vst 2 plugin graphic interface display size problem
Daikenzo
some GUIs are no longer displayed correctly in version 31.0.3 (e.g. vocalsynth). the size is too small to display everything.
Suslik V
Likely, scaling issue for High-DPI display devices.
It is better to re-test it against newer OBS: https://obsproject.com/forum/threads/obs-studio-31-1-beta.186286/
For the test purposes you can make OBS portable in a different folder. For portable OBS, please read only after the words "If it was not clear": https://obsproject.com/forum/thread...»-when-opening-app-settings.82157/post-346499 or in the Help: https://obsproject.com/kb/portable-mode
