Unsure why my stream is stopping randomly. Restarts after 30 seconds
Wibbbow
My stream works perfectly fine at the start, but it varies on when it crashes. Sometimes it doesn't happen, but on average its once every 2-3 hours. It will instantly go from green to red on the bottom right, then on the bottom left it will say a disconnection error, and then establishing reconnection. It reconnects within 30 seconds. This has been happening ever since I moved into my new apartment. I checked my settings on my computer and OBS, everything is just about the same as my partner with no issues. We share the same ethernet/router, so I don't think its a wifi/router issue since theirs never cuts out or have problems. I could use all the help I can here. Here are multiple logs to look at since I am unsure which one will give the most information. Thank you!
  • 2023-04-24 13-26-59.txt
  • 2023-04-24 12-54-44.txt
  • 2023-04-24 13-28-26.txt
  • 2023-04-24 00-09-52.txt
