was getting weird CPU usage increases by BF3 also but I had NO idea what was causing it. I tried everything until eventually I reinstalled Windows and the problem was STILL happening. I'm going to try a different build and see how my game cpu usage is.
So does anyone know if the current stable version also has this game capture problem?
**Edit: Looks like the current stable version (0.542b) is good. Using the test build, I was at 90% CPU usage on BF3. With the stable build, it's back down to 60-70%. :)
Kharay
Kharay said:
I have not yet been able to reproduce it with 100% accuracy but several times now Minecraft will drop to abysmal FPS after stopping the stream and closing OBS. As if somehow part of the Game Capture hook lingers behind and messes with Minecraft. The only resolution is to simply restart the game.
Again, I cannot reproduce this phenomenon with 100% accuracy but it is behaviour I had not seen before, during previous builds. Nor is it behaviour I've previously seen of Minecraft.
Regarding this -- Never mind; it's not OBS. It's some kind of strange interaction between Minecraft and Chrome; just had it happen to me with OBS not even running. Restarting Chrome seemed to fix it; odd little bug.
Grue
Session log
12:00:24: Adapter 1
12:00:24:     fps: 48
12:00:24:     CBR: no
12:00:24:     CFR: no
12:00:25:     fps: 48
12:00:25:     CBR: no
12:00:25:     CFR: no
12:00:57:     fps: 48
12:00:57:     CBR: no
12:00:57:     CFR: no
12:02:08:
12:02:08:
12:02:08:
Hook log
I confirm this same happened to me streaming wow. You need to restart the game so things go back to normal.
Lain
Forum Admin
Lain
Forum Moderator
Developer
Thanks for the info about the CPU usage, I'll check to see what code has changed
Lain
Forum Admin
Lain
Forum Moderator
Developer
Re: 0.54.07 network test build
Okay, updated to 07, could you guys see if game capture is still having those issues? iRacing users as well as those of you experiencing the strange CPU usage problem?
paibox
heros in an halfshel
The keyframe interval setting isn't all that advanced, it's merely the maximum amount of inbetween frames before the encoder forcibly adds a keyframe. Also, YouTube requests it be set to two seconds, and soon other services may request such things as well.
Lain
Forum Admin
Lain
Forum Moderator
Developer
Re: 0.54.08 network test build
Just updated the build to 08, moved keyframe interval to advanced. Reasoning being that it really isn't a general setting users should mess with usually.
Also fixed that monitor capture rotation issue from viewtopic.php?f=6&t=794
EDIT: crap, forgot to add the new code from palana's commit to make it work with quicksync
EDIT EDIT: no wait, that code was included, ignore the last edit
Lain
Forum Admin
Lain
Forum Moderator
Developer
Did it stop working for you or something?
Fenrir
Forum Admin
07 - made a workaround/fix for game capture for when it would capture a 1x1 pixel or a smaller size than intended from games that don't properly use the swap chain
Just as FYI, whatever changes were made did not resolve this issue. I'm willing to help with any testing to get it resolved, but as it's a very small number of games affected (the one I'm having the issue with is technically a demo anyway), not a terribly big deal. :)
flavored
Hey,
As of the earliest builds of 0.54.* I was getting this huge bug with my Avermedia C127 (Game Broadcaster HD). I didn't report it at first thinking it'd be fixed in the future builds, but to date no change is there. In .52 it's all fine. Screenshot is attached.
OBS Version Tried: 0.54.08 in this example, all of 0.54.* since they were released.
The video recorded is exactly the same as in this preview.
paibox
The resolution selection code changed at some point, it looks like it isn't picking the correct input resolution. Try setting it manually instead of relying on the (possibly) buggy driver reporting which resolution is currently being used.
got a crash just now while streaming fo about an hour
**edit** hmmm seems obs was longer open then i expected/thought......
OBS has encountered an unhandled exception and has terminated. If you are able to
reproduce this crash, please submit this crash report on the forums at
http://www.obsproject.com/ - include the contents of this crash log and the
minidump .dmp file (if available) as well as your regular OBS log files and
a description of what you were doing at the time of the crash.
