Question / Help Repeated Freezing
Spensaur23
Hey guys, i am streaming obs to twitch and every time i open it and start to click around the app freezes. its not like a normal freeze though because it continues to stream and i can still minimize and maximize the tab or move it around my home screen. the display even shows live what im doing, i just cant click the buttons or change any settings. i have tried downloading older and newer versions but still nothing. if you guys have any ideas that would be much appreciated. im not super computer savvy so it could be something simple.
Spensaur23
19:39:21.038: CPU Name: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
19:39:21.038: CPU Speed: 2592MHz
19:39:21.038: Physical Cores: 4, Logical Cores: 8
19:39:21.038: Physical Memory: 24528MB Total, 19520MB Free
19:39:21.038: Windows Version: 10.0 Build 17134 (revision: 165; 64-bit)
19:39:21.038: Running as administrator: false
19:39:21.039: Aero is Enabled (Aero is always on for windows 8 and above)
19:39:21.039: Windows 10 Gaming Features:
19:39:21.039: Game DVR: On
19:39:21.041: Sec. Software Status:
19:39:21.042: Windows Defender Antivirus: enabled (AV)
19:39:21.042: Norton Security: disabled (AV)
19:39:21.043: Norton Security: disabled (FW)
19:39:21.043: Windows Firewall: enabled (FW)
19:39:21.044: Norton Security: disabled (ASW)
19:39:21.044: Windows Defender Antivirus: enabled (ASW)
19:39:21.044: Portable mode: false
19:39:21.070: OBS 21.0.1 (64bit, windows)
19:39:21.070: ---------------------------------
19:39:21.071: ---------------------------------
19:39:21.071: audio settings reset:
19:39:21.071: samples per sec: 44100
19:39:21.071: speakers: 2
19:39:21.072: ---------------------------------
19:39:21.073: Initializing D3D11...
19:39:21.073: Available Video Adapters:
19:39:21.075: Adapter 1: NVIDIA GeForce GTX 980M
19:39:21.075: Dedicated VRAM: 4250337280
19:39:21.075: Shared VRAM: 4270012416
19:39:21.075: output 1: pos={0, 0}, size={1920, 1080}, attached=true
19:39:21.075: output 2: pos={-1920, 0}, size={1920, 1080}, attached=true
19:39:21.078: Loading up D3D11 on adapter NVIDIA GeForce GTX 980M (0)
19:39:21.128: D3D11 loaded successfully, feature level used: 45056
19:39:21.961: ---------------------------------
19:39:21.961: video settings reset:
19:39:21.961: base resolution: 1920x1080
19:39:21.961: output resolution: 1280x720
19:39:21.961: downscale filter: Bicubic
19:39:21.961: fps: 30/1
19:39:21.961: format: NV12
19:39:21.963: Audio monitoring device:
19:39:21.963: name: Default
19:39:21.963: id: default
19:39:21.963: ---------------------------------
19:39:21.964: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
19:39:21.969: [CoreAudio encoder]: Adding CoreAudio AAC encoder
19:39:21.998: [AMF] <obs_module_load> AMF not supported (no AMD graphics)
19:39:21.998: Failed to initialize module 'enc-amf.dll'
19:39:22.010: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
19:39:22.010: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
19:39:22.011: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
19:39:22.011: [browser_source: 'Version: 1.29.0']
19:39:22.015: NVENC supported
19:39:22.135: Couldn't find VLC installation, VLC video source disabled
19:39:22.140: No blackmagic support
19:39:22.243: ---------------------------------
19:39:22.243: Loaded Modules:
19:39:22.243: win-wasapi.dll
19:39:22.243: win-mf.dll
19:39:22.243: win-dshow.dll
19:39:22.243: win-decklink.dll
19:39:22.243: win-capture.dll
19:39:22.243: vlc-video.dll
19:39:22.243: text-freetype2.dll
19:39:22.243: rtmp-services.dll
19:39:22.243: obs-x264.dll
19:39:22.243: obs-vst.dll
19:39:22.243: obs-transitions.dll
19:39:22.243: obs-text.dll
19:39:22.243: obs-qsv11.dll
19:39:22.243: obs-outputs.dll
19:39:22.243: obs-filters.dll
19:39:22.243: obs-ffmpeg.dll
19:39:22.243: obs-browser.dll
19:39:22.243: image-source.dll
19:39:22.243: frontend-tools.dll
19:39:22.243: enc-amf.dll
19:39:22.243: coreaudio-encoder.dll
19:39:22.243: ==== Startup complete ===============================================
19:39:22.254: All scene data cleared
19:39:22.254: ------------------------------------------------
19:39:22.308: WASAPI: Device 'Speakers (6- USB Audio Device)' initialized
19:39:22.331: WASAPI: Device 'Microphone (6- USB Audio Device)' initialized
19:39:22.379: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
19:39:22.836: Switched to scene 'Stream Display'
19:39:22.838: ------------------------------------------------
19:39:22.838: Loaded scenes:
19:39:22.838: - scene 'Scene':
19:39:22.838: - scene 'Stream Display':
19:39:22.838: - source: 'Display Capture' (monitor_capture)
19:39:22.838: - scene 'Rocket League':
19:39:22.838: - source: 'Rocket League Capture' (game_capture)
Spensaur23
the problem is once i start pressing buttons which would create the problem i cant access them, unless theres a way to do it without going through the app
Spensaur23
I'd need a full log from a recording or streaming session.
