Streaming to chaturbate problem (really need help)
username99
Hello everybody! I am streaming to chaturbate and for a while I watch myslef streaming from a icognito page on the browser to see if the stream is smooth. However I ussually see that my stream freeze without obs noticing me there is a problem. I really want to ask you if you could check my log file to see if there is a error which maybe I couldn't see. I have to mention that I have 1gbps internet and a very good laptop i7 8750h with nvidia gti 1060 and 8 gb of ram. Thank you in advance!
  • 2020-06-11 16-59-25.txt
R1CH
Forum Admin
Developer
The log looks fine, not a single dropped frame. Is it possible the camera itself is freezing? Otherwise the problem might be on their end.
username99
One more thing I would like to ask if you are in the domain please. I have from my ISP a router which I asked to put it in the bridge mode so disableing the wireless network and make a PPOE connection (broadband) directly to the net. Today I switched back from that and asked them to put it in the router mode to function like a normal router. Can this affect the internet quality?
R1CH
Forum Admin
Developer
It could, ISP provided routers generally aren't that great. Bridge mode with your own high quality router is my usual recommendation.
username99
ok thank you a lot for this informations. Also if you dont mind at what should I look for a high quality router? Price or what? Mentioning that I will streaming over a wired conection I dont need good wifi specs.