This crash appears to have occured in the 'c:\windows\system32\kernelbase.dll' module.
**** UNHANDLED EXCEPTION: 80000003
Fault address: 000007FEFD813C72 (c:\windows\system32\kernelbase.dll)
OBS version: Open Broadcaster Software v0.54.08 network/gc test
Windows version: 6.1 (Build 7601) Service Pack 1
CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
Crashing thread stack trace:
000000000025ED68 000007FEFD813C72 000007FEE85D5860 000000000000EA60 000000000025ECC8 000000000025F3D0 kernelbase.dll!0x7fefd813c72
000000000025ED70 000007FEE844D053 0000000000362A00 0000000000362A00 000000000025F3D0 0000000000000000 obsapi.dll!OSTerminateThread+0x33
000000000025EDA0 000000013FAC2BE5 00000000028F1260 0000000000000000 0000000000000000 0000000000000001 obs.exe!RTMPPublisher::~RTMPPublisher+0xb5
000000000025F220 000000013FAC2894 0000000000000004 0000000000000000 0000000000000000 000000013FABA234 obs.exe!RTMPPublisher::`vector deleting destructor'+0x14
000000000025F250 000000013FABCFF2 0000000000000000 000000000025F3D0 0000000000000401 0000000000000000 obs.exe!OBS::Stop+0x112
000000000025F2D0 000000013FADC6E9 000000000000FF00 0000000000030000 0000000000000401 000000000025F720 obs.exe!OBS::OBSProc+0x17f9
000000000025F460 00000000775F9BD1 000000000025F720 000000013FADAEF0 00000000008A03A0 00000000008A03A0 user32.dll!0x775f9bd1
000000000025F520 00000000775F98DA 0000000000000000 0000000000000000 000000013FADAEF0 0000000000000001 user32.dll!0x775f98da
000000000025F5A0 00000000775F67C2 00000000251605FF 00000000251605FF 000007FEFFA02164 0000000000452B90 user32.dll!0x775f67c2
000000000025F630 000000013FAB14F9 0000000000000000 0000000000000000 000000013FA90000 0000000000000000 obs.exe!WinMain+0x8b9
000000000025FB60 000000013FB24D50 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!strstr+0x1ac
000000000025FC10 00000000776F652D 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x776f652d
000000000025FC40 000000007782C521 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7782c521
A minidump was saved to C:\Users\Gebruiker\AppData\Roaming\OBS\crashDumps\OBSCrashDump2013-08-07_1.dmp.
Please include this file when posting a crash report.
List of loaded modules:
Base Address
log:
13:36:37: Open Broadcaster Software v0.54.08 network/gc test - 64bit ( ^ω^)
13:36:37: -------------------------------
13:36:37: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
13:36:37: CPU Speed: 3332MHz
13:36:37: Physical Memory:  8159MB Total, 6305MB Free
13:36:37: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
13:36:37: monitor 1: pos={0, 0}, size={1920, 1080}
13:36:37: monitor 2: pos={-1280, 33}, size={1280, 1024}
13:36:37: Windows Version: 6.1 Build 7601 S
13:36:37: Aero is Enabled
13:36:37: OBS Modules:
13:36:37: Base Address     Module
13:36:37: 000000003FA90000 OBS.exe
13:36:37: 00000000E8420000 OBSApi.dll
13:36:37: 00000000F3220000 DShowPlugin.dll
13:36:37: 00000000F31F0000 GraphicsCapture.dll
13:36:37: 00000000FBFC0000 NoiseGate.dll
13:36:37: 00000000FB0A0000 PSVPlugin.dll
13:36:37: 00000000EA830000 scenesw.dll
13:36:37: ------------------------------------------
13:36:37: Adapter 1
13:36:37:   Video Adapter: NVIDIA GeForce GTX 560 Ti
13:36:37:   Video Adapter Dedicated Video Memory: 1025966080
13:36:37:   Video Adapter Shared System Memory: 3220779008
13:36:37: =====Stream Start: 2013-08-07, 13:36:37===============================================
13:36:37:   Multithreaded optimizations: On
13:36:37:   Base resolution: 1600x900
13:36:37:   Output resolution: 1280x720
13:36:37: Loading up D3D10 on NVIDIA GeForce GTX 560 Ti...