19:49:14.231:
19:49:14.231: ================================
19:49:14.232: Warning: OBS is already running!
19:49:14.232: ================================
19:49:14.232:
19:49:15.772: User is now running a secondary instance of OBS!
19:49:15.792: CPU Name: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
19:49:15.792: CPU Speed: 2592MHz
19:49:15.792: Physical Cores: 4, Logical Cores: 8
19:49:15.792: Physical Memory: 24528MB Total, 19271MB Free
19:49:15.792: Windows Version: 10.0 Build 17134 (revision: 165; 64-bit)
19:49:15.792: Running as administrator: false
19:49:15.792: Aero is Enabled (Aero is always on for windows 8 and above)
19:49:15.792: Windows 10 Gaming Features:
19:49:15.792: Game DVR: On
19:49:15.794: Sec. Software Status:
19:49:15.795: Windows Defender Antivirus: enabled (AV)
19:49:15.795: Norton Security: disabled (AV)
19:49:15.795: Norton Security: disabled (FW)
19:49:15.795: Windows Firewall: enabled (FW)
19:49:15.796: Norton Security: disabled (ASW)
19:49:15.796: Windows Defender Antivirus: enabled (ASW)
19:49:15.796: Portable mode: false
19:49:15.812: OBS 21.0.1 (64bit, windows)
19:49:15.812: ---------------------------------
19:49:15.813: audio settings reset:
19:49:15.813: samples per sec: 44100
19:49:15.813: speakers: 2
19:49:15.813: ---------------------------------
19:49:15.813: Initializing D3D11...
19:49:15.813: Available Video Adapters:
19:49:15.814: Adapter 1: NVIDIA GeForce GTX 980M
19:49:15.814: Dedicated VRAM: 4250337280
19:49:15.814: Shared VRAM: 4270012416
19:49:15.814: output 1: pos={0, 0}, size={1920, 1080}, attached=true
19:49:15.814: output 2: pos={-1920, 0}, size={1920, 1080}, attached=true
19:49:15.817: Loading up D3D11 on adapter NVIDIA GeForce GTX 980M (0)
19:49:15.869: D3D11 loaded successfully, feature level used: 45056
19:49:16.712: ---------------------------------
19:49:16.712: video settings reset:
19:49:16.712: base resolution: 1920x1080
19:49:16.712: output resolution: 1280x720
19:49:16.712: downscale filter: Bicubic
19:49:16.712: fps: 30/1
19:49:16.712: format: NV12
19:49:16.714: Audio monitoring device:
19:49:16.714: name: Default
19:49:16.714: id: default
19:49:16.714: ---------------------------------
19:49:16.716: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
19:49:16.723: [CoreAudio encoder]: Adding CoreAudio AAC encoder
19:49:16.753: [AMF] <obs_module_load> AMF not supported (no AMD graphics)
19:49:16.753: Failed to initialize module 'enc-amf.dll'
19:49:16.767: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
19:49:16.768: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
19:49:16.768: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
19:49:16.769: [browser_source: 'Version: 1.29.0']
19:49:16.772: NVENC supported
19:49:16.875: Couldn't find VLC installation, VLC video source disabled
19:49:16.878: No blackmagic support
19:49:16.995: ---------------------------------
19:49:16.995: Loaded Modules:
19:49:16.995: win-wasapi.dll
19:49:16.995: win-mf.dll
19:49:16.995: win-dshow.dll
19:49:16.996: win-decklink.dll
19:49:16.996: win-capture.dll
19:49:16.996: vlc-video.dll
19:49:16.996: text-freetype2.dll
