Stream crashes "An encoder error has occurred while streaming", can anyone help?
Kyugaraaa
Hello, I just got a new pc (cpu and gpu), I installed OBS and trying to stream, but after a bit of gaming, even after 30secs, stream crashes and error says "An encoder error has occurred while streaming". I have a lot of "Frames missed due to rendering lag" and "Skipped frames due to encoding lag" while streaming a game. I'll paste the log file, check the last "Stream start" at the end of the log where the error is shown.
  • 2023-06-17 12-07-23.txt
deFrisselle
Check the log analyzer report and have a look at your log You have various source and capture hook issues You could also reduce your bitrate to 4500-5000 bps​