13:36:37: Playback device {0.0.0.00000000}.{ec118582-431d-43b3-93a7-50cf9c8a9acb}
13:36:37: Using desktop audio input: Luidsprekers (Realtek High Definition Audio)
13:36:37: Using 5.1 speaker setup
13:36:37: Using auxilary audio input: Microfoon (Pro 9000)
13:36:37: Audio Encoding: AAC
13:36:37:     bitrate: 128
13:36:37:     device: Logitech QuickCam Pro 9000,
13:36:37:     device id \\?\usb#vid_046d&pid_0990&mi_00#7&322d27b4&2&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
13:36:37:     chosen type: I420, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-2000000, fourCC: 'I420'
13:36:37:     audio device: Disable,
13:36:37:     audio device id Disabled,
13:36:37:
13:36:38: Using directshow input
13:36:41: Using text output
13:36:41: Using bitmap image
13:36:41: ------------------------------------------
13:36:41: Video Encoding: x264
13:36:41:     fps: 60
13:36:41:     width: 1280, height: 720
13:36:41:     preset: veryfast
13:36:41:     CBR: yes
13:36:41:     CFR: no
13:36:41:     max bitrate: 3500
13:36:41: MMDeviceAudioSource: Frequency for device 'Luidsprekers (Realtek High Definition Audio)' is 4608000, samples per sec is 192000
13:36:41: MMDeviceAudioSource: Frequency for device 'Microfoon (Pro 9000)' is 64000, samples per sec is 16000
13:36:41:
13:36:41: Profiler result for the last frame:
13:36:41: ==============================================================
13:36:41: frame - [time: 19.88 ms (cpu time: 0 ms)]
13:36:41: | frame preprocessing and rendering - [time: 19.795 ms (cpu time: 0 ms)]
13:36:41: | | scene->Preprocess - [time: 18.767 ms (cpu time: 0 ms)]
13:36:41: | video encoding and uploading - [time: 0.083 ms (cpu time: 0 ms)]
13:36:41: | | flush - [time: 0.079 ms (cpu time: 0 ms)]
13:36:41:
13:36:42: Using RTMP service: Twitch / Justin.tv
13:36:42:   Server selection: rtmp://live-ams.justin.tv/app
13:36:42:   Interface: Intel(R) 82579V Gigabit Network Connection (ethernet, 1000 mbps)
13:36:44: SO_SNDBUF was at 8192
13:36:44: SO_SNDBUF is now 65536
13:36:49: RTMPPublisher::Socketloop: Increasing send buffer to ISB 262144 (buffer: 61419 / 463872)
13:36:49: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:36:49:   New Scene
13:36:49: Using Window Capture
13:36:49: Using graphics capture
13:36:50: SharedTexCapture hooked
14:03:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:03:01:   New Scene
14:03:26: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:03:26:   New Scene
14:03:26: Using Window Capture
14:03:26: Using graphics capture
14:03:26: SharedTexCapture hooked
14:03:41: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:03:41:   New Scene
14:04:26: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:04:26:   New Scene
14:04:26: Using Window Capture
14:04:26: Using graphics capture
14:04:26: SharedTexCapture hooked
14:04:51: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:04:51:   New Scene
14:05:11: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:05:11:   New Scene
14:05:11: Using Window Capture
14:05:11: Using graphics capture
14:05:11: SharedTexCapture hooked
14:05:31: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:05:31:   New Scene
14:05:36: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:05:36:   New Scene
14:05:36: Using Window Capture
14:05:36: Using graphics capture
14:05:36: SharedTexCapture hooked
14:14:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:14:56:   New Scene
14:15:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:15:01:   New Scene
14:15:01: Using Window Capture
14:15:01: Using graphics capture
14:15:01: SharedTexCapture hooked
14:16:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:16:46:   New Scene
14:16:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:16:56:   New Scene
14:16:56: Using Window Capture
14:16:56: Using graphics capture
14:16:56: SharedTexCapture hooked
14:17:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:17:06:   New Scene
14:17:26: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:17:26:   New Scene
14:17:26: Using Window Capture
14:17:26: Using graphics capture
14:17:26: SharedTexCapture hooked
14:18:21: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:18:21:   New Scene
14:19:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:19:06:   New Scene
14:19:06: Using Window Capture
14:19:06: Using graphics capture
14:19:06: SharedTexCapture hooked
14:19:11: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:19:11:   New Scene
14:20:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:20:01:   New Scene
14:20:01: Using Window Capture
14:20:01: Using graphics capture
14:20:01: SharedTexCapture hooked
14:20:11: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:20:11:   New Scene
14:20:36: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:20:36:   New Scene
14:20:36: Using Window Capture
14:20:36: Using graphics capture
14:20:36: SharedTexCapture hooked
14:20:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:20:56:   New Scene
14:21:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:21:01:   New Scene
14:21:01: Using Window Capture
14:21:01: Using graphics capture
14:21:01: SharedTexCapture hooked