19:49:16.996: rtmp-services.dll
19:49:16.996: obs-x264.dll
19:49:16.996: obs-vst.dll
19:49:16.996: obs-transitions.dll
19:49:16.996: obs-text.dll
19:49:16.996: obs-qsv11.dll
19:49:16.996: obs-outputs.dll
19:49:16.996: obs-filters.dll
19:49:16.996: obs-ffmpeg.dll
19:49:16.996: obs-browser.dll
19:49:16.996: image-source.dll
19:49:16.996: frontend-tools.dll
19:49:16.996: enc-amf.dll
19:49:16.996: coreaudio-encoder.dll
19:49:16.996: ---------------------------------
19:49:16.996: ==== Startup complete ===============================================
19:49:17.007: All scene data cleared
19:49:17.007: ------------------------------------------------
19:49:17.040: WASAPI: Device 'Speakers (6- USB Audio Device)' initialized
19:49:17.049: WASAPI: Device 'Microphone (6- USB Audio Device)' initialized
19:49:17.097: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
19:49:17.583: Switched to scene 'Stream Display'
19:49:17.585: ------------------------------------------------
19:49:17.585: Loaded scenes:
19:49:17.585: - scene 'Scene':
19:49:17.585: - scene 'Stream Display':
19:49:17.585: - source: 'Display Capture' (monitor_capture)
19:49:17.585: - scene 'Rocket League':
19:49:17.585: - source: 'Rocket League Capture' (game_capture)
19:49:20.532: ==== Shutting down ==================================================
19:49:20.541: Switched to scene '(null)'
19:49:20.542: WASAPI: Device 'Speakers (6- USB Audio Device)' Terminated
19:49:20.546: WASAPI: Device 'Microphone (6- USB Audio Device)' Terminated
19:49:20.547: All scene data cleared
19:49:20.547: ------------------------------------------------
19:49:20.626: Freeing OBS context data
19:49:20.675: [Scripting] Total detached callbacks: 0
19:49:20.691: == Profiler Results =============================
19:49:20.691: run_program_init: 3541.74 ms
19:49:20.691: ┣OBSApp::AppInit: 23.873 ms
19:49:20.691: ┃ ┗OBSApp::InitLocale: 1.485 ms
19:49:20.691: ┗OBSApp::OBSInit: 1943.33 ms
19:49:20.691: ┣obs_startup: 4.352 ms
19:49:20.691: ┗OBSBasic::OBSInit: 1920.79 ms
19:49:20.691: ┣OBSBasic::InitBasicConfig: 0.523 ms
19:49:20.691: ┣OBSBasic::ResetAudio: 0.171 ms
19:49:20.691: ┣OBSBasic::ResetVideo: 902.245 ms
19:49:20.691: ┣OBSBasic::InitOBSCallbacks: 0.004 ms
19:49:20.691: ┣OBSBasic::InitHotkeys: 0.041 ms
19:49:20.691: ┣obs_load_all_modules: 281.158 ms
19:49:20.691: ┃ ┣obs_init_module(coreaudio-encoder.dll): 5.465 ms
19:49:20.691: ┃ ┣obs_init_module(enc-amf.dll): 29.451 ms
19:49:20.691: ┃ ┣obs_init_module(frontend-tools.dll): 5.144 ms
19:49:20.691: ┃ ┣obs_init_module(image-source.dll): 0.009 ms
19:49:20.691: ┃ ┣obs_init_module(obs-browser.dll): 0.069 ms
19:49:20.691: ┃ ┣obs_init_module(obs-ffmpeg.dll): 0.963 ms
19:49:20.691: ┃ ┃ ┗nvenc_check: 0.92 ms
19:49:20.691: ┃ ┣obs_init_module(obs-filters.dll): 0.033 ms
19:49:20.691: ┃ ┣obs_init_module(obs-outputs.dll): 0.008 ms
19:49:20.691: ┃ ┣obs_init_module(obs-qsv11.dll): 92.964 ms
19:49:20.691: ┃ ┣obs_init_module(obs-text.dll): 0.231 ms
19:49:20.691: ┃ ┣obs_init_module(obs-transitions.dll): 0.005 ms
19:49:20.691: ┃ ┣obs_init_module(obs-vst.dll): 0.001 ms
19:49:20.691: ┃ ┣obs_init_module(obs-x264.dll): 0.002 ms
