Stream "Starting" but not broadcasting i think IOS camera is the cause
lumos7
hopefully i can get some help here . Im currently having a sporadic issue with my streams. It seems like the OBS ios camera plugin may be the cause but i cant say for certain because it worked fine before. When i "start streaming" it says im streaming but the bandwidth bar isnt active and there is no stream running. if i attempt to end the stream the button doesnt work and i have to kill the app with task manager. I've only been able to stream in safemode but obviously thats not ideal as non of my plugins work then. I recently came across way more plugins which ive installed since so when i share the log files, pay those no mind because i doubt any of them are the cause. I've also tried multiple builds of obs and still have the same issue. ive attached some logs and crash files and a preview of what i see when i attempt to go live. like i said before though it does broadcast in safe mode
  • 2024-06-23 11-07-22.txt
  • 2024-06-23 11-10-39.txt
  • 2024-06-23 11-27-54.txt
  • Crash 2024-06-21 18-40-27.txt
The crash is caused by a custom dock or browser source you or a plugin added. Remove this plugin and the problem solves itself. You may want to see if there's an update to the plugins that are compatible with the version of OBS you're using.
lumos7
is tthere any feature that allows in obs plugin addition/removal/updating
Pally
Same issue here. Literally identical. How can I read the logs and figure out which plugin/dock is the problematic one?
  • Crash 2024-06-25 19-19-20.txt
DHhunter
I got almost the same problem !! I cant connect to facebook and if it connect o star losing alot frames !! Help
You're issue is not related to the OP issue at all.
Create a new scene collection and add a few sources in it. Close OBS and remove the plugins. Open OBS (you're now on the new scene collection) and test it. Start adding one by one the plugins or audio filters you used until you hit the one that crash OBS.
To the OP, there's no app to look for plugins updates, you have to do it manually. Remove any plugin you don't use and don't update OBS or a plugin until you know it works and are compatible. Check on each plugin page to know more.
Pally
I hate that the solution is essentially "redo your entire setup until you come across the issue" with so many nuances and all this time spent.
Why even bother putting so much effort into things if a log file can't even narrow down the cause of an issue without a nonsensical amount of labor?
You didn't attached a log file, unless you did on your own thread (please create one if you still need help) and I didn't see it.
And you don't undo anything, that's why you first create a new scene collection, to preserve everything on the actual scene collection your using. A little common sense.
Chat GPT uses the answers you already find in this forum if you care to look around, but normally is wrong about it because it also uses of all the bad or utterly ancient advices you also find over the internet.