14:24:11: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:24:11:   New Scene
14:24:21: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:24:21:   New Scene
14:24:21: Using Window Capture
14:24:21: Using graphics capture
14:24:21: SharedTexCapture hooked
14:44:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:44:01:   New Scene
14:44:21: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:44:21:   New Scene
14:44:21: Using Window Capture
14:44:21: Using graphics capture
14:44:21: SharedTexCapture hooked
15:06:31: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
15:06:31:   New Scene
15:06:41: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
15:06:41:   New Scene
15:06:41: Using Window Capture
15:06:41: Using graphics capture
15:06:41: SharedTexCapture hooked
15:13:11: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
15:13:11:   New Scene
15:13:26: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
15:13:26:   New Scene
15:13:26: Using Window Capture
15:13:26: Using graphics capture
15:13:26: SharedTexCapture hooked
15:14:41: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
15:14:41:   New Scene
15:15:11: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
15:15:11:   New Scene
15:15:11: Using Window Capture
15:15:11: Using graphics capture
15:15:11: SharedTexCapture hooked
15:22:41: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
15:22:41:   New Scene
15:23:16: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
15:23:16:   New Scene
15:23:16: Using Window Capture
15:23:16: Using graphics capture
15:23:16: SharedTexCapture hooked
15:34:43: RTMPPublisher::Socketloop: Increasing send buffer to ISB 524288 (buffer: 0 / 463872)
16:15:21: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:15:21:   New Scene
16:15:31: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:15:31:   New Scene
16:15:31: Using Window Capture
16:15:31: Using graphics capture
16:15:31: SharedTexCapture hooked
16:15:36: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:15:36:   New Scene
16:15:51: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:15:51:   New Scene
16:15:51: Using Window Capture
16:15:51: Using graphics capture
16:15:51: SharedTexCapture hooked
16:29:41: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:29:41:   New Scene
16:29:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:29:56:   New Scene
16:29:56: Using Window Capture
16:29:56: Using graphics capture
16:29:56: SharedTexCapture hooked
16:32:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:32:06:   New Scene
16:32:11: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:32:11:   New Scene
16:32:11: Using Window Capture
16:32:11: Using graphics capture
16:32:11: SharedTexCapture hooked
16:32:16: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:32:16:   New Scene
16:32:21: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:32:21:   New Scene
16:32:21: Using Window Capture
16:32:21: Using graphics capture
16:32:21: SharedTexCapture hooked
16:32:36: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:32:36:   New Scene
16:34:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:34:01:   New Scene
16:34:01: Using Window Capture
16:34:01: Using graphics capture
16:34:01: SharedTexCapture hooked
16:44:31: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:44:31:   New Scene
16:45:26: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:45:26:   New Scene
16:45:26: Using Window Capture
16:45:26: Using graphics capture
16:45:26: SharedTexCapture hooked
16:45:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:45:56:   New Scene
16:46:51: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:46:51:   New Scene
16:46:51: Using Window Capture
16:46:51: Using graphics capture
16:46:51: SharedTexCapture hooked
16:47:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:47:06:   New Scene
16:47:11: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:47:11:   New Scene
16:47:11: Using Window Capture
16:47:11: Using graphics capture
16:47:11: SharedTexCapture hooked
16:47:21: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:47:21:   New Scene
16:47:26: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:47:26:   New Scene
16:47:26: Using Window Capture
16:47:26: Using graphics capture
16:47:26: SharedTexCapture hooked
16:47:31: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:47:31:   New Scene
16:47:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:47:56:   New Scene
16:47:56: Using Window Capture
16:47:56: Using graphics capture
16:47:56: SharedTexCapture hooked
16:48:36: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:48:36:   New Scene
16:51:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:51:06:   New Scene
16:51:06: Using Window Capture
16:51:06: Using graphics capture
16:51:06: SharedTexCapture hooked
16:51:16: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:51:16:   New Scene
16:52:36: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:52:36:   New Scene
16:52:36: Using Window Capture
16:52:36: Using graphics capture
16:52:36: SharedTexCapture hooked
16:53:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:53:06:   New Scene
