Question / Help White Frame during livestreams
JustWilbo
Hi!
I have this recent problem during livestreams. A few months ago OBS gave a high CPU warning and frame drops during streams, Not only that but there would also every now and then apear a white frame for a second and sometimes more then a second over my stream. It doesn´t cover the whole screen, think about those black bars in some movies, but then the black bars would be normal screen and the movie would be all white. I think that describes the size of it best. Now I did fix the CPU problem. Turns out that the white frame was not part of the CPU problem. I have no idea what causes this to happen. Does anyone know what I can do?
WizardCM
Forum Moderator
Community Helper
I will admit, I've never seen that before. Could you post a clean log?
1) Restart OBS
2) Start your stream/recording for at least 30 seconds. Make sure you replicate any issues as best you can, which means having any games/apps open and captured, etc.
3) Stop your stream/recording.
4) Select Help > Log Files > Upload Current Log File. Copy the URL and paste it here.
(Note: If you do not see an obsproject.com URL, you will need to update OBS Studio to version 22+)
