Speedify
M4cgyv3r
I did a search but nothing really pertaining to my issue unfortunately.
I just started using speedify a few days ago, great price and performance testing was awesome, unfortunately on 2 live streams now - 1 each day the stream has had network problems forcing me to disable speedify.
I'm used to seeing the odd dropped frames over 4G, i use a RUT955 wired and a mobile hotspot incase i need to hunt for signal over wifi.
Surprisingly when OBS reports an issue with the network it just starts flicking between red and yellow with 0 bytes output, its weird and I've not seen this behavior before - checked logs and yep rtmp send errors then OBS disconnects and attempts to reconnect but can't.
I have to disable speedify to get it to work again.
Wondering if anyone else uses speedify - I left it all auto so I'm going through all the various settings now and will test if anything helps or hinders.
This is definitely an issue with speedify and a setting somewhere, i've also raised a ticket with them so if i find a resolution i'll post back here.
  • 2021-12-30 10-24-22.txt