16:53:21: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:53:21:   New Scene
16:53:21: Using Window Capture
16:53:21: Using graphics capture
16:53:21: SharedTexCapture hooked
16:53:26: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:53:26:   New Scene
16:56:31: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:56:31:   New Scene
16:56:31: Using graphics capture
16:56:31: SharedTexCapture hooked
17:02:41: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:02:41:   New Scene
17:02:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:02:46:   New Scene
17:02:46: Using graphics capture
17:02:46: SharedTexCapture hooked
17:02:51: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:02:51:   New Scene
17:02:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:02:56:   New Scene
17:02:56: Using graphics capture
17:02:56: SharedTexCapture hooked
17:09:21: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:09:21:   New Scene
17:09:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:09:46:   New Scene
17:09:46: Using graphics capture
17:09:46: SharedTexCapture hooked
17:11:16: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:11:16:   New Scene
17:11:26: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:11:26:   New Scene
17:11:26: Using graphics capture
17:11:26: SharedTexCapture hooked
17:11:36: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:11:36:   New Scene
17:11:41: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:11:41:   New Scene
17:11:41: Using graphics capture
17:11:41: SharedTexCapture hooked
17:11:51: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:11:51:   New Scene
17:11:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:11:56:   New Scene
17:11:56: Using graphics capture
17:11:56: SharedTexCapture hooked
17:14:16: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:14:16:   New Scene
17:16:51: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:16:51:   New Scene
17:16:51: Using graphics capture
17:16:51: SharedTexCapture hooked
17:16:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:16:56:   New Scene
17:17:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:17:06:   New Scene
17:17:06: Using graphics capture
17:17:06: SharedTexCapture hooked
17:19:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:19:46:   New Scene
17:20:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:20:01:   New Scene
17:20:01: Using graphics capture
17:20:01: SharedTexCapture hooked
17:21:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:21:56:   New Scene
17:22:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:22:06:   New Scene
17:22:06: Using graphics capture
17:22:06: SharedTexCapture hooked
17:22:11: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:22:11:   New Scene
17:22:16: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:22:16:   New Scene
17:22:16: Using graphics capture
17:22:16: SharedTexCapture hooked
17:22:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:22:56:   New Scene
17:23:11: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:23:11:   New Scene
17:23:11: Using graphics capture
17:23:11: SharedTexCapture hooked
17:23:26: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:23:26:   New Scene
17:23:31: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:23:31:   New Scene
17:23:31: Using graphics capture
17:23:31: SharedTexCapture hooked
17:23:41: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:23:41:   New Scene
17:24:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:24:46:   New Scene
17:24:46: Using graphics capture
17:24:46: SharedTexCapture hooked
17:24:51: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:24:51:   New Scene
17:25:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:25:01:   New Scene
17:25:01: Using graphics capture
17:25:01: SharedTexCapture hooked
17:26:16: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:26:16:   New Scene
17:26:51: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:26:51:   New Scene
17:26:51: Using graphics capture
17:26:51: SharedTexCapture hooked
17:26:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:26:56:   New Scene
17:27:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:27:06:   New Scene
17:27:06: Using graphics capture
17:27:06: SharedTexCapture hooked
17:27:23: GraphicsCaptureSource::NewCapture:  eliminating old capture
17:27:23: SharedTexCapture hooked
17:28:51: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:28:51:   New Scene
17:29:26: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:29:26:   New Scene
17:29:26: Using graphics capture
17:29:26: SharedTexCapture hooked
17:30:36: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:30:36:   New Scene
17:32:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:32:01:   New Scene
17:32:01: Using graphics capture
17:32:01: SharedTexCapture hooked
17:33:11: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:33:11:   New Scene
17:33:21: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:33:21:   New Scene
17:33:21: Using graphics capture
17:33:21: SharedTexCapture hooked
17:34:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:34:46:   New Scene
