Question / Help Recordings randomly sped up (opposite of slow-motion)
Tevaron
I've searched for this and can find no mention of it by anyone else, I've been experiencing this problem with both the multi platform and regular obs.
Sometimes, not always, I will record something and when I play it back the footage is sped up, like its in slight fast forward, for example a video that should be 2 hours and 30 minutes will end up being 2 hours and 15 minutes with everything slightly sped up as a result, this happens with shorter videos also. What is strange is that it doesn't always happen. I can sometimes even do a test recording that is fine, then do one I intend to use and it is sped up.
The major problem with this is I record my voice over separately for editing purposes and in these cases the two files will not sync correctly. Sometimes when this happens I can time stretch the video and get it to work, other times (today in fact) the video distorts in some fashion every time I try and I end up losing hours of effort and having to do it again.
I initially though my overclocked cpu was at fault and the faster system clock was affecting encoding in some manner, so I went back to stock speeds and even locked my cpu so it won't turbo. I thought I had figured it out as it seemed to stop happening, then it started happening again, randomly.
here is a screen shot of my recording settings, which I leave the same every time:
I will also load the log file from today and one of a video that did fine from 2 days ago
Any help is appreciated I'm really not looking forward to having to go back to FRAPs or find some other solution.
  • 2015-08-19 11-11-07.txt
  • 2015-08-17 14-07-07.txt
