"stream key not found" DURING my live streams, stream crashes
dracurai
hi! this is my first post to this forum, so i hope i'm doing everything correctly.
recently, obs has been doing this thing where i'm already live for an hour or so, and it randomly disconnects, saying it couldn't find the stream key. i have no idea what to do anymore, this is bugging me a lot. i included the log file from my last stream, i hope it's useful. the stream crashed at 17:36:25.570. thank you in advance!
  • 2025-03-14 16-55-47 log file.txt
prgmitchell
Forum Moderator
Hello, this is a known issue. The disconnect you are having would be related to your own network connection to the streaming server but OBS failing to properly reconnect when that happens should be fixed in the next update. I would recommend reinstalling OBS 30.2.3 until the next update releases if you want to avoid this happening.
dracurai
thank you, i'll do that !! <3
