Sound ruins after running OBS on Mac
Kolorsmac
Good Evening,
I have an iMac (HighSierra) and a Bose NC 700 headset connected. Just installed Black Hole to let OBS simultaneously capture computer music and my speaking on the mic. It works quite well. Problem is each time I start OBS it just ruins the quality of music, physically switching MIDI settings. Attached two screenshots from the MIDI sound settings. One is before I start OBS, the sound format is 2ch 32-bit 44kHz in MIDI setting, the other is after how it ruins it. And each time I quit OBS I can change the MIDI back but not when OBS is running. Please help. Thank you.
gregersen
Where you able to find a solution for this?
I'm experiencing exactly the same on my M1 macbook.
Kind of annoying to have to use crap quality audio when streaming.