19:49:20.691: ┃ ┣obs_init_module(rtmp-services.dll): 1.306 ms
19:49:20.691: ┃ ┣obs_init_module(text-freetype2.dll): 0.047 ms
19:49:20.691: ┃ ┣obs_init_module(vlc-video.dll): 0.054 ms
19:49:20.692: ┃ ┣obs_init_module(win-capture.dll): 0.085 ms
19:49:20.692: ┃ ┣obs_init_module(win-decklink.dll): 0.87 ms
19:49:20.692: ┃ ┣obs_init_module(win-dshow.dll): 1.808 ms
19:49:20.692: ┃ ┣obs_init_module(win-mf.dll): 111.917 ms
19:49:20.692: ┃ ┣obs_init_module(win-wasapi.dll): 0.004 ms
19:49:20.692: ┃ ┗reset_win32_symbol_paths: 0.106 ms
19:49:20.692: ┣OBSBasic::ResetOutputs: 8.336 ms
19:49:20.692: ┣OBSBasic::CreateHotkeys: 0.036 ms
19:49:20.692: ┣OBSBasic::InitService: 1.781 ms
19:49:20.692: ┣OBSBasic::InitPrimitives: 0.411 ms
19:49:20.692: ┗OBSBasic::Load: 577.982 ms
19:49:20.692: obs_hotkey_thread(25 ms): min=0.002 ms, median=0.024 ms, max=0.651 ms, 99th percentile=0.435 ms, 100% below 25 ms
19:49:20.692: audio_thread(Audio): min=0 ms, median=0.04 ms, max=4.224 ms, 99th percentile=0.098 ms
19:49:20.692: obs_graphics_thread(33.3333 ms): min=0.435 ms, median=0.708 ms, max=497.124 ms, 99th percentile=6.748 ms, 99.0385% below 33.333 ms
19:49:20.692: ┣tick_sources: min=0.002 ms, median=0.185 ms, max=496.742 ms, 99th percentile=6.109 ms
19:49:20.692: ┣output_frame: min=0.258 ms, median=0.346 ms, max=3.549 ms, 99th percentile=1.052 ms
19:49:20.692: ┃ ┣gs_context(video->graphics): min=0.123 ms, median=0.178 ms, max=2.893 ms, 99th percentile=0.77 ms
19:49:20.692: ┃ ┃ ┣render_video: min=0.031 ms, median=0.066 ms, max=0.227 ms, 99th percentile=0.181 ms
19:49:20.692: ┃ ┃ ┃ ┣render_main_texture: min=0.005 ms, median=0.035 ms, max=0.125 ms, 99th percentile=0.114 ms
19:49:20.692: ┃ ┃ ┃ ┣render_output_texture: min=0.003 ms, median=0.009 ms, max=0.117 ms, 99th percentile=0.072 ms
19:49:20.692: ┃ ┃ ┃ ┣render_convert_texture: min=0.001 ms, median=0.009 ms, max=0.067 ms, 99th percentile=0.051 ms
19:49:20.692: ┃ ┃ ┃ ┗stage_output_texture: min=0 ms, median=0.002 ms, max=0.027 ms, 99th percentile=0.015 ms
19:49:20.692: ┃ ┃ ┣download_frame: min=0 ms, median=0.002 ms, max=0.343 ms, 99th percentile=0.143 ms
19:49:20.692: ┃ ┃ ┗gs_flush: min=0.039 ms, median=0.099 ms, max=0.738 ms, 99th percentile=0.492 ms
19:49:20.692: ┃ ┗output_video_data: min=0.13 ms, median=0.164 ms, max=0.824 ms, 99th percentile=0.824 ms
19:49:20.692: ┗render_displays: min=0 ms, median=0.117 ms, max=3.223 ms, 99th percentile=0.958 ms
19:49:20.692: video_thread(video): min=0 ms, median=0.001 ms, max=0.018 ms, 99th percentile=0.018 ms
19:49:20.692: =================================================
19:49:20.692: == Profiler Time Between Calls ==================
19:49:20.692: obs_hotkey_thread(25 ms): min=25.1 ms, median=25.928 ms, max=26.16 ms, 2.7027% within ±2% of 25 ms (0% lower, 97.2973% higher)
19:49:20.692: obs_graphics_thread(33.3333 ms): min=6.756 ms, median=33.333 ms, max=497.131 ms, 97.0874% within ±2% of 33.333 ms (1.94175% lower, 0.970874% higher)
19:49:20.704: Number of memory leaks: 1
Spensaur23
I think that one will work, i also made a session and tried to add a filter to my display capture and it froze so i have that log here
  • 2018-07-19 19-55-08.txt