17:36:31: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:36:31:   New Scene
17:36:31: Using graphics capture
17:36:31: SharedTexCapture hooked
17:37:41: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:37:41:   New Scene
17:38:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:38:01:   New Scene
17:38:01: Using graphics capture
17:38:01: SharedTexCapture hooked
17:40:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:40:01:   New Scene
17:43:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:43:06:   New Scene
17:43:06: Using graphics capture
17:43:06: SharedTexCapture hooked
17:43:11: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:43:11:   New Scene
17:43:16: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:43:16:   New Scene
17:43:16: Using graphics capture
17:43:16: SharedTexCapture hooked
17:43:21: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:43:21:   New Scene
17:43:31: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:43:31:   New Scene
17:43:31: Using graphics capture
17:43:31: SharedTexCapture hooked
17:47:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:47:46:   New Scene
17:51:16: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:51:16:   New Scene
17:51:16: Using graphics capture
17:51:16: SharedTexCapture hooked
17:51:26: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:51:26:   New Scene
17:51:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:51:46:   New Scene
17:51:46: Using graphics capture
17:51:46: SharedTexCapture hooked
17:55:21: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:55:21:   New Scene
17:55:26: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:55:26:   New Scene
17:55:26: Using graphics capture
17:55:26: SharedTexCapture hooked
17:57:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:57:01:   New Scene
17:57:11: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:57:11:   New Scene
17:57:11: Using graphics capture
17:57:11: SharedTexCapture hooked
17:57:13: GraphicsCaptureSource::NewCapture:  eliminating old capture
17:57:13: SharedTexCapture hooked
17:57:16: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:57:16:   New Scene
17:57:41: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:57:41:   New Scene
17:57:41: Using graphics capture
17:57:41: SharedTexCapture hooked
17:57:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:57:46:   New Scene
17:58:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:58:06:   New Scene
17:58:06: Using graphics capture
17:58:06: SharedTexCapture hooked
17:59:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:59:06:   New Scene
17:59:26: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:59:26:   New Scene
17:59:26: Using graphics capture
17:59:26: SharedTexCapture hooked
18:00:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:00:56:   New Scene
18:01:16: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:01:16:   New Scene
18:01:16: Using graphics capture
18:01:16: SharedTexCapture hooked
18:01:41: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:01:41:   New Scene
18:01:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:01:46:   New Scene
18:01:46: Using graphics capture
18:01:46: SharedTexCapture hooked
18:01:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:01:56:   New Scene
18:03:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:03:46:   New Scene
18:03:46: Using graphics capture
18:03:46: SharedTexCapture hooked
18:05:31: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:05:31:   New Scene
18:05:36: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:05:36:   New Scene
18:05:36: Using graphics capture
18:05:36: SharedTexCapture hooked
18:06:31: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:06:31:   New Scene
18:06:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:06:46:   New Scene
18:06:46: Using graphics capture
18:06:46: SharedTexCapture hooked
18:06:51: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:06:51:   New Scene
18:07:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:07:01:   New Scene
18:07:01: Using graphics capture
18:07:01: SharedTexCapture hooked
18:07:36: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:07:36:   New Scene
18:07:41: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:07:41:   New Scene
18:07:41: Using graphics capture
18:07:41: SharedTexCapture hooked
18:07:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:07:46:   New Scene
18:28:12: Total frames rendered: 1049190, number of late frames: 735 (0.07%) (it's okay for some frames to be late)
18:28:13: RTMPPublisher::SocketLoop: Graceful loop exit
18:28:13: Number of times waited to send: 0, Waited for a total of 0 bytes
18:28:13: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
18:28:13: =====Stream End: 2013-08-07, 18:28:13=================================================
19:06:05: =====Stream Start: 2013-08-07, 19:06:05===============================================
19:06:05:   Multithreaded optimizations: On
19:06:05:   Base resolution: 1600x900
19:06:05:   Output resolution: 1280x720
19:06:05: ------------------------------------------
19:06:05: Loading up D3D10 on NVIDIA GeForce GTX 560 Ti...
