Recording Output Issues (Choppy Video)
Cloud2K
Hello, I am experiencing some issues when attempting to record Counter-Strike on my computer. The game itself runs fine and the preview window inside of OBS appears to have no issues but the recording output itself is incredibly stuttery.
I have spent the last hour browsing online, and on this forum to try and find some answers and troubleshoot, if I had made any progress then I wouldn't be making this post.
Here are my system specifications:
OS: Windows 11 Ver. 22H2 (OS Build 22621.2215)
CPU: Intel Core i9-10850K
GPU: NVIDIA GeForce RTX 3080
SSD: Samsung Evo Pro 2TB M.2 SSD
RAM: 48 GB
Here are my windows settings:
GPU Hardware Acceleration: Off
Windows Game Mode: Off
Xbox Game Bar: Off
Here are some notes about my game:
Mode: Window Mode
RAM: The game uses 2.3 GB of RAM and my total PC use is around 15 when recording
Steam Launch Options: -high -threads 6 -allow_third_party_softwares
I thought initially it may have been my ignorance to the settings in OBS as I have never needed to adjust them after the initial setup wizard. The setup wizard itself was run with the application run as an administrator, and I have only run the program as an administrator when recording.
Advanced > Recording
  • Type: Standard
  • Recording Format: .mkv (I have tried .flv)
  • Video Encoder: NVIDIA NVENC H.264
  • Audio Encoder: FFmpeg AAC
Advanced > Process Priority
  • Normal (I have tried Above Normal, and High)
Advanced > Encoder Settings
  • Rate Control: CQP
  • CQ Level: 20 (I have tried lowering to 16)
  • Keyframe Interval: 2s
  • Preset: Slow (Good Quality) (I have tried adjusting up and down)
  • Multipass Mode: Two Passes (Quater) (I have tried Full)
  • Look-Ahead: Disabled
  • Psycho Visual Tuning: Enabled
  • GPU: 0
  • Max B-frames: 2
Advanced > Video:
  • Renderer: DirectX 3D 11
  • Colour Format: NV12 (8-bit, 4:2:0, 2 planes)
  • Colour Space: Rec. 709
  • Colour Range: Limited
  • SDR White Level: 300 nits
  • HDR Nominal Peak Level: 1000 nits
Audio > General
  • Sample Rate: 40kHz
  • Channels: Stereo
Advanced > Sources:
  • Enable Browser Source Hardware Acceleration: Enabled
Video:
  • Downscale Filter: Bicupic (Sharpened scaling, 16 samples)
  • Common FPS Values: 60
Any help is welcome and appreciated.
Cloud2K
Please provide the log file from the recording session.
Apologise I needed to search online where to go to find it, here is one from a recording where I am suffering from the same issues mentioned above.
  • 2023-09-06 15-18-50.txt
If you're watching the video with windows player, please try using VLC player.
Also, you may want to enable windows game mode because it helps.
