Question / Help While recording I keep experiencing frame drops. Is a setting I have involved?
Koala_KingxX
I was recording a game and my frames started dropping about 10 minutes in and the fluctuated between 30-49 FPS for a while. My CPU was running no higher then 15% at peak. The game ran flawless on my end so any help with the settings that may be a problem would be greatly appreciated.
  • 2019-12-29 20-53-03.txt
21:25:24.799: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 12614 (11.0%)
You're overloading your GPU.
20:53:27.649: [x264 encoder: 'recording_h264'] preset: ultrafast
20:53:27.649: [x264 encoder: 'recording_h264'] profile: main
20:53:27.649: [x264 encoder: 'recording_h264'] settings:
20:53:27.649: rate_control: CBR
20:53:27.649: bitrate: 14000
You're also using CPU encoding for local recording on a machine that is capable of using the new NVENC encoder, and using CBR rate control, which is better suited for streaming.
I'd suggest using NVENC-new, CQP rate control and a quality setting of 15 and see how that goes. Make sure lookahead and psycho-visual tuning are off, at least to start with.
Koala_KingxX
Thank you so much! It appears to have cleared out my issue immediately!