19:06:05: Playback device {0.0.0.00000000}.{ec118582-431d-43b3-93a7-50cf9c8a9acb}
19:06:05: Using desktop audio input: Luidsprekers (Realtek High Definition Audio)
19:06:05: Using 5.1 speaker setup
19:06:05: Using auxilary audio input: Microfoon (Pro 9000)
19:06:05: Audio Encoding: AAC
19:06:05:     bitrate: 128
19:06:05:     device: Logitech QuickCam Pro 9000,
19:06:05:     device id \\?\usb#vid_046d&pid_0990&mi_00#7&322d27b4&2&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
19:06:05:     chosen type: I420, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-2000000, fourCC: 'I420'
19:06:05:     audio device: Disable,
19:06:05:     audio device id Disabled,
19:06:05:
19:06:05: Using directshow input
19:06:05: Using text output
19:06:05: Using bitmap image
19:06:05: Video Encoding: x264
19:06:05:     fps: 60
19:06:05:     width: 1280, height: 720
19:06:05:     preset: veryfast
19:06:05:     CBR: yes
19:06:05:     CFR: no
19:06:05:     max bitrate: 3500
19:06:05: MMDeviceAudioSource: Frequency for device 'Luidsprekers (Realtek High Definition Audio)' is 4608000, samples per sec is 192000
19:06:05: MMDeviceAudioSource: Frequency for device 'Microfoon (Pro 9000)' is 64000, samples per sec is 16000
19:06:05:
19:06:05: Profiler result for the last frame:
19:06:05: ==============================================================
19:06:05: frame - [time: 26.217 ms (cpu time: 0 ms)]
19:06:05: | frame preprocessing and rendering - [time: 21.228 ms (cpu time: 0 ms)]
19:06:05: | | scene->Preprocess - [time: 0.003 ms (cpu time: 0 ms)]
19:06:05: | video encoding and uploading - [time: 4.985 ms (cpu time: 0 ms)]
19:06:05: | | flush - [time: 4.978 ms (cpu time: 0 ms)]
19:06:05:
19:06:06: Using RTMP service: Twitch / Justin.tv
19:06:06:   Server selection: rtmp://live-ams.justin.tv/app
19:06:07:   Interface: Intel(R) 82579V Gigabit Network Connection (ethernet, 1000 mbps)
19:06:08: SO_SNDBUF was at 8192
19:06:08: SO_SNDBUF is now 65536
19:06:13: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 41436 / 463872)
19:06:32: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
19:06:32:   New Scene
19:06:32: Using graphics capture
19:06:32: SharedTexCapture hooked
19:10:38: RTMPPublisher::Socketloop: Increasing send buffer to ISB 262144 (buffer: 0 / 463872)
19:12:19: RTMPPublisher::Socketloop: Increasing send buffer to ISB 524288 (buffer: 0 / 463872)
20:17:16: RTMPPublisher::SocketLoop: Aborting due to FD_CLOSE, error 0
20:17:17: Total frames rendered: 256194, number of late frames: 261 (0.10%) (it's okay for some frames to be late)
20:18:17: WARNING: Forcibly terminating a thread after 60000 ms timeout!
lwrand
Hi there,
I tested both the "stable" version and "0.54.08 test" but they crash Final Fantasy XI and Dark Souls.
Please find attached a log of my last test (related to Dark Souls).
If you need any further tests, let me know :)
/cheers
  • 2013-08-07-2312-04.log
Status
