VHS to MP4: Nedis USB Audio / Video Grabber
D
Deleted member 481702
I'm trying to convert from VHS to MP4 (using EXT 1 / AV 1 port), but can't figure out what's the issue here. I have followed these instructions: https://www.youtube.com/watch?v=G2CIEE8kjSU
What am I doing wrong here?
D
The problem is that I can't get the VHS image to appear in the OBS software, so presumably OBS doesn't recognize the video source/signal. We're using a capture device called Nevis.
D
Will it be sufficient to directly route the video from the VHS player to the OBS software, or does the VHS video need to be mirrored first, for example, on a television, from which the capture is taken with the Nevis device?
A capture device appears as monitor for connected VHS devices, so yes, just connect the capture device instead of the TV or monitor.
